I have a power pod 740 plus. Two weeks old. Trying to run in main 1 and main two speaker mode. Both speakers work but only main volume works. I switched speakers to main / monitor changed switch and both speakers work but only from main volume. Question: when does the monitor volume get used? And how can I tell if both amps are working? Eq on both channels work it just seems that I only need one volume is the correct? Thanks.
SOURCE: Looking for a control pod.
I recently had a similar problem. In my case the left speaker had no sound. Finally traced the problem to a broken wire inside the control pod plug, which I destroyed by dissecting it. For those who have the experience, or know someone who does, purchase a new plug, which a Mini DIN 8 pin (RS-422 standard). It should be available at any good electronic parts store. Solder new plug on to cable, which requires a fine electronic soldering iron and a fair bit of skill (the wires are very fine).
Look at the plug (from the rear); you will see it comprises a top row of 3 pins equaly spaced; a middle row of 3 pins (there is room for 4 pins but one pin is missing just left of centre); a bottom row of 2 pins. I numbered these as follows:
8 o 7 o 6 o
5 o 4 o 3 o
2 o 1 o
The wire from the controller comprises 8 coloured cores and a bare core. The wiring of the eight cores are as follows:
DIN CORE PCB
pin 8 - brown 8
pin 7 - red 7
pin 6 - orange 6
pin 5 - yellow 5
pin 4 - green 4
pin 3 - blue 3
pin 2 - white 2
pin 1 - black 9
body clamp - bare wire - G
In case your coloured cores vary from mine I have also listed the pin each one goes to on the printed circuit board plug, which will let you identify the colours.
Posted on Feb 04, 2008
SOURCE: have no sound on front and rear speakers...
looking at the front of the unit take the left side pannel and replace the fuses. ive had to do that with mine several times because of the same problem
Posted on Mar 02, 2008
SOURCE: Onkyo Tx-v940 Receiver/Amplifier Protection Mode
Audio amplifier IC's damaged you need to change it.Good luck
Posted on Jun 11, 2008
SOURCE: Speakers not working correctly
you need to activate speaker fill i the settings
Posted on Jun 19, 2008
  • 4234 Answers
SOURCE: I have a phonic powerpod 7. the speaker
In bridge mode, the left and right amplifiers are in essence connected together. Typically, the speaker connections are to the positive connectors for each channel for this mode. WIth the speakers still connected, you essentially shorted the outputs to ground and smoked the output section. The unit will detect this now and not turn on the output section. Your unit is in what is usually called "protect" mode. This unit will require repair. Expect to have the output transistors replaced at the very least. I would estimate around $16-$40 for parts.
Dan
Posted on Jul 03, 2009
My marine stereo doesn't work anymore...Can I hook up my i pod to my pontoon boat speakers?
Yes, but not directly... the I pod will not have enough power to run the speakers...you will still need to have a radio or other way of powering the speakers and then feed the I pod into that...
heatman101
Jul 12, 2011 | Sport & Outdoor - Others
Bose Companion 5 Speaker System won't work
check if the volume control needs to be replaced. volume controls gets bad in due time coz of the carbon layer which gets thinner and thinner till it gets cut off
Aug 12, 2009 | Bose Companion 3 Computer Speakers
My volume will not turn up or down but does mute when both buttons are held down? Is this fixable?
I had the same problem, couldn't adjust the volume but could mute with both buttons (indicating that there wasn't anything wrong with the controls themselves). Tried re-connecting, turning off and on, etc. Nothing worked. Then I took the mains power supply out of my Samsung NC10 netbook that the speakers were connected to (so that it was running on battery power) and the volume controls started working! I don't know why this worked but it did.However, when I was trying to adjust the volume when the netbook was on mains power I got interference through the speakers which may be related. Hope this helps.
Jul 11, 2009 | JBL CREATURE II Computer Speakers
Using JBL 4410 3-Way crossover, trying to use PG 12" Dual 4-ohm
ok, connect the amp positive to the positive end of one sub coil, take the negative of that coil, and run it to the positive of the second sub coil, then run the negative out of the second sub coil to the negative of the amp.
Mar 29, 2009 | Phoenix Gold Octane-R 15.0:1 Car Audio...
Control Pod for Companion 5 volume control non-functional
I had exact same problem today. I moved my speakers from one room to the next. When I plugged everything back, the mute/unmute worked but the volume control no longer worked.
I got it working now!! I powered down my computer and then unplugged the power to the speaker system. Then plugged in the power to the speaker system again. Powered on computer and all is good again!!
Hope this helps/
Mar 13, 2009 | Bose Companion 5 Multimedia Speaker System...
Control Pod for Bose Companion 5 speaker system
I had the same problem right out of the gate, the volume dial on my control pod for my Companion 5 wasn't working, however, the touch pad and LED worked. I called Bose customer service and was instructed to:
First, unplug the power directly at the back of the woofer while the unit was on;
Next, I was instructed to unplug the control pod, visually inspect for any damage/defect;
Finally, re-seat the control pod on the back of the woofer and then lastly plug the power cable back into the woofer.
It worked like a charm. I hope this is helpful!
Jan 29, 2009 | Bose Companion 3 Computer Speakers
Denon AVR-3805 zone 2 no longer working
time to reset the microprocessor. See page 87 in manual.
1) switch off the unit using the main unit's power operation (small power button)
2) hold the PURE DIRECT button and DIRECT button at same time and turn the main unit's power operation on.
3) wait for entire display to flash in 1 second intervals
now the speakers need to be set up again but zone 2 will be working. i suspect a power surge causes the microprocesser to be corrupted. i put a power surge protector and have not had problems (lately).
Dec 29, 2008 | Denon AVR-3805 Receiver
Strange problems with Z-2300's
I'm having this same problem and have sort of solved it with a really wierd technique I found at Logitech. Evidently this problem is related to the control pod rather then the RCA jack. Try this:
Unplug the control pod from the subwoofer Turn off the main switch Turn the volume knob one full turn, tap the knob Repeat again (2 times) Replug the control pod Turn on the main switch and the control pod See what happens
I found that this got the speaker working finicky after it was almost totally useless. It seems to be cutting out randomly, but fidgeting with the control pod or it's connector jack fixes it. No clue what the deal is here, but your problem is identical to mine so take some time to screw around with these components with music running so you can hear if it suddenly works.
Nov 12, 2008 | Logitech Z-2300 Computer Speakers
Zone 2
if you have a main speaker system working properly, takea known good amp to ch2. wire the main pre amp out to amp 2 input.. turn both units on(no spkrs connected), fire it up. if the amp does not go into protect mode, turn ALL power off to the system.,connect one Spkr channel on A2, AND TURN THE VOLUME DOWN FIRS!!!!. pOWER UP THE SYSTEM AND SEE WHAT YOU GET.BE GENTLE WITH VOLUME SETTINGD! If ch 1 works, repeat procedure with ch 2 pre amp out.
Nov 11, 2007 | Onkyo TX-NR801 Receiver
 Grubhead
Grubhead
