Question about Acer TravelMate 2480-2968 Notebook
Acer Notebook 4330 No Power/No Charge
Notebook only about 1 month old no known damage, when plugged into AC there is no charging light/will not turn on(power light comes on solid for a few sec then goes back out again), Tried power reset sequence no results, took apart to check ac adapter connection, not a direct solder to board seems ok. Not the power pack, tried another same output parameters no result, tried that pack on my other laptop works fine. Stumped about where to check now. Thanks
I have problem with my acer travelmate 2480-2968. For some reason it will not charge or come on at all. The green light that is on the battery charger seems to work just fine, but it will not charge up. So I just brought a new battery for the computer and the battery had a lil energy to it so I use that battery and put it in the laptop and it power on just fine, but the same problem it will not stay charge. Can anyone tell me what the problem might be and how can I fix it. I can't send it back because I do not have a warranty on it. If there is anything i can do to make the battery stay charge please let me know. Thank you for you suggestion.
Posted on Mar 10, 2009
  • 32 Answers
If the Notebook is only 1 month old i suggest you bring it back and see if they will replace it. Most likely the problem (for how you have explained it) is that the DC power pin (inside the notebook) is either broken or not soldered to the mother board correctly.
Being only one month old this is probably a faulty pin or installation from the manufacturer so this should not be a problem for the place you got it from to replace.
If you do have problems I suggest contacting the manufacture immediately to see if they will replace it.
I hope this helped
Have a great day.
Posted on Jan 28, 2009
My acer aspire one wont charge where u connect plug
You should call on 1-800-585-2494 Toll Free on Acer and get your help for Acer.
Sep 08, 2014 | Acer Aspire One PC Notebook
OW TO GET MY ACET ASPRE ONE IT STOP BLACK SCHREEN NO POWER
Step by step troubleshooting.
Verify power outlet is good
Verify power adapter is good
verify connection to computer is good
fully charge battery
test
=======do this
Check power source, plug known good light into AC receptical.
If AC cord has connector to power block verify it is properly seated.
plug adapter into AC outlet
Verify Power is present at power connector with another similar computer or voltmeter. (12V to 20V)
When plugged into computer, charge (not power) indicator MUST light either red, amber, or green. If not, connector on computer may be broken.
leave overnight or until charge light is green
turn on normally.
most likely causes:
- loose connector
- broken wire from power adapter
- broken power plug on computer.
- anything else is probably beyond ur capabilities to fix.
Aug 10, 2014 | Acer Aspire One PC Notebook
Dell Inspiron 1100 won't turn on
unplug, take out battery then hold power button for 30 seconds then plug back in and turn on
if the3 laptap gos on without the battery you need a new battery
Jun 14, 2013 | Dell Inspiron 1100 Notebook
Samsung R480 Will not charge or turn on but indicator lights flash or stay on.
Swap out the ram one at a time testing to see if you can power up, making sure there is one in the memory slot at all times, if this works the piece in your hand is defective, no difference! the motherboard has major issues.
Jul 10, 2012 | Samsung R480 Notebook
When i charge my acer aspire the power button flashes
The DC jack in the laptop is showing early signs of intermittent issues, the jack is solded to the motherboard which sometimes breaks free over time, this is something that will eventually need to be addressed.
Mar 25, 2012 | Acer Aspire 5336-2283 Notebook
My Acer aspire 4935 is not recognizing the AC adapter. When ever I shutdown the system and connects the AC adapter, it works and the charging LED lights up. Once I press the power button to boot the...
Problem description:The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
When the laptop is turned on, the battery charge LED goes off even if the adapter is still plugged in.
Possible cause:1. AC power adapter failure.
2. Battery failure.
3. Broken/loose power jack.
4. Motherboard failure.
Possible troubleshooting steps and repair solution:1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
http://www.chargerbuy.com/replacement-acer-aspire-9400-ac-adapter-19v-3-42a.html
2. There is a slight chance that you have bad battery. Test the laptop with a know good battery and replace the faulty one if needed.
3. The battery charge problem could be related to the power jack. Maybe the jack is broken or not making good contact with the motherboard. It is necessary to remove the motherboard and take a closer look at the power jack. Resolder or replace the jack if needed.
4. If the power jack is in a good working shape and new power adapter with battery do not fix the problem, most likely you have a faulty motherboard. Replace the motherboard if needed.
Feb 09, 2011 | Acer Aspire 4730-4947 Notebook
Acer Aspire 7741Z - 4643 that is only 2 month old. It is plugged in, and recognizes that it is plugged in, but does NOT charge the battery. Please let me know what to do. Thanks, Not charging
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Your response is very much appreciated...
Feb 06, 2011 | Acer Aspire One PC Notebook
I have an HP Pavilion dv7-1130 Entertainment Laptop, and as of recently, when I try to turn it on, the lights around the keyboard power on and the fan runs, then the fan stops and the lights stay on. No...
With an extensive use of the notebook,
some times notebook would store some static charges which
indeed will stop the notebook from powering up or charging
the battery. The procedure to remove this static charges from
the notebook is known as power drain. Performing a power
drain procedure will not effect any personal data or delete
any pictures from the hard drive on your notebook.
I recommend you use Power Drain procedure by following these
steps:
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter.
5. Turn on the Notebook power.
Dec 12, 2010 | HP Pavilion dv7-1130us laptop
HP Compaq 6515b laptop: Diplay is blank, Few times it came back after some time, But now it is titally blank,
steps:
Dec 07, 2010 | HP Compaq 6515b Notebook
Acer Aspire 5738Z won't hold charge
Sorry. It seems that your battery is dead.
If your laptop is working fine on AC power only (with the battery disconnected), then your battery will need to be replaced.
Jun 16, 2010 | Acer Aspire Notebook
Acer TravelMate 2480-2968 Notebook Logo
302 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
