Question about Sony PlayStation Portable (PSP) Slim (PSP-2000) Console
Psp wifi well, every time a scan for local connections, i found mine connection, i do everything right but, when the psp searches for the IP adress the psp doesn't found it, plz help
  • kakaroto1707 Jan 29, 2009
    i already did that,
    to reset the router, the same have to be off???
  • 132 Answers
Reset your router and try again
Posted on Jan 28, 2009
  • Derek Powers
    Derek Powers Jan 30, 2009
    Turn the router off for 30 seconds - 1 minute and then turn it back on.
Ip adress timed ou
Try power-cycling the router (unplug and plug back in). Make sure wifi is enabled on psp (green light @ bottom left, toggle switch is on bottom left of psp). Also, when typing in encryption key, make sure the encryption protocol settings on the psp are the same as what your psp is broadcasting. So if your router is broadcasting WPA/WPA2 encryption, make sure psp is set to that.
Hope this helps.
Oct 25, 2011 | Sony PSP 3000 (0 MB) Black Console
Connection in inter net
Hello. For connecting to internet with your PSP, you have to follow these steps:
1. Press home and go by pressing 2. You have to choices. Ad-Hoc (when the connection is realized between two PSPs) and Infrastructure Mode (when you connect to a local wifi device). This is what you will select.
3. Choose New Connection
4. Enter a different name so you can remember it easily. (To enter a new connection name, press X and you will see a keyboard screen. Press Enter and X.
5. If you turned on your WLAN switch (On the lower left edge of your PSP is a small slider switch which you have to slide it upwards) then you will see a status message "Scanning. Please wait"
6. You will see now some network connections. You need to know the password of it in order to access it.
7. Select one and press to continue.
8. When you see Adress Settings press easy. Then you will get a confirmation screen. Press > to save your settings.
9. Press X and make a test connection.
I hope I helped!
May 21, 2011 | Sony PlayStation Portable (PSP) Console
Nine times out of ten I can't get an internet connection on my recently bought emachine netbook. Says connection available but no connection. I have another laptop in the same room and this is always...
disconnect your router for 10 sec's, then turn on, turn off wifi device on ur laptop, then turn it on again, renew your IP adress, you can find a step by step guide in google, just search "how to renew your IP adress
May 15, 2011 | Computers & Internet
When i try to connect to the internet on my psp it says my
Hi! At This Time : I use WPA PSK encryption simply because it is the only one i can work out how to set up and the PSP will not support this which is why i disable encryption while using it! But : i had that error. wut I did was (u can do this from in the game or in network settings) delete the one that should be working. did it all over again and this time I scanned for a connection. when I found my connection, I used it. and i redid the connection and it worked when I tried it again. Fix-sha0w
Jul 14, 2010 | Sony PlayStation Portable (PSP) Console
Need ip address for syrens, not sure if i remember right:
Hi Stephan,
the ip address of your router by default should be "". to check if the ip adress of your router here's the solution :
  1. go to control panel > network and sharing/networking >change adapter settings
  2. then you'll see your local area connection
  3. right click on it>properties
  4. double click on (internet protocol tcp/ip) "tcp/ipv4 in windows vista/7
  5. the select "obtain ip address automatically" & "obtain dns server464142c.jpg automatically" click ok and click ok for the other window
  7. the dns server ip show should be your router ip adress
  8. open your web explorer and type in your router ip an press "enter" you'll get your router configuration where you'll be able to change the default ip.
I hope that it will help & don't forget to rate
Kind regards
Feb 14, 2010 | Sea and Sea Syrens OnBoard WiFi...
Ummm when i try to hook the psp to the wireless
prob you have to check your router settings or make sure u entered all of the required feilds on the psp
Feb 08, 2010 | Sony Video Game Consoles & Games
IP adress dosent work.
You need to match the security settings on the Wifi router. I do not know what security is set up on your Wifi, so I cannot accurately solve this problem. I have my router set to WEP with a passcode. On the PSP, I tell the network setup that the wifi is WEP and put in a passcode to match the Wifi routers security. If you have the passcode wrong, the IP address part will fail. Just find out the security type and passcode, then set up the PSP's network connection to match.
Dec 30, 2008 | Sony PlayStation Portable (PSP) Console
How do I get my PS3 Online?
right fist of go on settings on the ps3 menu then go to network setting then click onsettings and connection status list take a note of all the ip addresses and servers then go to internet connection on the same menu and click on scan then click on your router name and then lick onenter ur wep key if u av 1m but if u dnt then cck on none then press right then go o custom on the address setting then manual on ip adress settings type in all ip address and servers and stuff then click on auto on the mtu dont use proxy server enable unpn click right then press x to save ur settings then test connection thn hopefully this works for u m8 cheers arsenal_07
Mar 24, 2007 | Sony Playstation 3 (PS3) Console
Sony PlayStation Portable (PSP) Slim (PSP-2000) Console Logo
147 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
