Question about Altec Lansing M402SR IPOD HOME AUDIO wCLOCK M402SR Clock Radio
Won't turn on
Stopped working No power seems a fuse blew up
My turn signals, windshield wipers and rear window defroster stopped working all at the same time. The fuse and multi-function switch are both fine.
Check all fuses with test light or multimeter. I tend to agree with you that it is probably a fuse. Not knowing of any "hidden" fuses or in-line fuses on that system. But sometimes other fuses that are not labeled as wiper or turn signal might be used for power also. So, check all fuses including the ones under the hood.
Feb 22, 2015 | 2002 Chrysler Sebring
Stopped Working All Together
Hi, bring to your nearest service center to repair it.
May 18, 2013 | FUJIFILM Instax 210 Film Camera
Chevy Avalache 2007 blew a fuse while getting a jump, car won't start, rear windows and power locks don't work
You blew more than 1 .
The HUGE MAXI FUSE is probably burned... IF I remember correctly, it is a 80 or 100 Amp
Apr 06, 2013 | 2007 Chevrolet Avalanche LTZ
Power door locks won't work and the instrument pnnel lights won't turn on. I replaced blown fuse a 20mp one in position 14 I believe. worked ok till I tried to lock the doors, the fuse blew
Hello. Try looking at the black earth that goes from the drivers door and into the A frame which is covered in a rubber sheath. The wire can break after opening and shutting the door over several years and as it's normally the thicker wire is more prone to break. Also check the other wires visually for any chaffing and tugging on each wire. If more electrical parts start failing, air con blowers etc it will be an earth. Hope this helps
Nov 03, 2012 | 2002 Dodge Neon
What's your problem?The horn won't work, the light that is supposed to go on when you open the doors won't work, the cigarette lighter won't work, and the head unit won't work
on 1987 all you mentioned are on same fuse #11 located in fuse box below steering wheel 3rd row 3rd fuse from left next to either a blank space if you do not have power windows,or next to silver circuit breaker if you do have power windows.
May 23, 2012 | 1987 Chevrolet Camaro
Why is my frigidaire washer not spinning?
  1. Stopped Mid-cycle
    • If your Frigidaire washing machine started spinning, but then stopped, verify that the power cord is still connected to the outlet. See if the outlet blew by plugging in a different appliance into the outlet. See if you blew a fuse. A blown fuse usually is either black or has broken wires. Replace the fuse. If you have a circuit breaker instead of a fuse box, reset the circuit breaker if it's been tripped. Check the lid switch, which is located inside the main housing of the washing machine, near the door frame. If the switch is burned out, order a new part from a Frigidaire parts dealer.
    Pump
    • The pump's sole responsibility is to remove water during the spin cycle. If the pump isn't working properly, see if it's clogged with debris or clothing. Use needle-nose pliers to remove these items. Check the pump pulley, which is connected to the pump. This component must move freely for the pump to work. If it won't turn, purchase a new pump pulley since you can't usually fix this component.
    Lid
    • Check the door latch assembly if the door isn't closing correctly. If any of these components are broken, order a new part from a Frigidaire parts dealer. If you do not, the washer won't start spinning since it believes the door isn't closed. Your Frigidaire washing machine won't start the spin cycle until the lid or door is closed. Always close the lid, and remove any items preventing the lid from fully closing. Always close the dispenser drawer.
    Additional Concerns
    • Never over- or under-load your washing machine. Your Frigidaire washer may not enter the spin cycle if the load is too large, since this can damage the washing machine. Remove a few pieces of clothing. If the load is too small, add a few similar items to the washing machine. Check the internal belt, drive motor and motor coupling. If any of these components are broken or very worn, they may not work properly, preventing the washer from entering the spin cycle. Order replacement parts from a parts dealer. Check the tub and basket bearings, and get new ones if the current ones have broken components or are defective.
Sep 27, 2011 | Washing Machines
My 2yr old whirlpool dishwasher model# DU1145XTPBA, ser# FU3026019, 2.7 amps, type# 5750-0 has stopped turning on. I never had any trouble out of it and now it won't turn on. I thought maybe a fuse...
It is possible the thermal fuse located in the control panel has blown.
See item 5 in this diagram. You could attempt to replace it.
make sure the power is disconnected when you are working on the dishwasher.
Hope this helps.
Jun 21, 2011 | Whirlpool Dishwashers
My entire gauge cluster will not work, temp gauge, fuel, rpm, and speed... it will light up, but not work. My Windows won't work either, I replaced the relays... but no luck. If I bypass the relay the...
You most likely fried a wire or blew a fuse. If it is the fuse, just find which one blew and replace it. If it was a wire, you're going to have to isolate and replace it. Better invest in a Digital Volt Ohm Meter. (DVOM)
May 08, 2011 | 1995 Honda Accord
Altec Lansing M402SR  IPOD HOME AUDIO wCLOCK M402SR Clock Radio Logo
22 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
