Question about Canon Cameras
Lens error restart camera canon SX10IS
Canon SX10 IS Lens Error-restart Camera message. Happening more and more frequently. lens also does a little dance in and out before showing this message and closing down. Sometimes it doesn't close down but remains with the lens extended and sometimes won't turn back on again.
  • Canon Master
  • 4,738 Answers
Here are some troubleshooting steps for a lens error. And here's a video summary of those steps:
Posted on Jan 23, 2013
SOURCE: Canon PowerShot SD630 LENS WONT CLOSE,LENS ERROR RESTART CAMERA
I have the same problem. How do you restart the camera. I have pulled the battery and SD card, but can't get to a menu screen to restart to camera.
Posted on Apr 22, 2008
camerawes
  • 36 Answers
SOURCE: Canon SD 850 says lens error,
There could be a number of reasons for the lens error. ie. . sand in camera, impact damage etc. Typically the lens can be dissasembled and repaired by a competent camera repair technician. If you are certain that you did not damage the camera in any way I would send it back to canon for a warranty repair. If you however think you could have damaged it you are probably looking at around $100 to repair the camera. Hope this helps!
Posted on Jun 10, 2008
SOURCE: Lens Error - Restart Camera : Lens remains in extended position.
Hey,
I had the same problem as everyone else regarding the error that would pop up stating that there was a lens error. I had the camera in my pocket when I went to a hockey game, pulled it out to take a picture, and it didn't work. Needless to say I was pissed because I expected far more from Canon. I was just about to go and buy a new camera, and figured that I would try to troubleshoot the problem and stumbled upon this site. Someone suggested turning the camera on and off while twisting the lens, so I figured it couldn't hurt to try it.
Before trying this, my lens would not retract all the way, the cover would not shut, the image was blurry, and I could not zoom in at all or the camera would show the error.
So, I tried the "twisting" solution, and it wasn't working, but I think I was being too delicate with it. I put a little more pressure on it and gave it a good twist. There was a clicking noise as others have said, but in the end, it worked after about 2 or 3 minutes of messing with it. No my lens goes down, the cover shuts and its clear as a bell. Not sure if this is a recurring problem as it appears to be a common problem, I fully suggest trying this before you send it off to get it fixed for a ridiculous amount of money.
Best of luck
Posted on Jan 30, 2009
ginko
  • 19396 Answers
SOURCE: Lens error, restart camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Posted on Jul 05, 2009
  • 164 Answers
SOURCE: Canon PowerShot SX100 IS Lens Stuck
If the lens does not extend/retract when the camera is powered on, then lens assembly is damaged.
Unfortunately, such Canon SX100 (and the SX110 too) has a very fragile lens assembly, and it's damaged very easily. Most of the times the internal gears, the plastic post guides and the motor are damaged at the same time, so the only solution is to replace the whole lens assembly.
The lens replacement requires a qualified camera repair technician, unless you want to try in repair it yourself, which requires tools (scredrivers, soldering iron, desoldering tool, magnifier glass with light, etc).
Best regards,
Posted on Jul 22, 2009
Lens error.....restart camera. Tried over and over again. Nothing works. HELP!
Went to the beach yesterday, by the end of the night my camera gave me this error: "lens error, restart camera". The lens would no longer come out.
I figured sand got stuck within the lens, so I did the following:
1. Turn camera up-side-down (with lens facing down)
2. Gently tap the sides of the camera (to loosen particles in lens)
3. Turn camera on
4. The lens will eventually come out
5. Gently tap the sides of the lens
6. Turn camera off (continue tapping side of lens as it retracts)
I turned the camera on and off a couple of times to ensure I removed all sand particles from the camera.
Now the camera works...thank god....
thanks.
Apr 11, 2011 | Canon PowerShot SX10 IS Digital Camera
Got a lens error message and the camera turned off
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Aug 01, 2010 | Canon PowerShot SX10 IS Digital Camera
I have a canon Powershot A480. It keeps coming up with the faultLens Error Restart camera. How do I do this
Service & Support Issue: Camera displays "Lens error, restart camera" on the LCD monitor.
Solution: Possible solutions for a Lens Error message PowerShot A480.
The "E18" or "Lens" error message indicates an error that involves the lens unit or lens cover.
This error may appear where the lens is prevented from properly extending or retracting such as, for example, when pressure is applied to the lens or the area surrounding the lens while handling the camera. The error may also be displayed if the lens unit/camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera. Solution
Check the following when you operate the camera to avoid applying pressure to the lens and surrounding area:
  • Hold the camera so that your fingers do not touch the lens unit when you are shooting.
  • Make sure the camera is off before the camera is placed back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.
If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred. Please click here to set up service for your camera online.
Jul 25, 2010 | Canon PowerShot A480 Digital Camera
LENS ERROR, RESTART CAMERA...
CANON IXUS 561
Lens sometimes does not extend and error message 'lens error restart camera' appears when camera is turned on. This does not work without several tries and much button pressing. Problem is not caused by finger(s) in front of lens barrel.
May 20, 2010 | Canon PowerShot A560 Digital Camera
PowerShot SX10 IS Digital Camera: lens error please restart camera...
May 18, 2010 | Canon PowerShot SX10 IS Digital Camera
Camera displays "Lens erros, restart camera"
I had this happen to my camera. The lens has malfunctioned. You will have to buy a new camera, or they might possibly allow you to send the camera in for a fix, but there is nothing you should or can try.
Good Luck
Cheers
dmklunk122
Dec 24, 2009 | Canon PowerShot SX10 IS Digital Camera
Canon ixus 60 - lens error restart, restart camera
Dear God, It was like a comedy. I got on the whale boat, after having the Canon ixus 60 for 4 years. I've never had any error messages. The whales came 10 feet from the boat and twice raised their head, and no camera, just the beeping and the error message: lens error; restart camera. How do you restart the ixus 60 Canon digital camera, anyone? Please help!! Thanks Claire@klarity.org, Maui, Hawaii. Aloha!! & Mahalo.
Aug 26, 2009 | Canon Cameras
Canon PowerShot A420 reset lens error message
Not a solution, but a smilar problem with Canon Power shot A2000IS. Same lens error. reset camera message. Lens alos in fully open position.
Also in Costa Rica.
Any suggestions?
Neil
Jun 24, 2009 | Canon IXUS V2 Digital Camera
Apr 28, 2009 | Canon PowerShot SD850 IS Digital Camera
Cameras Logo
132 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
