Question about Haier CPN12XH9 Portable Air Conditioner
It keeps flashing stop and won't turn on ?
It says self draining and I have all that hooked up properly could it be full some how?
Start matsui washing machine
Check the washer drain hose for clogs.
Jun 19, 2017 | Washing Machines
What does this mean? My machine is very new & won't drain it won't go through a full cycle & won't spin properly now it's bleeping with this flashing up on it!
Turn off machine and check water waste filter to see if blocked should be at front at bottom of machine or at back,not sure this is the cure but hope it helps
Apr 06, 2013 | Washing Machines
My bush tv won't stop flashing
The tv need service. Contact any experienced service technician.
May 07, 2012 | Bush 1433GRN2 14" TV
Oven lite won't go off and when turn on self cleaning it says door
The door switch has gone bad. This will keep the oven light on and the self clean won't work because it thinks the door is open.
Dec 12, 2011 | KitchenAid KESC307 Electric Kitchen Range
The red l water full indicator light keeps flashing and won't reset. What do we do
Assuming you have drained the tank and replaced the drain plug. Turn the unit OFF and Unplug it for 10 minutes. Then plug the unit back in and turn the unit ON. During that 10 minute time out, the unit's electronics should have reset and reverted back to the original factory settings. At this point you can set the controls as you like.
Hope this helps you and thanks for choosing FixYa.
Jul 31, 2011 | Danby Heating & Cooling
Hi, I just purchased this used. It was working fine for one day, but now it won't turn on. Can u help? Haier CPN12XH9 12000 BTU Portable Air
If the water collection tank is full, it will not turn ON. Since you said the unit worked fine for one day and now it won't turn ON, more than likely, that's the problem. After draining the tank, the unit should reset itself and turn ON like it should.
The drain plug is on the rear of the unit, just above floor level. You can either drain it into a low sided pan or bowl that's capable of holding up yo a quart of water. O r roll the unit to a floor drain or outside to drain it. If you choose to drain it into a pan, turn the unit OFF & unplug it, before draining it.
I hope this helped you and thanks for choosing FixYa
Jul 25, 2011 | Haier CPN12XH9 Portable Air Conditioner
I have an LHD6594EBL dehumidifier that won't run and it keeps saying the bucket is full but the bucket is empty, we have a hose attached and don't use the bucket,
Sue, if you haven't noticed any water draining from the hose recently, it may be that the hose connection and tubing of the unit are clogged and the drained water pressure is causing the unit to show "Bucket Full." Also, if the bucket is not properly in place, whether you use the drain hose or not, it will cause the unit to stop functioning. You know how to correct that, so I won't go into detail on that issue.
To unclog the drain, you will need an 18" long, plastic Zip Tie or something similar (NO wire coat hangers though) that will fit into the hose connection. TURN THE UNIT OFF AND UNPLUG IT. Then carefully insert the Zip Tie and continue to push it in until you reach the bend in the tubing. You will have to carefully work it past this bend, until it either bottoms out or you run out of usable Zip Tie. Now, while rotating it, slowly pull it out and be prepared for some water to follow.
Hope this helped you troubleshoot and solve the problem.
Jun 01, 2011 | LG LHD659EBL Dehumidifier
Haier CPN12XH9 Portable Air Conditioner Logo
37 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Terry Hair
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
