Question about Plumbing
Where is reset button on goulds water pump for house
2 Suggested Answers
  • 512 Answers
SOURCE: Goulds pump model BGR75 won't reset. Any tips.
If the motor runs but keeps tripping the overload, the motor is bad or the motor is under a big load. Does it pump water? If not, check the impeller and see if there is anything wrong with it. If it does pump water and the motor trips overload, the only thing left to check is the overload. Check the motor's amp draw and if within specs, replace overload. If amps are too high, replace motor.
Posted on Oct 07, 2012
Goulds j5s pump discharging rusty water and green moss particles. how do i flush
If its discharging all the time, I would say its sucking up contaminated water but if only occasionally, that would suggest something is rusting / deteriorating in the system and it "grows" when the pump is not in use. I would have a close look at the source tank(s), the connecting pipework and as a last resort, disconnect the pump and have a look inside the pump chamber.
Jan 04, 2016 | Goulds Pumps Goulds 1/2Hp Shallow Well Jet...
How do i prime a gould j5 pump
to make it easy to prime a pump I put a "T" piece in the suction line close to the pump. When it needs priming I take out the plug and put water in the line until the pump is full
Oct 17, 2014 | Goulds Pumps Goulds 1 Shallow Well Jet...
Why dont i have water pressure after my pump cycles off
Make sure your tank is well pressurized and not water logged.Is there a significant difference between your cut in and cut off pressure.Check for leaks -water or air.
Sep 07, 2014 | Goulds Pumps Goulds 1 Shallow Well Jet...
PRIME A GOULD PUMP
whats your question how to prime the pump? if so at the bottom is a 3/4 inch plug screwed into it, or at top, once the pump is hooked up to the lines turn off the power, and unscrew the prime plug fill with water, then screw in tight DO NOT USE THREAD SEALANT THEN THROW THE POWER TO THE PUMP, of course house supply valve must be off 3/4 turn valve off until the line is primed then open the supply line to house slowly to supply the water to all the lines, NOTE WHEN YOU FIRST INSTALL A NEW PUMP, HAS TO BE PRIMED, HAVE TO HAVE SUPPLY LINES FROM WELL TO HOUSE CLOSED TO PRESSURE THE TANK AND TO FILL THE LINES.
Apr 27, 2014 | Jet Flo 04325143A Marine Heavy Duty Water...
Water pump for the house keeps re-cycling, without using water
IS THE TANK WATER LOGGED? THERE HAS TO BE SO MUCH AIR IN THE TANK TO KEEP PRESURE.
Nov 28, 2013 | Goulds Pumps J and JS Series Pump nozzle...
Gould j5s, pump not going above 15 - 20 psi, does this sound like it could be a priming issue or not since it is pumping some water?
how much pressure do you want with a 15 to 20 psi, really what are you pumping house water, you need more pressure to supply a home like a 60 psi with an exterol tank
Nov 18, 2013 | Jet Flo 04325143A Marine Heavy Duty Water...
Gould water pump water pump will not shut off ,have replaced preasure stwich &GAGUE,HOLDING GOOD PREASURE
Does the switch click open, if so it is wired wrong. If not it is set to high.
Aug 15, 2013 | Goulds Pumps Plumbing
Goulds pump
check for air leaks in the connections our your pressure switch is bad
Apr 24, 2013 | Goulds Pumps Goulds GT15 - IRRI-GATOR Self...
What is the impeller
The impellor is that blade attached to the motor shaft and has curved blades (some exposed others in a two sided unit) that throws the water from the center and out the outlet hole.. IT can be keyed on but mostly they are threade4d on with L.H. thread. When you split the housing that is what you will be looking at
Jan 29, 2013 | Goulds Pumps Goulds gt10 1 1 Phase...
Water stopped running in house, I was running hose for about an hour and water justed stopped. reset breaker and still no water
take the screws out of the bottom of the pump maybe sand in the impeller.that pump s/b off the bottom of the pit on like a brick or something
Apr 22, 2010 | Goulds Pumps Goulds 1/3 Hp 115V 1 Phase...
Plumbing Logo
46 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
