Question about Water Heaters
Rheem powervent with power glo ignition system, model # 21vp40h-1p. Power glo lights up fine and dandy but kicks off and the dag nabbit fan runs all day. Have to turn gas and power switch off and back on, I guess kinda resetting it all, and then the deally will ignite and start heating water. Main valve? ?
2 Suggested Answers
  • 3 Answers
SOURCE: Rheem powervent ignites then goes out, electronic ignition.
Sounds like a bad thermocouple. This part sends a millivolt signal to keep the gas valve open but shuts it off when it cools - or if something goes wrong with the ignighter - to prevent fires. It's easy to replace and not super expensive. See your local Rheem dealer.
Posted on Aug 14, 2009
Pilot doesn't stay lit
1) Copy following link to troubleshoot by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
2) Replace gas control valve.
Mar 02, 2013 | Rheem Water Heaters
Rheem 21VP50-1P - power vent running non-stop.
Rheem does not post service manuals, but other manufacturers do.
Copy following link for troubleshoot by type of gas control valve.
Also, scroll up on same page, on right side for heading title 'Pressure switch' for troubleshooting the pressure switch.
Don't forget to check anode rod to protect steel tank from rusting.
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/How-to-maintain-water-heater.html
Oct 12, 2012 | Rheem Water Heaters
I have a Rheem Power Vent propane water heater model3 21VP4OE-1P that is acting up. The pilot lights and then the burner lights, but goes off after 5 - 10 seconds. It cycles like this 2 or 3 times, then...
check the thermal coupling for the pilot light. if it goes out it will shut down gas supply, its a safety feature to put out pilot light if the thermal coupling is bad. to prevent gas from leaking and causeing a fire. check coupling.
Aug 12, 2010 | Water Heaters
Aug 13, 2009 | Water Heaters
Rheem water heater, will start but flame lasts 10 seconds
Is the vent fan working well and can you feel unobstructed air out the termination fitting outside?
Apr 04, 2009 | Water Heaters
61 Gallon Rheem Water Heater is leaking!
TANK COULD BE LEAKING BUT NOT USUALLY @ TOP CK ALL FITTINGS VERY CAREFULLY AND BE SURE IT IS NOT ONE OF THEM
Feb 21, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Water Heaters Logo
59 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
