Question about Stairmaster Stepmill 7000 Pt
Stepmill 7000 wont regulate speed
Stairs turn faster and faster. The led field light goes off when stairs are started
  • 3 more comments
  • joelroberts3 Jan 28, 2009
    Stepmill 7000 seems to be skipping. Changing the wall socket as suggested in earlier post is not the solution.
    after removing the brushes they appeared to be ok, they were reinstalled. We tried to operate again and machine slowly started to grab and regulate speed after approx. 2 min. it worked fine for 10 min. or so although the field led light was not completely lit it was flickering. Now the light has gone out and is spinning freely again
    all wires seem to be secure, no burns or corrosion on circuit board
    this machine has had very little use, power transformer was replaced recently I tested machine to see that it would turn on but did not put it under a load until today transformer seems to be aftermarket what are the chances its not supplying correct voltage
  • 2,071 Answers
Just clean and rebuild or simply resoldered all parts joints in the circuit board so the parts connectivity renew so it function very well and most of all, if you see a capacitor there replaced it all. Maybe that is the caused of the stepmill not to regulate or function normally.The function of the capacitor is to hold the voltage if the capacitor is leaky already it will not hold the voltages causing the machine to function abnormally .I experienced like this capacitor problem when I repair an escalator before,its function abnormally its cannot be regulated.I did the procedure i said above and replaced all the capacitor its works find its run normally.
Hope it may help you;
Regards;
VOTIT
Posted on Jan 28, 2009
    President:
  • 1,952 Answers
Change the led light
  • mohammed marika thambi
    mohammed marika thambi Jan 28, 2009
    The switching
    pulses from these power FETs are fed to a toroid transformer because,
    unlike your analog power supply, they switch at a very high switching
    frequency, 80 Khz? 100 Khz?...it matters not...it's high, so we need a
    high frequency transformer. High frequency toroid transformers at tiny
    little things, not big honking 50/60 Hz beasts that drink copper. There
    are several output windings, maybe, like the one powering your computer
    where we need several output voltages (+5, -12, +12, -15, +15 or more in
    some). The IC's sensing circuit watches the highest load output that would
    vary the worst.
    change the regulater then tranfomer battaries
  • 11,896 Answers
Check the motor and gears. also check wiring there. also check power supply
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Your described problem could indicate a faulty speed controller. Additionally, the LEDs going off further indicates that the main board is fault. In most models, the speed controller is also in the main board.
This of course would require opening the unit, perform voltage measurements,determine faulty component and subsequent part(s) replacement. Further, a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron would be required. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings.Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Good luck and thank you for using FixYa.
  • 2 more comments
  • Louie  Role
    Louie Role Jan 28, 2009
    Another possibility is a loose connector or corroded/burnt wire/terminal.
  • Louie  Role
    Appreciate your postback/update.
    The symptoms described: "it worked fine for 10 min. or so although the field led light was not
    " points to an initially intermittent fault that develops into a full fault after a period of time. Since by design your unit makes use of a motor, then the most likely culprit is the controller of the motor. At different speeds, either the motor would be receiving varying voltages or different windings of the motor are used. Either way, it is the controller that selects what voltage or what winding receive power is in question. This could then be checked/monitored with the use of a DVM/VOM (voltmeter).
  • Louie  Role
    To my knowledge, a transformer would either supply correct voltage or none at all. There is no way for it to supply higher than specified. Not unless the replacement transformer is not the specified one.
  • Louie  Role
    A higher voltage would initiate a "domino effect", higher than required voltage from the transformer, higher voltage to the diodes/capacitors, higher input to the regulator; in all likelihood a fuse or circuit breaker would blow/trip.
    Genius:
  • 1,847 Answers
It seems issue with the regulator. 1st check it on a diff wall socket.
On idle machine -- power and field lights are lit, relay is NOT (relay board)
With everything that you have tested and the relay board testing okay, this sounds like the console is the problem.
Jan 02, 2014 | Stairmaster Stepmill 7000 Pt
Tip
Too Much Resistance on Stepmill
The first step in troubleshooting too much resistance or constant resistance begins with the lower board. You will want to first verify that the Field LED is lit on the lower board. As shown in the video, the Field LED is off initially, when the steps are engaged it lights up, after about 5 seconds the light should go off. If the Field LED stays lit during a workout or after a workout is completed, this is a sign that the console is faulty. There is constant power being supplied through the console keeping a full load and causing no change in resistance. If the Field LED remains lit, the console needs replaced.
Too Much Resistance Troubleshooting Video for Stairmaster Stepmill SM916
on Feb 11, 2015 | Stairmaster Stepmill 7000 Pt
Stairs won't speed up or slow down
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
You should start by verifying that your relay board is functioning properly. The following videos will help you through the troubleshooting of this issue.
Nov 15, 2013 | Stairmaster Stepmill 7000 Pt
Stepmill has no resistance when starting
First thing you'll want to do is check the alternator brushes. Here's a link to the different types offered for the Stairmaster 7000PT:
Repair Parts for Stairmaster Equipment Batteries Springs Belts Chains...
If the brushes look like they are in good condition you can also test the relay board. This link will take you to the procedures for checking the relay board:
Stairmaster Stepmill 7000PT Electronic Testing of Relay Board
Nov 06, 2012 | Stairmaster Stepmill 7000 Pt
My stepmill has no resistance on the steps. It goes full speed with out turning it on a program
you prob have bad alt. brushes. on the back of the alt. there is a small access panel where the brushes are located. they wear out over time and need to be replaced every yr or so
Aug 19, 2011 | Stairmaster Stepmill 7000 Pt
Stairmaster stepmill 7000pt all pwer is on but will not start the stairs
console could be defective try to diagnose it by entering diagnostic codes from your manual
also check the mechanical parts inside , a hinge rod could have slipped out and has pinned the entire stairs
Jan 14, 2011 | Stairmaster Stepmill 7000 Pt
Machine wont run computer screen is up but wont start the belt
do a diagnostic on console if possible . enter diagnostic codes from your manual
also check mechanical inside a hinge rod could have slipped out binding the entire stair system
Jan 13, 2011 | Stairmaster Stepmill 7000 Pt
When my wife uses stairmaster 7000 on level 20 the stairs barley move 118 pounds when I use level 20 it seems to be working properly 210 pounds
hi
just check the speed of unit if she goes faster than when she was on level 17-or 19 it is ok
if not calibrate the tension but i think it is always feels like this
let me know
Nov 22, 2010 | Stairmaster 7000PT Nautilus Stepmill
I have problem with master console of step mill 7000 pt stair master
If you have a Stairmaster Stepmill 7000PT that has an older style console with the red LEDs and you want to upgrade to the newer, console with the blue LCD; the parts necessary for this upgrade include the console and the console cable.
Stairmaster Stepmill 7000PT Console Upgrade
C40 Console Repair Video for Stairmaster Steppers
Oct 19, 2010 | Stairmaster Stepmill 7000 Pt
Check the blue wire to the alternator. Check all connections. the blue wire is the tach wire. no tach signal and you cant climb fast enough!
Jan 28, 2009 | Schwinn Wide Ride Pedal
Open Questions:
See all Stairmaster Stepmill 7000 Pt Questions
Stairmaster Stepmill 7000 Pt Logo
298 people viewed this question
Top Stairmaster Exercise & Fitness Experts
fordexpert
Craig Butler
Craig Butler
zr800o1le
zr800o1le
Level 1 Expert
Are you a Stairmaster Exercise and Fitnes Expert? Answer questions, earn points and help others
