Question about Home
I need to re-plumb the tub I just bought, its a hydro swirl that was re plumbed and screwed up. any pictures?
It looks like the tub had been in a surround.
    Spread the Word:
    An expert who has shared 5 answers on their Facebook wall.
  • 52 Answers
What exactly is messed up with the plumbing? We have a diagram of how tubs are usually plumbed we can fax you.
Rod
www.uspartscenter.com
Posted on Jan 31, 2013
  • Sean Sayed Feb 27, 2013
    Hi, would you have plumbing diagram for Jacuzzi corner tub. Thanks, Sean
brainyass
  • 242 Answers
SOURCE: How can I unclog plumbing in whirlpool tub used to clean dogs?
Depending on how mechanically inclined you are, take apart the tub and clean everything out. No easy task, I know, but who want old dog hair floating around? That will be your best bet.
Posted on Oct 24, 2008
  • 63 Answers
SOURCE: plumbing in fridge/freezer
That is the water inlet for the ice maker. It is 1/4 inch diameter and will need to connect to a valve of that size with 1/4 inch plastic or copper tubing.
Please rate if this helps-
Posted on Mar 23, 2009
  • 123 Answers
SOURCE: just bought a house with a hydro quip cs 6000
Hey Mike; what is it you would like to know about your hot tub?
Thx
Ken
Posted on Sep 01, 2009
slick fixer
  • 7 Answers
SOURCE: I have an aqualux whirlpool tub w/ cracked jet housing
yes i can do it call me 301 659 9968 rick
Posted on Oct 31, 2009
  • 105 Answers
SOURCE: just hooked tub up and it won't work
i've been on board during many of these initial start-ups, there is a little red re-set switch on the motor somewhere (you'll see it), it is usually tripped, just push it back in, you'll usually hear it click when you push it in .
Posted on Jan 03, 2010
I need to find a service man in the Seattle area to get my tub working. It has power but won't come on.
then look in a phone book for a plumber . I am sure there are more than 1
Feb 11, 2016 | Home
Replacing hot tub flow switch
Depending on what type of flow switch is in the plumbing will determine how it is changed out.
These are usually glued into the plumbing line with no unions or gate valve on either side of it,
If this is the case for you tub then you will need to drain the tub or isolate it from the water so you can plumb in a new flow switch.
Rod
US Parts Center
888-521-6183
Feb 15, 2013 | Qca Spas Pool & Spa
A CRANE WHIRLPOOL TUB BOUGHT FROM MENARD'S IN THE 1990'S HAS TWO CONTROL KNOBS FOR AIR AS WELL AS AN ON/OFF BUTTON. WHERE CAN I FIND A REPLACEMENT SEAT THAT THE AIR CONTROL KNOB SCREWS INTO A
What you are looking for is called the wall fitting for the air control knob.
If you can email me a picture of the knob, topside and underside I can tell you who made it and if there are parts for it.
send your pictures to: sales@uspartscenter.com
Rod
US Parts Center
888-521-6183
Feb 10, 2013 | Crane & Co Crane Plumbing 2430W Whirlpool...
Replace handle with different style
One of those big-box home suppliers might have something you can use or can order something. Likewise, a plumbing supplier could have just what you are looking for. Moen is a common brand which makes compatibility more likely
Feb 09, 2013 | Moen T999P Chateau Two-Handle Low Arc...
Just bought a home with a swirl - away tub need to clean out and I am not sure how to remove the jets from the inside of the tub. I need to clean them..
Check with your local plumbing supply shop, there are special self cleaning chemicals to run thru the system, also can be purchased on line.
May 19, 2011 | Whirlpool Home
I need a replacement jet for this tub. Where can I find the part?
Have you considered your looking for a plumbing part
for a common name brand?
Go to a plumbing supply where the pros go
Feb 01, 2011 | American Standard Evolution 2425V-LHO.020...
Basement plumbing. I want to put in a basement bathroom and my plumbing drain from the house is 4' from the basement wall. I need to put in a sewer basket and venting. any diagrams to follow?
My suggestion is to build up the floor where the tub will be maybe 12" above original floor and u can make a couple steps up to the tub the whole length of tub
Dec 10, 2010 | Home
There is a leak on my 4 person Dream Maker hot tub at the pumps connection to the other plumbing. I'm wondering if it needs a new gasket or what? The leak is taking out a couple inches every couple days....
  • I used to teach plumbing.
  • I honestly have not worked on This unit.
  • I would like to SUGGEST using some Plumbers Tape--not puddy to start with. This might fix it w/o a new gasket.
  • If That Does not fix it, go to your Local Plumers supply store (I would NOT go to home depot or lowes; I would go to the old fashioned shop) and get the gasket for the pump, as you are pondering about.
May 11, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Handle loose. I got to put in hard to turn the water on. look like miss a screw
This valve needs to be taken apart and lubricated with pure silicon grease (available at plumbing or builder's supply houses.) Good luck.
Nov 30, 2009 | Peerless Industries Peerless& Single...
I am installing a 6ft long Swirl Away Roma II model whirlpool tub
Here is the link to where you can find the info you are requesting. If you can't find it on this page link contact the company directly. They will be able to get you the info you are looking for.
http://www.mansfieldplumbing.com/v3/support01-r03.html
Mansfield Plumbing is the manufacturer for your product.
Apr 10, 2009 | Home
Home Logo
272 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
