Question about Dometic Refrigerators
My refrigerator will not stay cold
Fridge raider was at five for defrosted the freezer which was filled with ice restart up and will not come down past 55
    Top Expert:
  • Dometic Master
  • 5,075 Answers
Check door seals
Posted on Jun 03, 2016
22yooper
  • 828 Answers
SOURCE: Refrigerator warm, freezer cold
Totally Unreasonable if you don't mind me saying so. The person who told you that story was thinking of an absorption unit more than likely.
Your proble is related to the defrost system of your refrigerator. There is a timer that automatically starts the defrost. It energizes the heaters that defrost the cooling coil. After the coil reaches a preset temperature a defrost terminator turns the heater off for the remaining time on the timer cycle. You could have a bad timer (stalled) which would not start the defrost. Locate the timer and turn the clutch head screw clockwise very SLOWLY until you hear one audible click. The defrost should take place and will be indicated by water in the drain pan under the refrigerator. If after 25 minutes it does not restart in the cooling mode turn the screw once again to the second click and replace the timer.
If the refrigerator restarts after 18-22 minutes and defrost does not take place your problem is in the heater circuit. Open heater or thermostat (termination switch)
Posted on Jul 16, 2008
SOURCE: Refrigerator warm, freezer too cold
I had this same problem. You need to totally empty the fridge and freezer and allow it to defrost for 24 hours. Then put it back on and it will work. This happens if someone leaves the freezer door open and then it gets closed. The defrosted water freezes in the pipes and doesn't allow the cold air to move up into the fridge so the freezer gets even colder. This has happened to me twice!
Posted on Aug 16, 2008
  • 19 Answers
SOURCE: Maytag refrigerator cooling probelm
Defrost the fridge, take everything out of freezer and turn off for at least a day, check the drain is clear after defrosted and try again, if it happens again you may need a new defrost heater of timer.
Posted on Nov 18, 2008
MNTECH
  • 1543 Answers
SOURCE: I have a GE GSS25WGMD BB Fridge. I have already
First, when the refrigerator is running, open the freezer door and hold in the light switch so the freezer light goes out. You should be able to hear the freezer (evaporator) fan running. If it is running, then you most likely have a problem with the air damper. It is a motorized door in the very upper left side, back corner, of the fresh foods section. The door needs to be open for air to flow into the refrigerator section. If you place your hand near the vent holes at the upper refrigerator section and the freezer fan is running, FF section warm, you should feel cold air entering. If not, the damper door may have broken. It is not real easy to get at to replace, but that is where your problem may be. Be sure to check the freezer fan first, as a non-working icemaker may point in that direction.
Posted on Jun 09, 2009
  • 13 Answers
SOURCE: Freezer box gets cold but fridge box stays warm.
Could be frost build up in the freezer compartment or a bad defroster,
Try running a diagnostic defrost cycle test and see what happens
Posted on Aug 17, 2009
Why does my refrigerator turns off restart a couple days later ?
Could be the back of the freezer is not defrosting and is packed up with ice. The cold air then can't circulate to the fridge part as the fan is frozen solid in ice. Had this happen due to a faulty transducer that tells the defrost system the freezer is iced up and to go into defrost mode. Also it could be the fan that blows cold air down into the fridge from the freezer compartment.
Aug 24, 2014 | Haier HNDE03VS (32 cu ft) Compact...
I have Zanussi Frost free fridge freezer 3 years old. Bottom of freezer compartment below shelf is filling up with ice. The freezer appears very cold. The fridge seems less cold.
There is a timer which defrosts fridge daily . Put on manual . replace switch . check door closing , defrost , check defrost element .
Apr 08, 2014 | Refrigerators
Kenmore classic bottom freezer refrigeration warm but freezer is cold
I would guess you have just caused a build up of ice to block the air way, which normally takes cold air into the fridge. manually defrost (unplug and wait until the ice goes away) then restart and it should be fine
Nov 11, 2013 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Electrolux ER 7626 Fridge not cooling
On these units there is a defrost heater which comes on after about 12/14 hours running time depending on usage.It would cut in for about 15 mins just to get rid of ice accumulated around the Evaporator.This heater or the timer has failed and ice has got between the duct. supplying cold air to the fridge unit.The best thing to do is to defrost unit for 24 hours and then try it and see if you can feel cold air coming up into the fridge.The repair for this is not that successful and you would be better off defrosting unit like a normal fridge/freezer.
Hope this was a help.
May 12, 2010 | Electrolux ER7626B Bottom Freezer...
Why isn't our refrigerator staying cold? It is staying around 50 degrees and no lower.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge won't stay cold
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
OR
Sep 08, 2009 | Refrigerators
Freezer and frige not that cold
Aug 30, 2009 | Neff K3965XO Side by Side Refrigerator
Aug 17, 2009 | Refrigerators
Roper Fridge
You have one of the following problems which is indicated by the frost buildup. Your defrost timer has failed, or defrost heater circuit consisting of a defrost heater and defrost thermostat. Start at the defrost timer. May be located in the fridge compartment near the temperature controls. There may be a recess through which you can turn the dial SLOWLY clockwise until you hear one click. the freezer will be in defrost. Wait 18-22 minutes and the freezer should defrost and restart into cooling. If it does not restart after 30 minutes turn the screw clockwise again one more click and it should restart.
If you had to turn it again to get it to restart the timer is bad and needs to be replaced. If the timer restarted the cooling mode after 18-22 minutes and defrost did not take place your problem is in the heater circuit.
Jun 09, 2008 | Roper Refrigerators
GE model TFX24FA side by side
Look in he back of the freezer section, if you see ice on the back wall then I would suggest defrosting the whole unit overnight and restarting to see if this makes a difference to the fridge section. If it does then you have a problem with the defrost cycle of the unit, if it doesnt then you may have a fan gone. We normally suggest defrosting first in case a door got left ajar. However if it does pull back down you will need to keep a close eye on the unit for several weeks. Hope this helps.
Aug 16, 2007 | GE PSC23NHN Side by Side Refrigerator
Refrigerators Logo
44 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
