Question about Fisher and Paykel GWL11 Top Load Washer
Wont Spin my Machine has stopped Spinning altogther, when i start the machine at any point in wash cycle u can hear trying to start up but then just goes to beeping and 2 lights on the wash cycle, it drains and fills fine, and if u try and move the barrel itself it goes stright into beeping mode, i looked at the propellor underneath the pump and it spins fine with little resistance
  • 8 more comments
  • belinda egan Jul 24, 2007
    2 along the wash cycle, 2nd wash and rinse
  • belinda egan Jul 25, 2007
    sorry i got that wrong, its the first light and 2nd rinse light along wash process, now its not even wanting to fill, the water starts and stops over and over till it goes to the beep/light sequence again
  • ceiling Feb 18, 2008
    everything works except machine will not spin F & P 5& 6.5 machines smart drive.Pump OK ,power ok Seems as if there is a electronic brake on motor (not a solenoid ) which is not releasing to enable spin.
  • Anonymous Aug 13, 2008
    the washing machine fills up fine and drains fine just wont do the wash cycle and spin
  • Anonymous Mar 23, 2014
    My washing machine keeps beeping and would not start.
  • Anonymous Mar 25, 2014
    The cycle stops on spin and alarm starts to beep
  • Anonymous Mar 28, 2014
    Turned on washing machine it has 3 lights on 2 x washing cycle and 1 x first spin and it beeps every second
    cant fill with water or use
    turned machine on it wont fill with water and had 2 x lights on in the wash progress and 1 x light on in the rinse cycle and has a continuous beep aprox every second and I cant do anything can you help
  • Anonymous Mar 29, 2014
    starts to spin, wobbles, bangs, shuts down and tries again until cycles out. basket seems to move very easily side to side
  • Anonymous Mar 30, 2014
    washing machine working fine red light on spin cycle but does not start spin cycle
  • 28 Answers
Code 130 rotory position sensor needs tech to replace it or controller faulty
Posted on Jun 21, 2008
    Novelist:
    Champion:
  • 244 Answers
More than likely your carbon brushes in your motor when these wear down the drum wont spin so it wont do a cycle
Posted on Aug 12, 2007
  • 51 Answers
Hi Vixxy, Which lights flash when you hear the beeping?
Posted on Jul 24, 2007
Fisher and paykel washing machine top loader doesnt spin dry the clothes well. There isnt any water in the machine after the spin cycle but the clothes are heavy wet. What's could cause this?
Machine not spinning. Have you stood next to machine and listened? When all water is drained out (watch the drain hose for water to stop) then you should hear the spin start and hear it building up speed. If it doesn't then you need to post back here with more detail on what you could hear or see happening. i.e. how long after water stopped draining did machine finish and switch off?
Nov 05, 2016 | Fisher and Paykel Washing Machines
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ...
www.dslreports.com > ... > Home Improvement
DSLReports
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
Dec 02, 2015 | Maytag Washing Machines
Washer wont drain. fills with water. goes through wash cycle but wont drain. once it gets to the spin cycle, it spins for a few seconds and then stops and rinse light comes back on.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 21, 2011 | GE Washing Machines
Wont spin out,starts spin cycle then stops
heatman101
Sep 25, 2010 | GE WWSE5200B Top Load Washer
Washing machine
Here is what I suggested to another person with a similar request......
Not knowing what model machine you have, I would hazard a guess and say it is your break solenoid or break arm or a variation on a break system.
After the spin cycle, the break solenoid or break motor engages a break arm to stop and lock your spinning drum. The loud clunk is normal especially in Simpson and Hoover top load machines.
You can check this by putting the machine on a spin cycle. Once the machine gets up to speed, open the door. You will hear the clunck and then the drum stops abrublty. When you close the lid again, you will hear the solenoid release the drum, and then the motor starts spinning the drum again.
If that is the case, it is normal and no need to worry about it. However, if you did not have the noise before, then best to get a repairer to check it out.
Regards
Ash
Nov 08, 2009 | Washing Machines
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
Twin machine wont spin
the lid swich is defective,,,on the right hand side push down on the little switch with a non metal probe ..listen for a click..if no click or you have to push to far down change lid switch
Oct 13, 2008 | Whirlpool LTE5243D Top Load Stacked...
Haier XQBM22-C washer stopped spinning
It still doesn't work! I don't know how to fix it.
Mar 07, 2008 | Washing Machines
Fisher and Paykel GWL11 Top Load Washer Logo
683 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
shaun taylor
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
