Question about DreamGear I.Sound DreamTime (DGIPOD-364) (White) Speaker System, Clock Radio
Isound speaker with fm radio - DreamGear I.Sound DreamTime (DGIPOD-364) (White) Speaker System, Clock Radio
Nook reset/ was caused by isound speaker
Did you perform a hard or a soft reset?
A soft reset is initiated by holding the power button for 20 seconds and should not erase any books.
A hard reset is performed under settings and selecting erase and deregister device. This will completely wipe all apps, books and settings from the device and restore it to factory default settings.
However if you just log in to your B&N account you can see what you have previously downloaded and just download them again.
Dec 21, 2013 | Computers & Internet
Isound will not connect
Just hold the Bluetooth bottom while trying to connect to phone
Nov 28, 2013 | iSOUND 1690 TWIST WIRELESS SPEAKER &...
To add to my request a manual for AWA 17cm DVD/CD/AM-FM Television Micro System
An FM transmitter is a portable device, which converts a specific audio output into an FM radio signal. It can be plugged into a CD player, satellite radio system, headphone jack, or a portable media player. One common use of an FM transmitter is to play music from an Mp3 player through the speakers of a car.
Aug 20, 2012 | Televison & Video
I can't change the radio from am to fm. when i push the source button I get only am and aux in> i can't figure out how to get fm radio
not knowing what make and model your radio is i can't say 100% sure, but there should be a band button that should go from am to fm. some radios also have more than one fm selection. (fm1, fm2).
Jan 19, 2011 | Car Audio & Video
Is the fm radio able to go through the bluetooth
no FM Radio works only through Wired headset or through builtin speakers
Sep 09, 2009 | Cell Phones
LG Viewty FM Radio Speakers Not Working
well actually..your mobile does not have the ability to switch on to loud speaker when FM is on..! it can only be heard with ur head phones..^^ok
May 27, 2009 | LG KU990 Viewty
How to route the sound of fm radio on LG ku990 to main speaker. Right now sound is available only for headphones.
to Activate the FM Radio through the handset speaker? Type 3845#*990# into your handset.
You’ll be presented with a menu called Test Mode
Use your camera wheel to select FM Radio Test
Use the Up/Down keys on screen
Press the C Key and then the Red Key to exit.
thanks to lg-phones.org for this :)
Apr 25, 2009 | LG KU990 Viewty
FM Radio
The RDS (Radio Data System) FM radio is built-in and offers instant and easy access to FM radio channels in your phone. A handsfree or portable speaker set must be attached to the phone, as the wire works as an antenna for the radio. You can then choose to listen to the radio via the handsfree or the portable speakers, or through the speakers in the phone.
Jul 11, 2008 | Sony Ericsson K608i Cellular Phone
Ipod dream Time click radio
definitely take it back, if you don't you may be stuck forever
Jun 08, 2008 | Audio Players & Recorders
Fm radio/speakers
check that there are speakers! stupid as it sounds, sometimes there are just covers with holes behind...
If there are speakers trace the wiring through to the source make sure it has been conected both ends...
Or check the balance & fader on the set.
Dec 19, 2007 | Radio Communications
DreamGear I.Sound DreamTime (DGIPOD-364) (White) Speaker System, Clock Radio Logo
18 people viewed this question
Top DreamGear Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a DreamGear Audio Player and Recorder Expert? Answer questions, earn points and help others
