Question about Kitchen Ranges
I have a Chef Condor Convection wall oven which need replacing as it has stopped working. Does anybody know what are the dimensions of this oven so I can purchase the same size as I don't want to make chaanges to the kitchen cabinets at this time?
jsrock516
  • 5911 Answers
SOURCE: GE Wall Oven - error code F1
According to GE, the F1 fault code indicates a problem with the Electronic Range Control (ERC) Board. If the fault cannot be cleared, they recommend replacing the ERC and the touchpad. Has your repair guy tried any of these ideas? Post back with your comments, please.
Posted on Jan 17, 2008
aborcass
  • 2651 Answers
SOURCE: kitchen aid superba electric convection range
ouch thats gotta hurt!! how about the clock os that back on atleast??? sounds like a bad thermo stat on the back wall of the unit maybe a quater sized thermo 1 wire in one out, should have ( BUT DOUBt it does) have continuity through it. ifthe clock still doenst work ther is also a small inline thermal fuse connected right to the wire warness connecting to the main control
Posted on Apr 03, 2008
SOURCE: Kitchen Aid Double Convection Oven stopped during Self Cleaning
same thing happened to me yesterday took all day to figure it out was the themal fuse on the back of the oven the part number for my kitchen aid is 8300802 if you want the doors to unlock and reset the display you can take the leads off the fuse touch them together and the door will unlock however it is best to change the part took me 5 minutes once i knew what to look for
you have to remove the back panel and you will see the part with the number on it cost me 50 dollars but better than the 8o bucks to have a sevice guy come and do it next time i self clean i will pull the stove away from the wall to help keep it from ver heating
Posted on Apr 04, 2008
  • 521 Answers
SOURCE: Oven quit, bake not working, replaced thermostat, now broil works, still no bake
Your problem may be the bake relay on the clock or wiring.try changing that
Posted on Aug 12, 2008
huuum
  • 750 Answers
SOURCE: electrolux built in wall oven,
Hello stevefer
Welcome.
You said, Your Electrolux built in wall oven, lights and digital display work fine, fan works fine, but the oven will not heat regardless of the mode (broil, bake, convention roast, convection bake)
First,
1.What is the Model Number and the year of your wall oven?
2.Did the oven light up and display with any error codes?
3. Did you try to turn the breaker off for 5 minutes to see if this will reset the system?
Perhaps the heating element is failing and may need to be replaced.
I will be able to better assist you when you reply with this information.
Waiting your response.
Huuum
Posted on Oct 16, 2008
My Chef Classic Wall mounted fan forced oven stopped working. Its grill section working. Fan and the light in the oven working well. Bot oven doesnot heat up. Please give a tip what is probably wrong?
The bake element has gone bad. They can visually look fine but still be bad. To check and replace that element you will unfortunately need to kill the power and remove it from the wall. Remove the back cover. Check for a low resistance (around 16 ohms) across the bake element. If the resistance is high the element is bad. Google the make and model for a replacement element.
Dec 26, 2014 | Magic Chef Ovens
Condor convection chef
Possible causes:
1. Defective controller or its power supply.
2. Broken display panel.
3. Oven needs to be reset (pull plug for a minute or two to reset).
Jun 04, 2013 | Microwave Ovens
I need instructions for chef condor convection oven-having trouble with timer
i have a chef condor wall oven and the door wont shut properly as the latches have gone loose or broken
Jun 09, 2010 | Electrolux Ovens
Convection Oven has stopped working
magnetron may be defective . replace d magnetron
May 29, 2009 | GE JVM1790 1000 Watts Convection /...
Panasonic dimension 4 microwave/convection oven
Does this unit have a turntable? If so does it turn when on?
Sep 24, 2008 | Panasonic NN-C980 Convection/Microwave...
Kitchen Ranges Logo
37 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
