Question about CA6550 Codealarm Remote Start Security System w Keyless Entry 2Way Meta
How do i reprogram remote
Lost battery power now i need to reprogram car remote
Remote does not work nor does power locks, mirrors power seat reset
find the relay, it will be a multi functional one, good luck
Feb 02, 2015 | Seat Cars & Trucks
The power won't come on when i push the power button
If you are using a universal remote the program is lost anytime the batteries are removed or sometimes when the remote is dropped the program is lost.
If that is the case you only have to reprogram it.
Oct 16, 2014 | Televison & Video
Brand new batteries in my remote. Tried to reprogram. Worked. Remote sperattacly works. 2010 model.
IF you took too long to change the batteries in the remote it may have lost some memory. The remote can be reprogrammed by a service dealer but they will need the remote and the car to do the job.
Sep 11, 2013 | 1998 Ford F150 Regular Cab
I have a universal remote and lost my manual, put new batteries in my remote...and now have to reprogram for my tv can you tell me the code for a sharp tv/vcr combination?
Here is a link to download the manual with instructions for programming the codes:
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/one_for_all/urc4220-manual.zip&area=other
Aug 18, 2011 | One For All URC4220 Remote Control
Panasonic DMR-EZ28 won't talk with remote
hi you need to reprogram the remote to fit with the unit there have 3 codes for remote 1 or 2 or 3 to reprogram your remote with the code indicated on your display press and hold the [3] and [ENTER/OK] buttons together for approx 5 to 10 seconds, then release
Jun 24, 2009 | Panasonic DMR-EZ28K DVD Recorder
Power locks won't work from remote
make sure the button inside the remote makes contact with the outer plastic, might want to open it an try to press it an see if it works...!
May 28, 2009 | 2000 Ford Ranger SuperCab
Toyota 2000 Landcruiser Pardo remote need to reprogram
forgive my poor english/do U have a challanger alarm in Your car?If U have U must programm Your pilot in service because challenger has a radio device to programing pilot to the system
May 17, 2009 | 2000 Toyota Land Cruiser
Code for remote
need a code for a rca tv for my remote
Dec 07, 2008 | Philips Magnavox Learning Universal Remote
Changed batter remote start not working
Hello, What has happened is your remote has lost its programming.. Just like with most electronics, when something is reset or powered off, or even when the battery dies ....the programming software is lost. The remote has to be reprogramed either by a dealer (suggested) or by an aftermarket outsource..Hope this helps...This could help with almost all remotes.
Nov 22, 2008 | DEI GM Immobilizer Bypass
Reprogramming keyless entry remote...
Believe it or not, the information and instructions for reprogramming your particular model of vehicle is provided in your owner's manual. The dealer does not need to be involved unless you have lost all your programmed and programmable keys.
Aug 19, 2008 | 1999 Ford Econoline
CA6550 Codealarm Remote Start Security System w Keyless Entry  2Way Meta Logo
Top Audiovox Vehicle Parts & Accessories Experts
xxxxxx xxx
Glen Weitzdoerfer
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
