Question about HP Computers & Internet
Is there a wireless and bluetooth combination module
Laptop is an HP 9013cl with wireless card installed. Want to add bluetooth capability. The module installed is HP 412766-001. The bluetooth card part # is HP 412766-002. Is there a way to have both a wireless connection and bluetooth in this laptop model? I have seen HP 397922-001 known as multi unit module, bluetooth adapter. Does this module have the ability to perform both wireless and bluetooth combined into one?
  • HP Master
  • 2,258 Answers
Ever thing to ask HP real>? below?
we are not HP we sell nothing here nor are there drivers here,
or anything here, only chat.
the answer is sure, some PC sold by HP, and for sure laptops
have dual/ wifi/blue tooth miniPCI module offered day 1 new.
i just upgraded my neighbors for free.
This only applies to specific models, so ask HP.
answer 2 is buy a usb thingy,, blue tooth mines like f1/2 a finger nail long and fits on any pc made with USB jacks.. blue tooth add ons
are super best way to add it. and way cheaper too.
mine is 1/2 a dime sized. (not counting usb end that hides inserted)
real
https://h30434.www3.hp.com/
Posted on Jul 19, 2017
ddao52
  • 41 Answers
SOURCE: wireless capabilities
hit the Function key (usually "Fn") then F2 should work. Also on most Fujisu's the wifi button is some where around the top left might want to try that also with or without Fn.
let me know if everything works out, also please take the time to rate me!
-Daniel.
Posted on Nov 19, 2007
lfty888
  • 10 Answers
SOURCE: Function Key Combination to Turn On Wireless?
Try to check the bios settings if WIFI is enabled. because if you turned on the switch but if it's disabled in the BIOS, it'll still won't work. :)
Posted on Feb 17, 2009
El Geek
  • 149 Answers
SOURCE: no wireless capability
If your model does not have wireless capability, even if you had a switch on the machine, if there is no internal wireless card you can't make this wireless. My suggestion would be to purchase a PCMCIA or USB wireless card that you can load to your system to make this wireless capable.
Posted on May 22, 2009
msnseb
  • 88 Answers
SOURCE: Dell Precision M6300
There is a bluetooth device installed, but no driver, or updated driver to run it!
Posted on Jul 06, 2009
SOURCE: My wireless capability is turned off
How do I turn on the wireless capabilities on my MSI laptop?
Posted on Dec 25, 2009
Rfi or emi problems
Rut-ro reggie!
It's H.A.A.R.P. or aliens from space!........
Or maybe it's a bad Bluetooth/Wireless Module; in the laptop, lol!
Radio Frequency Interference or Electro Magnetic Interference, I can see from an outside source..........but Blue screen too?
Leads me to believe a bad hardware component.........
HP Support > Pavilion dv6-7010us Notebook PC > Main Support page,
http://h10025.www1.hp.com/ewfrf/wc/product?product=5273519&lc=en&cc=us&dlc=en
Click on User guides in the list,
Click on -
HP Pavilion dv6 Entertainment PC Maintenance and Service Guide
Go to Page 35. (Adobe Reader page number at Top. Actual manual page is 27)
Let's use the Athens 9485GN for an example.
HP part number - HP 655795-001,
http://www.ebay.com/itm/HP-655795-001-654825-001-b-g-n-WiFi-BT-4-0-Combo-Card-Atheros-AR5B225-/150965238736
See the gold plated contact pins on the bottom?
FOLLOWING Anti-Static Procedures, a pencil eraser is used to clean those contact pins. BOTH sides.
If using an eraser on the end of a pencil, and not a solid eraser; refrain from letting the metal band on the pencil, touch the gold plated contact pins.
Rub up and down, and back and forth; on all contact pins.
Doesn't take much pressure, nor rubbing, to make a clean contact surface.
(Doesn't take much 'corrosion', to make a bad contact surface)
Use air to remove the eraser dust. You can use a can of compressed air for computers, if available; or air pressure from your mouth will be sufficient.
Also clean the copper area (Holes) where the mounting screw/s go through.
Also clean the Terminals. Main and AL I
http://www.ebay.com/itm/HP-655795-001-Atheros-AR5b225-WIFI-N-WLAN-wireless-BT-Bluetooth-4-0-Half-Card-/180953894044
Try to clean the connectors on the wires that go to the Wireless/Bluetooth Adapter card, also.
(Wireless Antenna wires)
Reinstall Wireless/Bluetooth Module. Reconnect Wireless Antenna wires. (Properly)
If this does not resolve the issue, then suggest replace Wireless/Bluetooth Module.
Agree that I am 'going out on a limb' with these statements.
Could be something else. May be damage to the LCD Cable. (Video Cable)
Causes 'blue screen'.
Trying to correlate blue screen, and RFI/EMI interference; is a tough job; over the internet.
Laptop was in front of me, I would look for damage to the Wireless Antenna wires, first.
They loop under the right Hinge, and are just as prone to damage, as the Video/LCD Cable is.
(The Video Cable, or LCD Cable if you prefer; routes under the left Hinge)
No apparent signs of damage to the Wireless Antenna wires, (Visual inspection), I would remove the Wireless/Bluetooth Module, and clean contacts as stated above.
Blue screen occurs again, I would look into the Video Cable.
Video Cable connections are tight, then I would perform a continuity test on the Video Cable. Multimeter set to OHM's (1K), and check every wire in the Video Cable for continuity.
(Assistant for gently wiggling the cable, as Continuity test is performed. Checks for Broken/Stretched wires. Multimeter reading fluctuates when cable is gently wiggled, you know you have a broken wire)
A bad graphics chipset, will knock a laptop to it's knees. (Turns off)
Thinking is a bad Wireless/Bluetooth module, can do the same.
Knock the laptop to it's knees far enough, that no graphics are shown. There is also RFI/EMI interference, and this goes along with my thinking, that there are bad contact surfaces, or bad Wireless/Bluetooth Module.
Just my 2cents
Regards,
joecoolvette
[You open that laptop far enough to access the Wireless/Bluetooth Module, you better be wearing an ESD wrist strap; and have it's alligator clip attached to a good ground source.
Otherwise you will Static shock out the laptop, and have an expensive paperweight.
Average cost is $3 to $6 ]
Apr 27, 2013 | HP Pavilion dv6-7010us Entertainment...
Hp dv6 no wireless capability - light will not go to blue from organe on f12 key press it says wifi off again wifi disabled
When you pulled the Wireless Module, then reinstalled it; you made Windows find the Drivers, again.
[When a new device is installed, Windows 'breaks it's neck' to find suitable matching drivers.
You reinstalled the Wireless Module, and made Windows think it was a new device ]
The wire terminals can 'corrode'. (It's gold plating, and gold isn't supposed to corrode. Just a term I used to explain)
The terminals on the Wireless Module can also 'corrode'.
Try using a pencil eraser on those two contact 'pins'.
The connections of the wires to Wireless Module, MUST be tight.
Can swivel if you move the wire, but not seem loose.
(That is with ALL power removed to laptop. AC adapter {Charger}, and Battery )
Still persists? Suggest new Wireless Modem Card.
Regards,
joecoolvette
Dec 25, 2012 | Computers & Internet
Hello I m having HP Compaq nx6325 laptop with XP .Now wants to activate Blueetooth tried some options i.e installed IM bluetooth and Hp Wireless but in vain.HP Wireless Assist. showing as Disabled and ...
XP great OS but it may not work with your BT device a compatibility issue. Bet that if you try your device with a computer that has Win 7 or greater OS, the device will work.
Sep 22, 2017 | HP Compaq nx6325 Notebook
I have hp pavilion dv6325ca laptop can now i upgrade my laptop with internal bluetooth module as already i have a internal wireless adapter can u suggest how to upgrade
The easiest option for you is to buy a Bluetooth dongle. It connects via USB, and if you get a compact one like the one in the image below you won't even notice it on the laptop. You can get one from Ebay, they are dirt cheap, under $2.
Dec 23, 2010 | HP 407674-004 - HP Compaq nc2400, Pavilion...
How do i connect a bluetooth device to my compaq
first download and install two things on your laptop.
You can find them on this site:
http://h20000.www2.hp.com/
SeriesId=3355650&lang=en&cc=us
after choosing the correct system:
1.
Software Support for HP Integrated Module with Bluetooth Wireless Technology
2.
HP Wireless Assistant
Both are in the network section.
After installation enter HP Wireless Assistant and switch on Bluetooth
Dec 09, 2010 | Compaq Presario CQ60-220US PC Laptop
The bluetooth logo is there but each time i try to enable it,it keep telling me that there is no device and i was told in the customer,s guide note to enable it by clicking Fn + F3 but each time i try...
Sometimes on laptops there is a access panel on the bottom of the laptop that when you take them off will show slots for inserting additional ram, wireless network, modem and bluetooth modules. If you can look and see you may find that your laptop has the capability for bluetooth, but may need a card installed. If your laptop does not then you could always buy a usb bluetooth like the one here: http://www.cellularfactory.com/laptop/ACER/4/31883/518537/
Thanks, Matt
Sep 22, 2010 | Computers & Internet
How to enable bluetooth on hp pavillion laptop
Hey there,
If your particular model of HP has the bluetooth installed from the factory, turning on the wireless switch on the front left edge of the laptop enables the bluetooth, as well as the wireless LAN. A bluetooth icon should appear in your taskbar, near the clock, when bluetooth is turned on. Most of the cheaper versions of the DV6000 series do not come with the bluetooth module installed. The module can be ordered from HP Parts and installed by the end user, if they have a little computer know how. You would then download and install the bluetooth software pack that is available on HP's support website.
Hope this will help to resolve your issue with Bluethooth..
Cheers!!!!!
Vivek
Feb 14, 2010 | Computers & Internet
No wireless capability
May 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Where and what (sim card only, wireless card+sim card ??) to put into an hp nc6000 laptop to have benefit of what is yet inside (or supposed to be inside like the antennas ) and access to internet ,...
A wireless card should be already be in that system. There is no SIM card. According to HP's specifications, your laptop should have one of the following wireless devices integrated into the laptop:
The HP nc6000 notebook supports a broad range of secure, integrated wireless LAN options featuring support for the latest industry standards. Integrated Bluetooth is also an option and can be combined with any one of the supported wireless LAN options. All integrated wireless LAN options Wi-Fi certified
Cisco Compatible Extensions support
Wired Equivalent Privacy (WEP) support up to 128-bit keys
Wi-Fi Protected Access (WPA) support
802.1x standards support including EAP-TLS, Protected
EAP (PEAP) and Cisco-EAP (LEAP)
Dual antennas integrated in the display enclosure HP W500 802.11a/b/g Integrated support for 802.11a, b and g
Up to 54mbps throughput performance
Advanced Encryption Standard (AES) support Intel PRO/Wireless 2100 802.11b wireless LAN Intel® Centrino™ mobile technology
Integrated support for 802.11b
Up to 11mbps throughput performance Intel PRO/Wireless 2200 802.11 b/g wireless LAN Intel® Centrino™ mobile technology
Integrated support for 802.11b and g
Up to 11mbps throughput performance Integrated Bluetooth Designed to the Bluetooth v1.1 specification
The full information is here:
http://h18000.www1.hp.com/products/quickspecs/11794_na/11794_na.HTML
If everything is working properly, all you have to do is find your local Starbucks or other WiFi hotspot and connect.
Mar 09, 2009 | HP Compaq nc6000 Notebook
Wireless or Blue tooth capable
You may call HP Tech Support At toll free- 1-800-585-2494 and ask any technical question to hp support agent. you may also contact them via chat support by visiting: HP Customer service . hope this will help you better.
Aug 08, 2008 | HP Deskjet 6980 InkJet Photo Printer
Computers & Internet Logo
24 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
