Question about HEC Group Computers & Internet
HEC rapter schematic diagram - HEC Group Computers & Internet
Dennis
Posted on Apr 24, 2014
2 Suggested Answers
freetek
  • 5568 Answers
SOURCE: HEC-250BR SCHEMATIC
This page seems to contain all the info you need but it is unusual that the supply does not have a chart defining lead colors and output capabilities.
http://www.wikihow.com/Convert-a-Computer-ATX-Power-Supply-to-a-Lab-Power-Supply
Posted on Sep 19, 2008
Need the pin to pin wiring schematics for this model of motorcycle?
    More images for 1990 Kawasaki 650R wiring schematic
    Kawasaki Motorcycle Wiring Diagrams - ClassicCycles.org
    www.classiccycles.org/1852/597943.html
    Kawasaki Motorcycle Electrical Wiring Diagram Schematics. ... Kawasaki GPZ600 GPZ 600 Electrical Wiring Harness Diagram Schematic 1988 to 1990 HERE ...Kawasaki KZ650 Z650 KZ Z 650 B Electrical Wiring Harness Diagram Schematic ...
    Owner Center - Kawasaki
Jan 21, 2016 | Motorcycles
Hec 1050w
oh hec its a hec
have you cleaned the filter
Feb 03, 2014 | Washing Machines
1 need a manual for my hec 1050 washer
I'm so sorry but this forum is not able, nor in a position, to supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
Also members on Fixya are not 'affiliated' to, or representative of, any manufacturer at all, just using their experience gained probably over many years.
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Jul 24, 2011 | Washing Machines
2000 ford f150 change computer from junk yard , well not start now ,but showing theft light ,do I have to get this thing flashed
The HEC ( hybird Electronic Cluster ) has a PCM ID stored in it, that needs to be cleared from the old one you had, so the new one can be re-learned.
The HEC sends the valid key tag with the PCM_ID configured in the HEC to the PCM for comparison to know if the start enable should be valid or invalid
This is so someone cannot take a cluster, ignition key cylinder and the PATS keys configured in the HEC, and put it into a truck, to make it start. Takes a bit of programming to get it to work.
Going to need someone to erase the PCM_ID parameter in the HEC to make the truck not think it is being stolen ( good news, it works as advertised ).
Feb 05, 2011 | 2000 Ford F150 Flareside SuperCab
98 lincoln town car wont start, the theft protection is activated
theft protection rsets itself. I have never seen a PCM go bad. Some just need a reflash which costs much, much less. You can get a used PCM if you really think you need one, at car-part.com. Page with asterisk is lowest price.
here's some info on antitheft. What's your red light doing on the dash when you turn on the key or try to start the car?
The passive anti-theft system (PATS) also contains the following components:
  • Theft indicator.
  • Encoded ignition key.
  • Passive anti-theft transceiver module.
  • Hybrid electronic cluster (HEC).
  • Powertrain control module.
  • J1850 communication network.
  • Lighting control module (LCM).
The passive anti-theft system (PATS) uses radio frequency identification technology to deter a driveaway theft. Passive means that it does not require any activity from the user. This system is known as SecuriLock® in North America, Safeguard® in the U.K., and PATS in Continental Europe. This information can be found in customer literature such as the Owner's Manual.
PATS uses a specially encoded ignition key. Each encoded ignition key contains a permanently installed electronic device called a transponder. Each transponder contains a unique electronic identification code out of over 72 million billion combinations.
Each encoded ignition key must be programmed into a vehicle's hybrid electronic cluster (HEC) before it can be used to start the engine. There are special diagnostic service procedures outlined in the workshop manual that must be performed if the encoded ignition keys need to be replaced.
The encoded key is larger than a traditional ignition key. The key does not require batteries and should last the life of the vehicle.
The transceiver module communicates with the encoded ignition key. This module is located behind the steering column shroud, and contains an antenna connected to a small electronic module. During each vehicle start sequence, the transceiver module reads the encoded ignition key identification code and sends the data to the HEC.
The control functions are contained in the HEC. This module performs all of the PATS functions, such as receiving the identification code from the encoded ignition key and controlling engine enable. The HEC initiates the key interrogation sequence when the vehicle ignition switch is turned to RUN or START.
PATS uses the powertrain control module (PCM) to enable or disable the engine. The HEC communicates with PCM over the J1850 network in order to enable engine operation. The HEC and the PCM use sophisticated messages in order to prevent a theft. The HEC communicates with the lighting control module (LCM), which controls the theft indicator.The HEC and the PCM share security data when first installed together that makes them a matched pair. After this security data sharing, these modules will not function in other vehicles. The shared PCM ID is remembered even if the battery is disconnected. The HEC also stores the vehicle's key identification code even if the battery is disconnected. There are special diagnostic workshop procedures outlined in this service manual that may be performed if either the HEC or the PCM needs replacement.
All elements of PATS must be functional before the engine is allowed to start. If any of the components are not working properly, the vehicle will not start.
PATS uses a visual theft indicator. This indicator will prove out for three seconds when the ignition switch is turned to RUN or START under normal operation. If there is a PATS problem, this indictor will either flash rapidly or glow steadily (more than three seconds) when the ignition switch is turned to RUN or START. PATS also "blips" the theft indicator every two seconds at ignition OFF to act as a visual theft deterrent.
PATS differs from the perimeter anti-theft system in that PATS enables and disables the engine from starting. If equipped, the perimeter anti-theft system protects the perimeter of the vehicle (doors, hood, and trunk) and sounds an alarm.
Jun 05, 2009 | 1996 Lincoln Town Car
Need physical dimensions of HEC HP585D 585W ORION HP585D ATX
No, given your old PSU's dimensions the HEC PSU would be too large. It sounds like you have a micro-ATX case.
Apr 06, 2009 | HP HEC HP585D 585W ORION HP585D ATX 12V...
HEC-250BR SCHEMATIC
Sep 07, 2008 | Computers & Internet
Computers & Internet Logo
63 people viewed this question
Top HEC Group Computers & Internet Experts
David Payne
David Payne
Are you a HEC Group Computer and Internet Expert? Answer questions, earn points and help others
