Question about Lands Phones
I HAVE A UNIDEN CORDLESS PHONE AND THE WHEN I PUT THE HANDHELD ON THE BASE IT DOESN'T LIGHT UP TO CHARGE AND THE BASE SAYS E1 AND THE HANDHELD SAYS SEARCHING. HELP.
    Problem Solver:
  • 3 Answers
Probably the wrong phone on the wrong base
Posted on Jan 28, 2009
Uniden cordless phone not working
Yr battery is probably Shot. With these type of batteries they can fall over if they go below 25% charge for a length of time. The charger is not charging even though it says it is. If the phone is not to old then get a new battery and try again. cheers
Sep 06, 2012 | Uniden Cordless Phone
I have a Uniden D1680 cordelss phone system. Often times when talking for two minutes or so--it disconnects--this happens alot. Any suggestions???
UNIDEN is notorius for this. It could be losing connection to the base - are you moving around while on the phone? or it could be the battery is not holding a sufficient charge. You can move the base unit to see if that helps - maybe something is interfering with the signal. You can try taking the battery out of the phone and putting it back in. If that doesn't work then try swapping the phones and putting them in each others charger. If that doesn't work then try letting the battery die by leaving the phone off the charger for 24 hours and then recharging for 24 hours. Good Luck!
Jun 10, 2012 | Uniden Cordless Phone
Hi I have a Cordless Uniden Dect 6.0 and also another one that sitts on a bitter base. My problem is this: the cordless with the smaller base shows the message 'Searching' and wont do anything,...
Welcome to FixYa.
Reset the units/set up by doing the following:
  • Turn OFF all the HANDSETS.
  • Remove the batteries of the HANDSETS.
  • Unplug the power source of the BASE.
  • Unplug the phone line of the BASE.
  • Let it stay that way for 30 mins.
  • Insert the battery again of the HANDSETS, make sure it is charged properly.
  • Plug back the power source of the BASE.
  • Plug back the phone line to the BASE.
  • Register any handset that is unregistered (refer to manual).
Keep me posted.
Jas247
Sep 11, 2011 | Uniden D1680 Cordless Phone
How do i recharge my uniden phone battery
Phone's "Status Light" Not Illuminating or Battery Failing to Charge
  • 1.Check that the base unit's AC adapter is plugged into the both the base unit and electrical outlet firmly.
  • 2.Wipe the base unit's handset holder's connectors and the connectors on the bottom of the handset with a soft cloth/rag or pencil eraser to remove any loose dust and dirt from the metal connectors.
  • 3.Place the handset firmly in the base unit holder until the "Status Light" illuminates, indicating the battery is charging.
    4.Replace your Uniden cordless phone's battery, by purchasing a compatible battery from an electronic supply store or directly from Uniden. Turn your phone's handset unit over and remove its battery door. Lift the phone's battery pack up and gently unplug the battery's wire connector by pressing in on the connector's side and pulling the connector free from the phone's circuit board. Battery installation is the reverse of removal.
    Read more: Troubleshooting a Uniden Cordless Phone ' eHow.com http://www.ehow.com/how_7252483_troubleshooting-uniden-cordless-phone.html#ixzz1Wkmk0pxX
    Sep 02, 2011 | Uniden Cordless Phone
    Uniden cordless phone does not make good contact with the cradle
    Put some WD40 on a cloth and rub all the contacts to make sure they are clean. Also clean the inside surfaces of the cradle base to make sure the phone goes all the way in. Contacts are sometimes spring loaded, spray WD40 into them.
    Aug 27, 2017 | Uniden Cordless Phone
    Uniden XS 1210 cordless phone won't connect to base unit
    try connecting both phones via the base that is working and see if they recognize each other. Let me know if that works.
    Jul 21, 2009 | Uniden Cordless Phone
    After 6 weeks, phone is dead
    still warrentty time so contact ur uniden cordless phone dealer
    Jul 19, 2009 | Uniden Cordless Phone
    E1 displays on base unit uniden wdect 3355
    THATS AN ERROR MESSAGE, BASE IS NOT GOING TO WORK ITS SHOT.
    Oct 27, 2008 | Uniden 2.4 GHz Cordless Phone System
    UNIDEN 5.8 GHZ CORDLESS PHONES
    Registering Handsets to the Base
    Whichever handset you choose to charge in the base is automatically
    registered to the base. Any additional handsets must also be registered to
    the base before you can use them.
    Be sure both handsets are fully charged.
    One at a time, place each handset in the base. The charge/in use LED on
    the base begins to flash, indicating the base is registering the handset.
    Wait for at least five seconds, then pick up the handset and press
    [talk/flash]. If the display shows TALK, the handset is registered. If not,
    place the handset in the base to try again.
    Press [end] and continue with the next handset.
    Note:
    Once both handsets are registered, it doesn’t matter which
    handset is placed in the base or the charger.
    When you charge the handsets, Caller
    ID summary screen and the name of
    the handset appears.
    This can be find from uniden website.
    http://www.uniden.com/pdf/DXAI4588-2om.pdf
    Oct 17, 2007 | Uniden TRU8885-3HS Digital Cordless Phone
    Lands Phones Logo
    361 people viewed this question
    Top Lands Phones Experts
    Computer Repairing
    Computer Repairing
    Are you a Lands Phone Expert? Answer questions, earn points and help others
