Question about Logitech X-530 5.1 Surround Sound Speakers&Subwoofer - 970114-0403 Computer Speakers
No instructions I do not know how to hook it into my TV I have it all conected correct due to the color coded tips but from there I am lost. it is a lotitech X-530 and it was given to me with no instructions
  • 192 Answers
It should be pluged into the box that came with your tv
Posted on Jan 28, 2009
I purchased a used Panasonic Plasma TV TH-42Pw5. I finally got a picture by hooking it up through a vcr, but the color is completely green. When using the remote instruction colors are varied. HELP!
usually a single color is caused by a bad connection to the display I would guess that a connector inside the TV has come partially loose causing this this is quite common on the computers at my work due to vibration before taking the TV apart I suggest replacing the external cables to the VCR
Mar 25, 2017 | Panasonic Televison & Video
MY TV will not show color on the tv .I have a protron PDS2315 .I don't have the cables that came with the DVD player Does that make the deference?
Hi zapchenk,
First of all, thank you for posting your question here at
The most common caused of "No color" fault when viewing movies through DVD player are :
1. Wrong TV/DVD format - If your TV is a NTSC system format and not knowingly your DVD player is set to PAL/Secam system format, then there's no color generated to your TV due to incorrect video frequency signal coming from the DVD player.
Solution : You have to sync/match the system format of the TV and DVD player. Check first the system format of the DVD player through the menu. Try to change it from PAL/Secam to NTSC.
2. Wrong hooked up - Since the problem is in video, you have to check the video hooked to your TV and DVD player. HDMI jack is the best option to avoid wrong hooked up because it come with Audio and Video in just one cable. If you are using one RCA cable to connect the video, make sure that it is hooked up to Video in of the TV and Video out of the DVD player, it is usually color yellow RCA jack. If you are using the component video hooked up, you must have 3 RCA cable for video alone. It is color coded as green(Y), blue(Pb/Cb), and red(Pr/Cr) RCA jack.
My advice is to check first the system format and then the video hooked up.
Hope I helped you.
Have a nice day!
Good luck and take care!
Kind Regards,
Dec 10, 2011 | Televison & Video
How to install samsung dvd-v1000 dvd/vcr combo ? I lost instructions and need to know what cords to hook up where ?
if your using rca cables then plug the coresponding colors from the out on the dvd to the input on the tv
Dec 21, 2010 | Samsung DVD-V1000 DVD Player/VCR
Changing remote to another tv lost my owners manual dont know what to do fist going from a philips tv to a toshiba tv
I can help you with your URC-3021 Universal Remote Control issues.
The codes for Toshiba TV's are: 0154, 0156, 0060, 1356, 1656,
1704, 0650 & 1256.
For complete instructions on entering the URC-3021 remote codes, please refer to my posted Fixya Tip One For All URC-3021 Code Entry.
I hope that helps.
One For All URC-3021 Manual
One For All URC-3021 Code List
One For All URC-3021 Code Search
One For All URC-3021 Reassign Key
May 20, 2010 | One For All URC-3021 Remote Control
Lost the Sony remote some time ago now need to reach chan.#3
Due to the fact that you lost the remote, you will have to buy a universal one(lots of places have them) and you will have to program it to your TV, most come with a code book with them, follow the instructions, if that does not work most remotes have a search code feature on them, where you can turn the unit on and follow the steps to search for the code and you should be good to go.
Feb 18, 2009 | Insignia Digital-to-Analog Converter for...
How do we hook up the D.V.D. player to the T.V. We think we have done it correct but it does not play.
couple of ways but the easiest way would be connecting the video and audio out from DVD (need rca connections yellow red and white)
Yellow --- Video
white and red is audio out left and right.
find in your tv set inputs with similar colors its going to be input 1
or input 2 (as an example)
once you conect the cable matching colors yellow to yellow red to red and white to white make sure you select the same input on your set (video 1 or 2) that its throu input selection in remote control from tv or set itself.
Jul 03, 2008 | Televison & Video
Sony maintains most manuals on their website. The general principle is to hook the cables from the video and audio OUT of the DVD/VCR player to the video and audio IN of the TV. Once the cables are hooked up correctly, just press the input, source, av, or video button on the tv or tv remote to change the television to the correct channel so that you can watch videos.
Jun 14, 2008 | Philips Televison & Video
Broken wires
Sounds like uve got a component hookup, make sure the box has it too...should be labeled component, if not, and u only see yellow, white, and red, then uve only got composite hook up (AV) and u cant hook up all 3 cords to it. If it was working before... It was rigged in a way to make it work, I'd have to kno the brand of the TV, as well as the model that you've provided.
Dec 25, 2007 | Toshiba CX36H60 TV
Hooking tv up to my vcr/dvd combo
hook the antenna to the VCR rf conecter IN. buy some RCA jacks and a three way deal and hook the red to sound red out ,white to sound output white, and yellow is always video hookit to yellow vido out on the vcr/dvd. The other ends go to the inputs on the TV....same color code. or you can just hook a cable to rf connector OUT on the vcr and other end to( it with problably just same antenna in) to TV.
Aug 29, 2007 | Sanyo DS31520 31" TV
71 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
