Home | Philips | Magnavox 27MS343S 27" TV | I need a cord I need for...
Philips Magnavox 27MS343S 27" TV
Problem for Philips Magnavox 27MS343S 27" TV
I need a cord I need for an observation cam from magnavox
By styx_stonz on Jan 28, 2009
I have an observation camera from Magnavox, model # mc3511, serial # 72706839. I need to purchase the cord for this equiptment going from the monitor to the back of the camera itself. Would you please direct me to the correct entity to acclomplish this. Thank you inadvance for your assistance.
Same Problem
Mar 24, 2009
-   i have the camera but can not connect to the monitor.... what will i need to have this connect-   Guest
Feb 08, 2009
-   need cords for magnavov mc3511 observation cameras-   Guest
Solution #1
posted on Nov 04, 2009
Not Rated)
amonster
Rank: Apprentice
Rating: 0%, 0 votes
Strange, I have the opposite problem, I have the cord and camera, but no monitor. I found the following fix below to make this camera hook up to any tv or monitor, but it's greek to me. It may help you though! Or, if you can translate these instructions for me to hook up mine, I'l happily GIVE you my cord!
"The DC power was sent up the coax and the video is AC coupled and sent back down. If you open the
camera and trace the wire from the center pin of the UHF connector, it will lead to an inductor
and a large value capacitor. The video is coupled through the capacitor, which blocked the DC
power from the video output amp. The inductor (coil) blocks the video from getting back into the
power section.
Cut the inductor loose from the center wire of the connector. Put well filtered +12 VDC at 500
mA (1/2 amp) or greater into the inductor at this point while running a video cable from the jack
to a video monitor or to the video input of your home VCR. Then you can see the video on your TV.
Power return is to the ground of the connector or any other convenient grounding node.
Was this helpful?
Yes
No
Popular Solutions for Philips Magnavox 27MS343S 27"
Questions and Unsolved Problems for Philips Magnavox 27MS343S 27"
Do you recommend Philips Magnavox 27MS343S 27" TV?
Answer
Answer
I have to reprogram cable every time I turn the tv on. How do I keep the setting?
Answer
I have a Magnavox TV that I am trying to hook up a General Electric 9-7785 VHS Player and a... (More)
Answer
I have a DVD/Vhs serial#U40699379 mod.#mwd2206. The remote is lost. Can I get another and if so what... (More)
Answer
remote doesn't work, wont turn tv on and can't change the source.
Answer
We have a small flat screen that will not come on all the time when we use the remote or the power... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Philips Magnavox 27MS343S 27"...:
Top Standard Television Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Standard Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
