Question about Fisher and Paykel Washing Machines
Brown stains/lines on my washing
12 yrs old, electronic controls
    Sergeant:
  • 291 Answers
If it's a front loader it may be coming from the rubber door boot. Take a rag and rub the boot and see if it discolors the rag. If so replace the boot. 12 year old rubber (although awesome) is probably breaking down structurally.
If it's a top loader it could be oil from the transmission. I'm not that familiar with F&P machines but i have top loaders in my laundromat that can do this and i suspect most are capable. Likely you could identify them as oil spots though. They do not leave lines. Hope this helps. I could probably tell you more if i had the full model number that is on the machine (usually on the inside of the lid or door or the back along the top.)
Posted on Jan 23, 2013
SearsTechToo
  • 261 Answers
SOURCE: WHIRLPOOL ULTIMATE CARE II MAKES YELLOW BROWN STAINS ON LIGHT COLOR CLOTHES
Grease will not come from the interior of the washer, as the machine ages build up deposits under the basket and it is oily, greasy and full of mildew. If can get a spanner wrench from a appliance parts house and remove the basket you will see on machines older than three years a build up starting. I pulled 15 lbs from a 25 year old machine and I had to go get sick outside, it was bad.
Posted on Oct 06, 2008
vanni7
  • 163 Answers
SOURCE: Brown stains from wash machine
Hi!!! Your tub inner seal is worn off its a seal which protects the inner tub fron the transmission..Need a new tub seal..Good luckk..
Posted on Jan 03, 2009
SOURCE: My Washing machine stains clothes;
I've had this problem for many months now.  Even when it ruined my favorite tops & jeans, I couldn't get myself to let go of them... Good thing though because I have found a solution!  Make a paste using cream of tartar and hydrogen peroxide.  Generously spread the paste over the stains and let sit for about 5 minutes.  Boil enough water to fully immerse the stained garment in.  While waiting for the water to boil, figure out a way to wrap/roll the garment so that the paste doesn't come off when put into the water.  You want the paste to melt onto the stain while in the hot water.  After wrapping/rolling the garment, secure it with string or thread (anything that won't melt) that doesn't have color, just in case it bleeds.  After the water has come to a full boil, immerse the garment into the hot water and let it soak.  After about 15 minutes, remove the garment from the water.  The water should still be very hot, so I use cooking tongs to get it out.  Let the garment cool down to room temperature while still rolled up.  After it has fully cooled, unwrap the garment.  There should be very little or none of the paste left on the stain.  If there is still a great deal of paste, you may want to soak it again until the paste melts a bit more.  Once the paste is gone, rinse of the garment and it should be clean & stain free.  :o)
Posted on May 03, 2009
honeymokey
  • 3113 Answers
SOURCE: washer whining when washing and spinning leaving brown stains on clothes
Turn water off. Remove hoses and clean the rust out of the strainers at hose end. If they are clogged they will sound funny when water goes through them.
Posted on May 16, 2009
I had the same problem, and it turns out that it is NOT the seal. It is the liquid fabric softener. The fabric softener dispenser needs to be cleaned periodically or it gets a black waxy, goopy, build up. It is this same buildup that ends up staining your clothes with dark brown or black stains. Just remove the dispenser and wash it our very well and the problem will be gone.
Posted on Apr 12, 2010
Brown stains in the drum of my whirlpool dryer
Apparently a common problem with 4-5 year old Kenmore and Whirlpool dryers. The paint is rubbed off the back panel by the felt seal attached to the rotating drum. The bare metal gets rusty from the damp clothes. The rust is rubbed off by the felt seal. The entire felt seal will turn brown. The stains are transfered to the clothes. The rust stains can generally be removed by additional cleaning.
I'm going to replace the felt seal on the drum, clean the rust off the back panel and see how long it lasts. Seal w/ adhesive is $30-40.
Some have suggested painting the back panel, but i don't think fresh paint is going to last long. The original paint was probably electrostatically applied and maybe baked on.
Nov 05, 2009 | Dryers
Starting to leave brown oily like stain on clothes
The first place that I'd check would be the small metal screens inside the openings on the water inlet valve. They can get really rusted, epecially in areas with hard water, so I would recommend removing the water supply hoses and take a gander at the screens. They can sometimes release the iron oxide into the wash water and cause brown stains or blotches on clothing. Hope this helped and best wishes.
Sep 07, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Duet Washer/Dryer get brown streaks on clothing
The brown stains are likely coming from the felt drum seal. The OEM adhesive is tar based - and after time and use - breaks down.
You'll need a new felt seal - and the adhesive that is used should be silicone based... eliminating the brown streaks.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Brown stains on white clothes in front loading washer
Jun 12, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
My Kenmore heavy duty tumble washer is leaving a light brown stain on white or light clothes. It is likely staining dark clothes but of course they are too dark to see a light stain. It is definitely...
Jun 06, 2009 | Kenmore 44102 Front Load Washer
I have been getting brown stains in the shape of a line on items of clothing washed in my Whirlpool duet washer. I can not get these stains out with anything and they are ruining numerous items of...
I have been getting brown stains in the shape of a line on items of clothing washed in my Whirlpool duet washer. I can not get these stains out with anything and they are ruining numerous items of clothing. I have no idea what is causing them - I have manually cleaned the inside of the washer. same thing here. I have been having this problem for a few weeks, cant wash anything white without ruining it.
Apr 23, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Jan 03, 2009 | Washing Machines
My Washing machine stains clothes; they come out with brown rusty stains. Otherwise the washing machine works fine. my washing machine is lessthen three years old and always give brown stains in white...
Oct 25, 2008 | Washing Machines
Sep 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool duet front loader washer/dryer
It is not the dryer causing the problem. We get the brown streaks on our white clothes before putting them in the dryer. I have ruined more white clothes over the past six months with this Duet washing machine!!! We also don't use bleach so I don't think it is the HE/Clorox combo that somebody mentioned earlier. Anybody know what exactly is causing this yet... before I throught the moldy stain causing Whirlpool duet out?
Aug 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
22 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
