Motherboards
Problem for Motherboards
Generic problem for all Motherboards
Can't enter Setup.
By DeathChain01 on Jan 28, 2009
I recently found a motherboard, a processor, a CPU fan, a hard drive, and a CD drive in my basement in my piles of computer misc. So built a computer/. When I fire it up, however, it asks if I want to enter Setup by pressing delete. I can press it once, press it multiple times, or mash the button, but no matter what it will ignore me.
It will then try to boot, but encounters a problem or two.
After the No Setup issue, it will then proceed to do the EXACT FOLLOWING (Note: any paranthesis means a comment):
Sec Master Drive - ATAPI Incompatible
Sec Slave Drive - ATAPI Incompatible
Press F1 to Resume
(Doesn't matter if the drives are attached to the primary or secondary IDE ports. Continuing, I then press F1)
[BIG LIST OF COMPONENTS IS DISPLAYED]
(then the following after the list)
RPL-ROM-ADR: 0007 - 950D - 6521
RPL-ROM-IRQ: 3
RPL-ROM-PIO: D400
RPL-ROM-FFC: (Runs thru the #s 1-5 every second. IE: 1, 2, 3, 4, 5)
BOOT Failure
Insert BOOT Diskette into Drive A:
Press any key when ready.
(I don't have a boot disk, so I press any key anyway.)
Searching for BOOT record from floppy..Not Found
Searching for BOOT record from SCSI.(Scuzzy).No Found
Searching for BOOT record from network..OK (It's not connected to any Internet whatsoever so I would think an OK here is impossible...)
I can't find the motherboard's name anywhere on it, but there is a big copper heatsink/disipator with the name "Amptron" on it. Only signifigant name I could find.
Is it an HDD problem, a cable problem, or an IDE controller problem? First time I've encountered this problem with a computer before.
Comments:
Jan 30, 2009
- wayneard,
Yes, I'm using a single cable for the HDD and CD, and the HDD was already set to... wait...
OK, I'm POSITIVE I put jumpers on there.
Huh. Well it sees the HDD now, but it still won't let me into setup. I'll squash in the CD drive and see if I can install win2k.
Clarification Request
Posted by wayneard on Jan 28, 2009
What are the jumpers set on the drives?
Are you using a single cable for the HDD and the CD? Try doing so with the HDD connected to the middle connector with its jumper in the Master position and the end connector to the CD with its jumper on the Slave setting. (Connect them to the Primary IDE controller.
Is the BIOS showing the CPU and Memory when it begins booting?
Best Solution
posted on Jan 28, 2009
Very Helpful)
CompGoddess
Rank: Master
Rating: 91%, 7 votes
This may be an obvious question, but did you check the jumpers on the Hard drives? Make sure the master is set to master or to CS (cable select) then try again.
Was this helpful?
Yes
No
Popular Solutions for Motherboards
Questions and Unsolved Problems for Motherboards
Answer
Ive just looked at the specs for two motherboards 1,Asus P6T Deluxe V2 2,Asus M4A785TD-V EVO. WHATS... (More)
Answer
compaq presario mother board, what should I replace it with
Answer
problems with boot windows7 cannot boot cd code 5 someone else
Answer
system board, dev 001, err 91, fru 3610
Answer
nic and wirless wont detect. everything else works but not them all drivers are correct and... (More)
Describe your Motherboards problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Motherboard Experts
Top Computer & Laptop Repairmen
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
