Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Kenmore gas stove locked out during power outage.
I have a gas Kenmore stove which features a lockout system for the burners and oven when no electricity is present to operate the igniters.
We are expecting a power outage of many days due to an ice storm. Is there any way to bypass this lockout and light the stove manually.
Thanks,
BC
ngfam1
  • 639 Answers
SOURCE: Fault code F5
Hi Marcos
Happy to help you!
But I see that this problem will be solved only by service!
A & E factory service is good and nation wide!
1-800-905-9505
They answer 24/7
Thank you Neil
PS.Please do not forget to give me a problem solved rating
Posted on Aug 24, 2008
SOURCE: The ESEC lockout feature is
you can unplug the stove and plug it back in that will take the looking position. and in other models, set the oven to clean the oven for 5 minotes, and it will go of and will relace the oven door.
Posted on Dec 06, 2008
appldoctom
  • 311 Answers
SOURCE: Oven takes longer than expected to light
was it the correct igniter.almost always the ge ignitors are round.this is how it works.the ignitor pulls enough current thru it to garentee that their is a good source of ignition 4 the gas to leave the oven safty valve.to meaurse the value of the ignitor you need an amp probe.you would meaurse a good ignitor at about3.2to3.5 amps a strong ignitor will glow very,very brite
Posted on Jan 01, 2009
Sea Breeze
  • 4655 Answers
SOURCE: GE XL44 gas: Stove works fine. Oven heater lite on but gas wont
Click on link below and go to page 46 on the Adobe PDF of your model and there are some trouble shooting tips. Thanks, Let me know if this helps, Sea Breeze
http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=SKUOBJECTS&DOCUMENT=Installation%20Instructions&SKU=RGB745BEAAD
Posted on Feb 08, 2009
  • 198 Answers
SOURCE: oven won't work on gas with electric ignition stove
The glow bar for the bake burner is bad, needs to be replaced. Remove oven bottom to get to it, and also the utility drawer.
Posted on Feb 20, 2009
Managemylife com
From the manual:
To turn the Cooktop Lockout Feature OFF:
1. Press and hold (_ until "CLO" appears (Figure 3). Continue holding
until a second beep sounds (after 3 seconds). I_1will disappear from
the display indicating the cooktop may be used normally (Figure 4).
Note: Starting a Self-Clean cycle will automatically turn ON the Cooktop
Lockout feature. The cooktop will remain locked until the Self-Clean cycle
has completed and the oven door has unlocked. If a power failure occurs
after the Cooktop Lockout has been activated, you must turn OFF the
Cooktop Lockout feature before being able to use the cooktop features
again.
Dec 14, 2013 | Stoves Kitchen Ranges
Frigidaire stove oven want come on model # FGF368GSJ
Hello Larry D Harris - Does any part of the range work? I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another questions, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. A beep will sound. LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Do the maintop burners work? Granting that it does, you can try confirming that the shut-off valve on the gas pressure regulator is in the "ON" position (usually located on the back left-hand side of the range). This valve shuts off gas to the oven. If after the basic troubleshooting, you continue to experience the issue I would suggest contacting a certified technician to assist in the full diagnosis and repair of your range.
Nov 06, 2012 | Frigidaire Stove/Oven/Range Cooktop -...
My oven/stovetop isn't turning on, and it says "LOC" on the screen. Its like the stove won't ignite. What should I do?
To lock/unlock the controls: Turn all surface burners off.
Touch and hold the GAS/CONTROL LOCKOUT pad for 3 seconds until the display shows LOC.
To unlock the control, touch and hold the GAS/CONTROL LOCKOUT pad for 3 seconds until LOC disappears from the display.
Feb 11, 2011 | Whirlpool Ovens
After self- cleaning my Kenmore Gas Range, I have not been able to get the 'Cooktop Lock' light turned off! So while I can use my oven for baking I can't turn the gas on the top of my stove! I have...
This may be a silly question but, did you just try turning off the circuit breaker for a couple minutes to see if it resets itself when you flip it back on?
Nov 21, 2010 | Kenmore Kitchen Ranges
I have a kenmore electric stove. The top burner
I have the same problem, it turns out that the clock has a sensor in it to turn on the oven. If that sensor is not working, which is found in the clock, the oven does not work. I had a repair guy come out and it will cost 350.00 to repair. My stove is only six years old. It is only two months to the day off warranty. Apparently a power outage can cause the sensor to go. Hope this helps.
May 12, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
I have a kenmore stove 362.7361193 pilot not on
There isn't a pilot light on MOST modern gas ranges. The top burners are controlled by individual igniters through a common spark module. The oven, however, is controlled by an igniter on each manifold. One for bake, one for broil. If you are having problems with ONE of the oven features, I would suspect a bad igniter. If BOTH oven features are bad, you may have a bad Electronic Oven Control (EOC) board. If the oven works, but none of the surface burners are working, I would suspect a bad spark module. The following link explains a little theory on oven igniters:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
Since your range appears to have a common gas safety valve and regulator, all burners are fed fromthe same gas source. Which means, if you have ANY burners lighting, you probably don't have a gas problem.
I hope you can determine what your problem is from the information I provided. If not, please post back and elaborate a bit more on your symptoms so that I may assist you better. I hope this helps you.
Jul 21, 2009 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Kenmore Range/oven Burners won't lite
Ours did the same, I unplugged the stove for 1 minute and afterwards the burners worked fine.
May 19, 2009 | Kenmore 75844 / 75849 Gas Kitchen Range
Lighting the oven
Control Lockout (on some models)
Your control will allow you to lock out the
touch pads so they cannot be activated when
touched or cleaning the glass panel.
To lock the controls:
Touch the 9 and 0 touch pads at the
same time for 3 seconds until the
control beeps twice. The display will
show LOC continuously and the time
of day if not blacked out.
NOTE: All cooking and timing functions will be
cancelled when locking out the control.
To unlock the control, touch the
9 and 0 touch pads at the same time
for 3 seconds until the control beeps
twice, and LOC will be removed from
the display.
NOTE: Some models have a Control Lockout
pad. Touch and hold it for 3 seconds to
lock/unlock.
Gas/Control Lockout (on some models)
surface burners, oven burners and control
panel so they cannot be activated.
Touch and hold the Gas/Control
Lockout pad for 3 seconds until the
display shows LOC ON.
Gas/Control Lockout pad for 3 seconds
until the display shows LOC OFF.
When this feature is on and the touch pads
are touched, the control will beep and the
display will show LOC ON.
 The control lockout mode affects all
controls. No controls will work when this
feature is activated.
 The adjustment will be retained in memory
after a power failure.
Nov 30, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Burners don't receive gas though oven/broiler does
tommi, this model has a cooktop lock-out solenoid feature. Try pressing and holding the top light keypad for 5 seconds and see if the top comes back to life. If not, check your owners manual, it may be a different key. The lock-out solenoid is in the back behind the outer panel. The cooktop lockout valve has been redesigned from a AC to DC voltage because of complaints of chattering. The new part number is 8184768. Lets hope you don't need it and just have the top locked out.
Apr 10, 2007 | Kenmore 75844 / 75849 Gas Kitchen Range
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
579 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
