Question about Samsung LN Computers & Internet
Samsung LN32C450E1DXZA flickering
Screen flickers
SOURCE: Samsubg Monitor flickers
My samsung 740N lcd Monitor is flickering. can i get a solution of this problem?
Posted on Nov 05, 2008
SOURCE: Samsung 215TW Monitor Flicker
Its the capacitors on the backlight power supply. Samsung installed crappy ones and they blow up after a year or two. Change out the caps and you're good to go
Posted on Jun 09, 2009
  • 1684 Answers
SOURCE: Samsung 214t syncmaster flickering
It sounds like you have a monitor with a common problem. After a few years some LCD monitorswill blow a power supply. The problem is caused by parts calledcapacitors overheating in the confined space of the monitor. If you aregood at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should workfine.We just posted a repair guide showing how to remove the case ansreplace the parts. The capacitors do need to be installed with thecorrect + and -connections, note the stripe on the old one and insert the new one thesame way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 25, 2009
Geekman
  • 32281 Answers
SOURCE: Samsung 226bw visible flickers just after it is turned on
You may have a faulty inverter or loose power inverter connection. OR
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Posted on Aug 31, 2009
joelwilcox
  • 1274 Answers
SOURCE: My flat screen Samsung monitor flickers on and off
or it could be the cable? if you have a different vga cable you can try that, if that's not the problem then it sounds like your lcd is possibly dying. you should also look at the pins on the vga connections and make sure none of them are bent
Posted on Oct 31, 2009
My samsung led tv flickers but not all the time
Flicker can be adjusted. If you wish to get some details; check the site linked here. Pull up older posts.
Sep 03, 2016 | Samsung Televison & Video
Can a bad power board in a samsung tv cause flickering in the screen?
It sounds like your lamp is getting ready to go out, but you are also correct in the fact that a bad ballast could also make the lamp flicker. I hope this helps.
Feb 19, 2016 | Samsung 60" Series 8 LED HDTV - UN60F8000
Top half of tv is white it started with just a line from side to side and has become worst
half the picture on my tv screen turned completely white. ' IGN ...
www.ign.com > Boards > Community Central > The Vestibule
IGN
May 3, 2014 - 7 posts - ‎4 authors
what half? down the middle or every line of pixels? did you google the issue with your tvmodel? my samsung has issues with bad capacitors ...
samsung led ua40d5000 tv half screen turning white - Forums - CNET
www.cnet.com > Forums > Samsung
CNETMay 16, 2013 - samsung led ua40d5000 tv half screen turning white ... Interestingly after half an hour if i push back the TV from top left corner then problem ... Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Dark shade appears in the below half of the LED TV screen
Oct 23, 2014
LED Samsung Smart TV half screen lose in colour
Sep 11, 2013
Runco PL-61cx plasma tv, top half goes black
Jan 13, 2010
More results from www.cnet.com
LCD TV Samsung LN32C450 top half screen problem ...
? 3:58
https://www.youtube.com/watch?v=SawMHKpsYOA
Jun 8, 2015 - Uploaded by Vladimir P.
This is for my Samsung LN32C450E1DXZA that is having major image issues with the top half of the screen ...
Samsung ScreenTartan/Plaid Pattern on top half of screen ...
? 1:22
https://www.youtube.com/watch?v=ue9IQwj7CVM
Feb 03, 2016 | Televison & Video
I have a 40inch Samsung le40r88bd that keeps flickering and is getting worse is there an easy fix?
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
https://www.youtube.com/watch?v=i-jQZ-TQdgU
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture EASY most common way MODEL ...
Flickering picture
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMar 13, 2013 - A flickering picture on your TV can be caused by the following conditions: Television settings; Incoming signal issues; Electronic interference ...
How to fix Samsung LN46C630 screen flickering issue
Jan 16, 2016 | Samsung Televison & Video
Need fixs how do i make it stop flickering?
How do i stop my vizio from flickering? - YouTube
? 2:18
https://www.youtube.com/watch?v=RD2PwPFpbrE
Jul 19, 2013 - Uploaded by colguon38
Please help me stop my TV from flickering. ... 1080p. the monitor will momentarily change resolutions. that is the "flicker" you see. unfortunately i ...
? 3:43
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture EASY ... I have this exact make and model. .... and theflickering didn't stop. any ideas as to which JP I should cut . please help not ready to buy a new TV.
VIZIO flickering Tv screen easy fix( no money ) - YouTube
? 1:58
https://www.youtube.com/watch?v=oWSFwS3FH_c
Aug 28, 2012 - Uploaded by Bill GatesBestfriend
this might work for other tv's too. ... If your not sure you can dothis repair your self please take it to a tv repair shop. The repairshould be ...
Jan 04, 2016 | Televison & Video
Samsung tv has flickering lineswhile watching tv
? 3:43
Jun 4, 2012 - Uploaded by Tampatec How to Fix Samsung TV Flickering Blinks Flashing Flat Screen ... Rating is available when the video has been rented. ... sorry to bother you tampatec but i have a RCA tv it works great when it's.... My Toshiba Full HD led tv model 32PT200ZE is having issues of screen blinking/flashing and horizontal lines.
Sep 25, 2015 | Samsung Televison & Video
Screen flickering on and off.
I have the same problem with mine. I've kinda narrowed it down to it being the power supply in the monitor. was told it is about a $20 fix but we'll see
Nov 16, 2009 | Samsung SyncMaster 731B 17" LCD Monitor
PS3 - Screen Flicker
You need to try a new HDMI cable.. Cheap HDMI cables do that? I had the same thing happen to me... I switched the HDMI cable and it fixed mine.
AV
Jan 14, 2008 | Sony Playstation 3 (PS3) Console
Losing picture color on TV
Screen flicker can also be a bad dynamic black unit. Do you hear a low pitch growl when it flickers?
Dec 30, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
Computers & Internet Logo
41 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
