Question about Toshiba TheaterWide 62HM94 62" Rear Projection HDTV
Toshiba 62hm14 TV turns on with no picture but has sound then green light blinks and it shuts off
I have a toshiba 62hm14 and have owned it for 2 years and have not had any problems until now. When I turn the TV on there is sound and the red power light comes on but no picture at all. After about 15 seconds the green light which has no label starts blinking and the TV turns off. It then tries to cycle back on again and does the same thing. It happens over and over again until I manually turn the TV off. I have never replaced the bulb on this TV and it never gave me any warning it was a bulb. What do I need to do to fix this problem. Thanks for any help you could give me. Thanks!
  • 1 more comment
  • mesganam Jul 23, 2008
    I HAVE TOSHIBA 56HMX96 BOUGHT IT 18MTH AGO GOOD PICTURE
    GOOD SOUND LOVE IT BUT 2 DAYS AGO TURN IT ON NO PICTURE BUT THERE IS A SOUND.FIRST THERE WAS THE BLUE LIGHT ON WITH THE YELLOW LIGHT BLINKING,AFTER 8 TRY OUT THE POWER
    WENT OFF,THEN I HEARD A SOUND SAYING 'I AM NOT WORKING' THEN I TOOK THE BULB OUT AND CHEKED IT IT LOOK VERY GOOD NO BLACK OR ANY BROOKEN THINGS,WHAT CAN I DO HELP?//
  • kwallyg Oct 30, 2008
    I have the same problem. I thought it was the buld but it's working fine. The red light stays on and the green blinks about 15 times and the TV shuts off. It constantly does the same thing until I turn it off. Maybe it could be dust where I replaced the bulb. I'm going back to troubleshooting... If anyone has any answers please let me know???
    Keith at [email protected]
    Thank you much....
  • John Medina
    John Medina May 11, 2009
    turn on the tv a62 wide screem sound but no picture after afew trys it turns off how do you repairs lamps thank you
I actually found the solution, my manaul for the TV was missing a couple pages, very weird. I found the full manual online and there is a chart that shows what the blinking lights mean. It was my lamp, after I took it out it looked like it had exploded, so I ordered a new one from toshiba and replaced it. Very easy to do, costed about 120 for the lamp but no problems since.
Thanks for all of the responses.
BigPea
Posted on Dec 05, 2007
    New Friend:
You can look up a chart for the blinking light online, most likely the LAMP HAS TO BE REPLACED $80-$125 ONLINE.
Posted on Jun 16, 2011
This isn't gonna help you, but I have the same problem on my 62HM15A, think we have about the same tv, widescreen DLP,?
My TV does the same thing powers with a blining lite then powers off. First it powered on with sound no pic, then would shut down and power up again with pic and sound , now i gots a nothing just powering on and off until i shut the thing off manually.
thanks, just posted here in case some answers bipea's question and it relates to mine.
Posted on Nov 17, 2007
SOURCE:
Toshiba 52hm94 when powered on continuously shuts on and off with blinking red and green light and static noise
that happened to my old LED tv it was the tubes that have gone go into currys and ask an expert thats how i found out what was wrong with mine
Aug 02, 2012 | Toshiba 52HM95 52" HDTV Projection...
My toshiba 40ft2u1 will not turn back on
I'm having the same problem right now. I get the green light for about 5 seconds (not Blinking) then the light goes out. No sound or picture.
Apr 05, 2012 | Toshiba Televison & Video
Red/green lights both blink and tv will on turn on
Are the red and green lights blinking at the same rate or not? If the green light is blinking every 3 seconds and the red light is blinking every 1/2 second, the lamp door is not properly secured. If both lights are blinking at 1 second intervals, try replacing the lamp. If a new lamp doesn't solve the problem, the TV needs service.
I hope this helps.
Jun 23, 2011 | Toshiba 52HM95 52" HDTV Projection...
When i turn my toshiba tv model #46h84 the green bulb lights up the screen but then shuts off and there is no picture! please help me out!!!
I have the same exact problem...for a few weeks the TV would turn off and the red power light would blink. Then the other day I started having exactly the problem you describe...green screen for a few seconds and then total shutdown.
Feb 08, 2011 | Toshiba 46H84 46" Rear Projection...
Power problems problem on
I would try a power drain:  Unplug the TV's power cable so the TV is not grounded to the house.  Then press and hold in the TV's own power button for one minute to drain the capacitors. Plug the TV back in and see what happens.  If the TV will still not turn on, I would say you have a problem with the TV's mainboard as a dead power supply will not light any LED's for you.
Mar 24, 2009 | Toshiba CN36X81 TV
Toshiba 52Hmx94
How many times does it blink?
I replaced the ballast in my 62HM84 and it fixed it. The problem was TV would not turn On, Red light solid green light blinked 9 times then TV would try to restart. At first I thought it might of been the bulb, so I replaced it, same results. Next I replaced the ballast which is pretty easy, just take pictures before you remove the light engine so you can go back to the picture to verify the connections when reinstalling.
Dec 25, 2007 | Toshiba 52HM95 52" HDTV Projection...
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Jun 03, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Toshiba TheaterWide 62HM94 62" Rear Projection HDTV Logo
2,376 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
