Question about Blazer Es1000 Angled Head Butane Micro Torch Red
Manual for es 1000 micro torch
Manual for es 1000micro torch
I have a small pencil torch its not flaming right.not torching just a flame
Too much gas! Turn it down and check that nothing is blocking the airways.
Mar 23, 2015 | Blazer Pencil Micro Torch PT 4000
How do I refill the blazer es-1000
On the Bottom there is a Insert and you used the Pressurized Can to fill it
Nov 07, 2014 | Blazer Es1000 Angled Head Butane Micro...
Micro torch
to little air - air holes blocked up
Feb 23, 2014 | Omega Bernzomatic Corporation ST2200T...
Hy! my question is : Is the es-1000 model still available and if not what model is replacing it. Thanks, Robert
Model ES-1000 has been discontinued for a few years now. The replacement heads were also discontinued.
Unfortunately, Remington did not make a similar model to replacethe ES-1000.
The flat, slot style type head is what made the ES-1000 very popular with many users. Unfortunately, there are no manufacturers who make a flat, slot head shaver at this time.
Aug 15, 2011 | Remington ES-1000 Electric Shaver
What razor replaced the Remingtno ES1000?
Remington replaced the ES-1000 with the HGX-1. However, the HGX-1 really is not the same design at all. There is no real replacement for the flat head style shaver. No one currently manufacturs a flat head style shaver like the ES-1000
Aug 07, 2010 | Remington ES-1000 Electric Shaver
How can you manually open the Kitchen Aid KIRD861HSS?
By removing the decorative cover plate you somewhat expose the units inner workings. Carefully, insert a small sharp object into the unit at the point in which the micro-switch(es) are exposed. The micro-switch(es) will appear as small little plastic tabs that are poking out. While simultaneously depressing the power button, insert the sharp object into the micro-switch(es) closing the circuit. The down draft will raise enough to the point in which you can re-seat or install the filter thus making it operational.
Jan 27, 2010 | KitchenAid KIRD861HSS Kitchen Hood
Blazer Es1000 Angled Head Butane Micro Torch Red Logo
Top Blazer Science & Laboratory Experts
Gareth Cockram
Gareth Cockram
William McMath
ray gallant
Are you a Blazer Science and Laboratory Expert? Answer questions, earn points and help others
