Question about s4 hose . evaporative emission canister leak detection pump
Were can i find evap canister on 2001 mitsubishi galant
Were is the location on evap canister.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 122 Answers
Follow the fuel and extra lines from petrol tank and the carburettor.
Posted on Sep 26, 2014
PO442 code on my 2004 mit galant,LS V6 3.8 how to fix an evap problem small leak
the causes for the small leak are listed as
hose connections --intake leak--- EVAP canister--- EVAP canister purge valve
check hoses for small cracks ( old hoses) or replace the purge valve
Sep 19, 2016 | 2004 Mitsubishi Galant
Evap emission purge flow
Either the PURGE VALVE has failed (auto parts store) or the VAPOR CANISTER is clogged (junk yard).
Apr 14, 2014 | 2003 Mitsubishi Galant
Where is the Vapor Canister on 2002 mitsubishi galant
its in the rear of the car near the fuel tank
Aug 12, 2012 | Cars & Trucks
No Service Engine Soon seen for code P0442
code p 442 refers to evaporative emission (EVAP) system---small leak detected
it also refers to large leak detected --fuel cap off/loose === causes hose/connection,-- intake leak--EVAP canister---EVAP canister purge valve --mechanical fault --- EVAP pressure sensor
Oct 17, 2017 | Mitsubishi Cars & Trucks
I have a 2001 Mitsubishi Galant and my son received 4 codes off of the programmer. The recent one is P0300, then the next 3 are P0441, P0335, P0455. Can you tell me what the codes stand for
A code P0300 may mean that one or more of the following has happened:
  • Faulty spark plugs or wires
  • Faulty coil (pack)
  • Faulty oxygen sensor(s)
  • Faulty fuel injector(s)
  • Burned exhaust valve
  • Faulty catalytic converter(s)
  • Stuck/blocked EGR valve / passages
  • Faulty camshaft position sensor
  • A code P0441 could mean one or more of the following has happened:
    • Bad vacuum switch
    • Broken or damaged EVAP line or canister
    • Open in PCM purge command circuit
    • Open or short in Voltage feed circuit to Purge Solenoid
    • Faulty purge solenoid
    • Restriction in EVAP solenoid, line or canister
    • Corrosion or resistance in purge connector
    • Bad PCM
    Defective computer
Mar 13, 2011 | Mitsubishi Galant Cars & Trucks
P0456 error code on a 2003 Mits. Galant
P0456 = "Evaporative emission (EVAP) control system leak detected (very small leak)."
Feb 25, 2011 | Mitsubishi Galant Cars & Trucks
Were is the evap located on 2001 Chevy s-10 blazer with v6
The EVAP service port is located in the EVAP purge pipe between the EVAP purge solenoid and the EVAP canister. The service port is identified by a green colored cap.
Fig. Showing location of (1) Evaporative Emissions (EVAP) Canister Purge Solenoid and (2) Exhaust Gas Recirculation (EGR) Valve
Fig. EVAP Purge valve solenoid (3) mounting bolt (2) and insulator (1) on 2000-2005 4.8L, 5.3L, 6.0L Engines
Hope this help (remember rated the post).
Mar 26, 2010 | 2001 Chevrolet Blazer
Where is the fuel filter located in the 2001 mitsubishi galant?
can you tell me where the fuel filter is located on a 01 mitsubishi galant?
Mar 14, 2009 | 2001 Mitsubishi Galant
Atmospheric Pressure SensorI have a 2001 Mitsubishi Galant GDI. C
Its located in the air filter housing....The volume air flow sensor also incorporates the barometric pressure sensor and the air intake sensor....If you are replacing either of these sensors replace the volume airflow sensor.......
Nov 13, 2008 | 2001 Mitsubishi Galant
s4 hose . evaporative emission canister leak detection pump Logo
56 people viewed this question
Top Audi Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Randy Ohler
Phil Fisher
Level 1 Expert
Are you an Audi Vehicle Part and Accessory Expert? Answer questions, earn points and help others
