Question about Gateway ID49C07U Factory Refurbished laptop
My gateway id49c07u will not boot up - Gateway ID49C07U Factory Refurbished laptop
Gateway sx2110 windows 8 formated drive c. now it will not take cds or usb to reinstal. says no boot cds or bad disk. keeps revolving to checking pc and fixing
You might need to go in to BIOS setup and change the boot order to boot from CD/DVD before the hard disk. Same thing for booting from USB. If the boot order is set to the hard disk first and it does not find a bootable partition then that's the error you would get and it might not get past that. I think F2 will let you access that on a Gateway. This is a link to to the Gateway recovery page and it has lots of good info on it. http://gateway-us.custhelp.com/app/answers/detail/a_id/34866/session/L3RpbWUvMTQ5MjA0NTQyMC9zaWQvZlVRWUtZclRhYkZqbl8zSEFEOUdoeFh2MkpUUERRNDhWRU9Od1g4SVNsTWV0QkVSYlBBcjloMmk1WDJWV1I5X2dWa0R1empXcUdsZGNYZTAyMVJKYjFnWUVfa2dyb00ybFFjRlU3VzhFVVluQkNfRzc2SFQ0QXRnJTIxJTIx
Apr 12, 2017 | Gateway Computers & Internet
Disassemble id49c
Someone has the service manual for this laptop? I need to disassemble to fix an overheat fan.
Aug 14, 2013 | Gateway ID49C07u Notebook
Gateway ID49C07u overheating + battery problem
Get a can of compressed air and clean out all the vents and fans. You can also use a vacuum with a hose attachment to clean it. You also might want to get a laptop cooler.
Also, Facebook is constantly under attack from malware and virus peddlers. You might want to try doing some malware and antivirus scans with some of the FREE software listed below:
Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below.
Download, Install and Run Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
When Installing choose the non-pro version.
Download, Unzip, Install and Run TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Download, Install and Run Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
If you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Make sure to select ALL of the "threat categories" when you install or configure Avira...
You should be in pretty good shape if you run and install all of these programs.
Jul 31, 2012 | Gateway Computers & Internet
Can Gateway MX3215 boot to usb stick?
If you go into the BIOS configuration then the Device boot order and you do not see the USB port in the list, then an USB boot up option is not available.
If it is available the move the USB as the first boot device so you can boot up with an USB memory stick.
Nov 13, 2011 | Gateway MX3215 Notebook
Battery plan
Hi, Urusk10
It's better to put external uninterruptible Power Supply (UPS) machine to double your power back-up. for hardware plan.
For software power plan on the windows base operating system.
Click control panel > power options. inside power options properties you can see three the power plan you like.
Oct 24, 2011 | Gateway ID49C07u Notebook
Does someone know the part number for a flex cable (from screen) for a Gateway ID49C0YU?? or where can I find that number.
Here is how you fix it.
http://andrewblock.net/2011/01/22/bios-update-failed-on-gateway-id49c07u-how-to-recover-from-a-bricked-laptop#comment-14365
Jul 11, 2011 | Gateway ID49C07u Notebook
Gateway mt6728 recovery boot disk
you can get the recovery disk from Gateway's website, here is the link:
https://secure.tx.acer.com/RCDB/Main.aspx?brand=gateway
Nov 29, 2009 | Gateway MT6728 Notebook
Gateway mx3215 freezing on init boot
Corrupted driver or faulty hardware perhaps.
May 08, 2017 | Gateway FPD1975 19" LCD Monitor
Gateway ID49C07U Factory Refurbished laptop Logo
66 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
