Question about Sony FD Trinitron WEGA KV-29LS35 29" TV
No Sound Hello, The sound on my Sony Trinitron television just went out. I bought the tv just over a year ago. When I turn up the volume full blast there is a hissing sound, but that's it. Any help would be much appreciated.
  • Anonymous Mar 27, 2008
    i also have the same problem - no sound wheni moved the TV to Denmark, i bought it in UK 6 years ago.
  • 398 Answers
9 times out of 10, the symptom you are describing is the result of something not being set right. First, eliminate any cable box or dish reciever issues by running the cable directly to the TV or using a VCR to play a good pre-recorded tape. Then go through the audio menu and make sure the speakers have not been set to OFF and also make especially sure that the TV is not in the SAP mode. If you eliminate all of the above and still have no audio then have the set serviced by a qualified tech.
Posted on Jul 24, 2007
SOURCE:
Cannot control the sound on my sony trinitron
hello,
Try this method : operate with remote. if still not working, try manually by pressing volume button on tv. If this still not working, and you have tools and experience with electricity equipment , i suggest you to open it.
In front panel , change volume switch. Change all switch if necessary.
If you doesn't have experiences in electrics, call technician for a better repair.
Good luck.
Mar 25, 2011 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony kv36hs500 tv, suddenly no power, no standby lights, no sound
U check the power source?Take the tv aparts,check or replaced the power fuse,might get lucky.Not,than sorry,this tv can't be repair,without replacing electronic's componnents parts.Hire the same shop to do the repair.Ur tv power ICS inverter are dead.
Jun 15, 2010 | Sony FD Trinitron WEGA KV-36HS500 36" TV
VOLUME CONTROL
I HAVE SONY TV MODEL 2197.WHEN I SWITCH ON THE TV NO SOUND INSTEAD OF THAT I PRESS FULL VOLUME ...
Jan 27, 2009 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Sound goes off
if this issue persist you need to go to one service authorized
Dec 10, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No Sound Issues
Hello!
Try the audio out. Run the audio to a receiver to see if the audio is there. If it is, then I'd leave it hooked up to the receiver and save yourself some money. If there is not any low level audio out then I'd fix the set. The only Sony set I've ever seen that was not worth fixing was a 32" model from the early 1990's that had bad picture tubes after only 5 years. I am a Sony factory trained tech. Good Luck!
barneyluc
Oct 13, 2008 | Sony KV-32FS13 TV
Volume up then pic gone
Good Day;
The TV's front panel may be bad, manual buttons. TEMPT FIX; remove speaker, cloth covered, cover, disconnect cables. TV will work but only with remote.
Good Luck!
Jun 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Sony Grand Wega 50" LCD
What is model no of your tv, I think, there maybe a modification for it
capital98
Nov 30, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Volume is too low on my old Sony Trinitron KV-27S45
Volume is too low on my old Sony Trinitron KV-27S45 Can i fix it with out parts? no as it requires tech help as tv is high voltage device. would it be less expensive to just purchase a new tv? it would be less expensive. no need to purchase new tv. please get check 1 speaker paper cone might be hard or defective 2 loose contact in sound section 3 supply to sound might be absent. 4 connector loose. 5 any capscitor defective in sound section. 6 ic might be defective in sound section hope this will help.
Sep 25, 2007 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony FD Trinitron WEGA KV-29LS35 29" TV Logo
120 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
