Question about Kenmore 12502 Top Load Washer
Kenmore 12502100 Need to find the inlet valve part number so I can order a new one.
5 Suggested Answers
catriver
  • 878 Answers
SOURCE: Same Problem as Carmal
I believe you already have it Susan...Catriver..
Posted on Nov 26, 2006
rpbuice
  • 161 Answers
SOURCE: Kenmore 80 series model #110.26882503 fills slowly
Yes, the only other thing I would do and you may have done this is to put the hose directly over in the washer tub and turn the water on to check the flow. If that's good then replace the water valve.
Posted on Jan 08, 2009
jsrock516
  • 5911 Answers
SOURCE: kenmore 90 series need to replace the inlet valve
This is actually a simple repair that the average Do-It-Yourselfer can perform with just a little guidance. The following link explains all the steps necessary to replace a water inlet valve on a Kenmore top loader:
http://www.fixya.com/support/r600647-replacing_water_inlet_valve_kenmore
If you have questions along the way, please let me know. A replacement valve can be purchased online at searspartsdirect.com, appliancepartspros.com, repairclinic.com, or pcappliancerepair.com. All these sites offer competitive pricing and excellent service, so shop all of them for the best price. Use your model number for your search criteria. If you do not wish to order on line, use the part number found at the sears or appliancepartpros website and go to your nearest appliance parts retailer. This is a part that is commonly carried as part of the in store inventory. I hope this helps you.
Posted on May 24, 2009
  • 1937 Answers
SOURCE: Kenmore 80 series Model 110.28812790 - water leak inside tub
It's quite possible. First see the Sears parts list for your washer with diagrams of all major parts.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=+110.28812790&pathTaken=partSearch
Then see the Whirlpool / Kenmore Service manual for these washers and check the troubleshooting section.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Posted on Mar 27, 2010
Testimonial: "Thanks! Very helpful."
Need a part number for the inlet valves Y splitter I have a Kenmore side by side. I found the part on the Kenmore drawing but it doesnt have a part number. The Sears "Chat with Me" guy couldnt find it...
Without the model number for the unit, it is hard to tell but my bet is, the part you need is part of the whole inlet line. You need to order that tubing to get the part.
Nov 04, 2013 | Refrigerators
Leaking water all time,even when not in use
The problem here is the inlet valve, It has a piece of calcium stuck in the valve. The way to fix this would be replace the valve. Since you did not provide a model number I can't give you the part number. Click HERE to order appliance parts.
If you have any additional questions please feel free to ask.
Nov 17, 2010 | Kenmore Washing Machines
My washer overflows. it wont stop putting water
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (110.########) and you'll see a list of major sub-components with diagrams and parts.
(The 110 means that it was manufactured by Whirlpool, you also need to enter the 8 digit model number)
Also see the Whirlpool / Kenmore Service Manual for these washers.
It has testing procedures as well as a good description of how the washer works.
It sounds like a defective water level switch or water inlet valve.
See the following for how to release the console and cabinet on these machines in order to get to the switch for testing.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
Basically, what happens is:
When the washer is turned on, the water inlet switch is closed allowing water to flow thru the inlet valve. When it senses that the machine is to the level selected by the water level dial, the switch opens shutting the inlet valves.
If the switch or valve is defective, water will continue to enter the machine.
The Whirlpool Service Manual has testing procedures (basis continuity tests with a multimeter) for both the switch and valve.
May 10, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore washer fills with hot and cold water on but does not stop unless I shut the hot water off at the spigot, cold shut off fine.
More than likely, this is caused by a bad hot water solenoid on the water inlet valve. You will need to replace the valve in order to correct the problem. The following link explains how:
http://www.fixya.com/support/r3575881-replacing_water_inlet_valve_on_whirlpool
This is a simple and inexpensive repair. The average cost of a new inlet valve is about $30-$35.
Replacement parts (if required) can be purchased at any of the following web sites:
repairclinic.com
If you have any questions, please let me know. I hope this helps you.
Feb 25, 2010 | Kenmore 22422 Top Load Washer
Kenmore Trio Bottom mount Freezer - water inlet
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} PARTS
http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
http://www.appliancepartspros.com/partsearch/
http://appliancejunk.com/forums/
model number
Your model number is needed for more information.
It's usually stamped on a small tag in a visible location on your appliance.
http://www.appliancepartspros.com/modelnumber_locator.aspx
Jan 26, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
I need to reinstall awater inlet valve on my
Parts & Accessories | Shop & Find Lawn & Garden, Appliance Parts at Sears PartsDirect | SearsPartsDirect.com go here,put your model number in and hopefully this will help you,next time you need help send the model number,good luck,just take off one line at a time and install it into the new valve,the lines are different sizes and the solenoids are colored so it's kind of hard to do this wrong,also there should be instructions with the vavle
Jan 10, 2010 | Kenmore 22.0 cu. ft. Side-By-Side...
Kenmore 90 series need to replace the inlet valve
May 24, 2009 | Kenmore 24032\24036 Top Load Washer
Cold water good for a few minutes then slows to a trickle. Shut off for a few hours and cold water good again for a few minutes. Inlets are clear. Is this normal behaviour for a dying valve?
Yes, it will fail soon. it is beat to go ahead a order a new inlet valve assembly asap. the pressure sensors that are housed in the valve assembly are failing.
May 22, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Water inlet valve Kenmore dishwasher
Okay handy Mike,
First of all, is this a new dishwasher? Or, is it a used one? The reason I ask is because there should be a warranty with a new appliance and you should not have to worry, or have to pay for, any repairs.
The problem you are experiencing could very well be a water inlet valve problem (good assessment), but may also be something more simple. The dishwasher has a float inside the tub that is supposed to shut the water off, when it reaches the appropriate fill level. Check the float to make sure it moves up and down and that you can hear the switch "clicking". Sometimes small items get stuck under the float and will keep in the up (or shut off position).
For some helpful part locator drawings refer to searspartsdirect.com and type in your model number. An illustration of the water inlet valve can be found under the "Frame" heading in the next page as item number 24 (part number 154195301). The float and float switch can be found under the "Tub" heading as items number 13 (part number 154144301) and 24 (part number 5300809863), respectively.
If you require further assistance, please let me know. I hope its something simple and you don't require parts. But, if you do, you know where you can get them. If you do not wish to order on line, use the part numbers provided and go to your nearest appliance parts retailer. I hope this helps you. Good Luck.
Jeff
Jul 09, 2008 | Kenmore 22422 Top Load Washer
Kenmore Elite Quiet Pak 1 Model No.110.26942503
yea if valve is leaking into machine when not on youll need to replace the valve. part number for the inlet valve 3979346 . you can find a diagram as well as a part list at sears.com.
http://www.searspartsdirect.com/partsdirect/retrieveModelActionHome!retrieve.action;jsessionid=UFaeD4IGtGIcYFtrZmj97w**.shcapp3205?modelNumber=110.26942503&pop=flush
Mar 25, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore 12502 Top Load Washer Logo
32 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
