Question about Yamaha RAV246 Remote Control WA164101
My system power button does not work - Yamaha RAV246 Remote Control WA164101
Dell studio 1537 freeze n my power button dosent work
Hi Jonatham,
My name is Pradeep and I work for Dell's Social Media Team.
Please try turning on the laptop with and without Battery.
Please turn off the system and unplug power adapter and Battery. Press and hold the power button of router for 15 seconds. Turn on the system and let us know the status.
Please let us know if you are getting light on the AC adapter brick.
Pease try powering on the system using media button. Please let us know when is the system freezing.
Pradeep Lokesh
Social Media and Community Professional
Order Status: http://del.ly/61822hij
Download Drivers: http://del.ly/61832hid
Jul 12, 2015 | Dell Computers & Internet
The PS3 system reads discs with music and video but does not read discs with games on for PS3
Welcome to Fixya
Try the troubleshooting procedure below:
Step 1 - Turn off the playstation 3 by holding the power button on the front of the unit till the power light is red.
Step 2 - Touch and hold the power button, you will hear the first beep, meaning the playstation 3 is powering on. Continue to hold the power button and after about 5 seconds, you will hear a second beep, indicating the video reset. Continue to hold the power button and after about 5 seconds, you will hear a third beep and the system will power off (power light is red).
Step 3 - Touch and hold the power button, you will hear the first beep, again for the playstation 3 to power on. Continue to hold the power button and after about 5 seconds, you will hear a second beep for video reset. Continue to hold the power button and after about another 5 seconds you will hear a quick double beep. At this point release the power button. if you succeeded in activating the safe mode, you will see a message on the screen saying 'connect the controller using a USB cable and then press the PS button.
Step 4 - Perform the safe mode options in the following order until one of the options works for you. If one option works, do not continue onto the other options.
Restore Default Settings
Restore File System
Rebuild Data Base
Restore PS3 System etc...
Thanks!
Jan 09, 2011 | Sony Playstation 3 (PS3) Console
My power button is not working means my laptop power button is not working proprely i mean its not Restarting
what kind of problem thoes you mean you press power button and your system shuts down in place of restarting
Jan 04, 2011 | Acer Computers & Internet
Ps3 games will not play ps3 games it will play ps2 games and movies whats wrong with the system?
Welcome to Fixya
Restore File System
Rebuild Data Base
Thank you
Dec 27, 2010 | Sony Playstation 3 (PS3) Console
Dvd works games don't ps3
Welcome to Fixya
Restore File System
Rebuild Data Base
Thank you!
Dec 18, 2010 | Sony Playstation 3 (PS3) Console
Ps3 wontplay games
Welcome to Fixya
Restore File System
Rebuild Data Base
Cheers
Nov 25, 2010 | Sony Playstation 3 (PS3) Console
How do i reboot my computer
To reboot the desktop machine, kindly press the power on button for few seconds / small button(reset) below the power button to reboot the computer.
If its laptop follow the below steps
Determine what operating system it uses. Finding out what operating system your laptop uses will let you know what key combo (such as "Ctrl+Alt+Delete") can exit you from usage and trigger a reboot or shutdown.
Try and reboot using the operating system. Attempt to use the key combination that will allow you to exit from the operating system and restart the laptop. Be patient, as it may take some time if it has locked up.
Hold down the power button. If the operating system's answer to the rebooting will not work, find and hold down the power button of the laptop. This should cause the device to shut itself off. You'll have to press the power button again to power it back on, completing the reboot.
Unplug from the wall and remove the battery. If restarting via the operating system and the power button do not work, unplug the laptop from the wall outlet, and remove the battery from the laptop. This will cause it to power off immediately.
Allow time to reboot. Give the laptop time to cool down before you power it back on if you had to do this manually. A few seconds should do unless you have additional problems.
Oct 15, 2010 | Computers & Internet
No picture for ps3,i went to service menunand did something wrong
You probaly turned hdmi on or off i dont know what your settings is,
you can turn your system settings back to factory default using the Safe Mode.
Step 1: Turn off the PLAYSTATION 3 by holding the Power button on the front of the unit till the Power light is red.
Step 2:
  1. Touch and hold the Power button, you will hear the first beep, meaning the PLAYSTATION 3 is powering on.
  2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep, indicating the video reset.
  3. Continue to hold the Power button and after about another 5 seconds you will hear a third beep and the system will power off (Power light is red).
Step 3:
  1. Touch and hold the Power button, you will hear the first beep, again for the PLAYSTATION 3 to power on.
  2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep for video reset.
  3. Continue to hold the Power button and after about another 5 seconds you will hear a quick double beep. At that point release the Power button. If you succeeded in activating Safe Mode, you will see a message on the screen saying, "Connect the controller using a USB cable and then press the PS button."
  4. Connect a USB cable to the controller and the PLAYSTATION 3 and press the PS button to enter Safe Mode.
  5. Then you will see the Safe Mode menu.
    safemode2.jpg //
Step 4: We recommending performing the safe mode options in the following order until one of the options works for you. If one of the options work, do not continue onto the other options.
  1. Restore Default Settings
  2. Restore File System
  3. Rebuild Database
  4. Restore PS3 System
Oct 04, 2009 | Sony Playstation 3 (PS3) Console
Panasonic SC-HT75 Home Theater system
with the unit switched on press and hold the stop button and press the power button once. if that doesn't work then try it with the play button.
Mar 31, 2008 | Panasonic SC-HT75 System
Yamaha RAV246 Remote Control WA164101 Logo
Top Yamaha Televison & Video Experts
Larry Stiles
Larry Stiles
Electro Med Services...
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
