Question about Vertex IN-80 Protein Skimmer
I have a vertex in 80 skimmer about two week old and it continues to over flow even at its lowest setting.
We have tried every thing vinegar bath, water change in the main tank, it also creates micro bubble that are picked up by the main pump
Have three sets two with very low receiver performance, one no receive at all , in all three sets the green call lamps flasher all the time
We work on the business band Vertex in the US. When the green light continuously flashes, the radio has a terminal condition. It is typically in the VCO, but often other parts fail as it failed. Due to the price of labor, and the unreliability of the repair, we do not repair these because by the time we find the issue, it is over 60% of the cost of a new radio with a full warranty. Hope this helps, more of a "do you want to take the time to try to fix it". BTW, we throw those away and never salvage parts due to the likelihood many components have failed.
Feb 17, 2015 | Vertex Radio Communications
How to vacum my spa with pool maintenance kit
if you have the intex kit , it comes with instuctions but hers it ina nut shell , find adaptor plate that fits inside skimmer (flat thing with hose port in middle) assemble sustion head and handle with hose attached and drop into pool (keep handle out) fill hose full so it sort of sinks (no air gaps) snake carefully end of hose over to skimmer (pump running normal) fit plate into skimmer quickly snake hose thru skimmer hole and fit to plate adaptor on hose port , wait a few minutes if flow continues out pump dishcharge then your good to go if not dissasemble and start over , but let filter pick up prime again 1st , do not lift head out of water even to get big stuff off pickup do it in the pool under water
Jul 23, 2014 | Intex Above Ground Swimming Pool Skimmer...
Pool cleaner starts and then stops working
Check for water flow / water flow restrictions / and water flow blockages.
Many things create water flow reductions: Dirty filters, plugged impellers, packed with debris baskets - both skimmers and at pump, closed to partially closed valves, air suction leaks: worn shaft seal, worn orings at pump lid or pump volute body, low water level, stuck skimmer weir blade/gate in the up position & skimmer empties and air is sucked into the system which may cause the pump to lose prime. This a problem that goes un-noticed and is hard to detect even by some service technicians!
Jan 31, 2014 | Pool & Spa
Old primary relay can't find part number
sounds like the flame recognition is not sensing a flame.. some models use a rod that gets corroded.. a little cleaning with fine steel wool and a vinegar bath, rinsed with water and dried works well to clean up the rod..
Jan 03, 2014 | Honeywell Heating & Cooling
Philips steam iron no steam and red tap light is flashing even when filled up with water it's still getting hot and water is boiling but steam fiction not working as red light will not go out
It sounds like the flow holes are CLOGGED with scale inside. To clean it out:
1. Drain the water/steam out the pour-in shoot at the top of the handle, over the sink. Is any crap coming out?
2. Take some VINEGAR and pour it straight into the fill pour-in shoot. Don\'t dilute it. Fill up the IRON to full line. Let the vinegar SOAK the inside of the COLD iron for 15-20 minutes, by placing it FACE DOWN on an old bath towel, on a heat-resistant surface, such as a granite counter top, or metal cookie sheet. Don\'t put the towel on the ironing board!!! It may get stained badly. Let it sit, COLD for 20 minutes. You can swirell the vinegar around by shaking the iron.
Stand it up on its flat end, with the vinegar inside, still. Take some fresh vinegar and dip Q-tips into the vinegar and clean the slots and holes on the bottom plate. Any burn streaks or soil can be removed with wiping the plate with vinegar. After you clean all the holes and slots with vinegar from the outside, TURN ON THE IRON with the vinegar inside. The vinegar will heat up and should come out the holes. If any holes are not blowing vinegar/steam, clean them with q-tips again. Don\'t let all of the vinegar inside steam out!! Just heat it enough to make sure all of the holes are clean. Some white film may come out of the holes on to the face plate--it is calcium build-up from using tap water in the iron.
Now DUMP out vinegar inside the iron and reservoir through the pour-shoot You may see crud and crap coming out. Repeat the process of filling it up, steaming through the holes etc. until the vinegar comes out clear!!!
DON\'T use tap water in any IRON. Use distilled water, or even bottled drinking water (without flavoring, additives, of course). This will prevent corrosion and calcium build up in the iron.
ALWAYS completely drain the iron from the pour-in spout each time you are finished using it!! After pouring out the tank\'s water, you can set the iron to STEAM HIGH, and force any water inside to boil off and out of iron.! Never keep water in the reservoir or iron.
I set my iron, when hot, and done using it, with the pointed side DOWN in the sink drain to make sure it is dry.
So clean it with vinegar often, use bottled drinking water or better, distilled water and it will prevent this.
Oct 24, 2013 | Irons
I can't get surface skimmer to work
im not sure what or even how you mean "swims away" as properly intalled it has a bracket that holds to pool wall , no the most problem ive seen with these is they sink !! pulling it and bracket right to bottom , this is just an adjustment of water flow thru float skimmer vs side skimmer (normal)
Jun 22, 2012 | Intex Swimming Pool Leaf Catcher Skimmer
Do not know how to install the filter to the pool, misplaced the instructions
1 - Connect your shortest hose from the bottom of your skimmer (if your pool came with one) to the lowest hole in your pool.
2 - Connect another hose (if I remember correctly, the 2 remaining hoses are the same length - if not, use the shorter of the two) from the outside of the lowest hole to the bottom place on your filter.
3 - Connect the final hose from the top place on your filter to the highest hole on your pool.
Your pool's water leaves your pool thru the lower hole & enters the filter. The filter then returns the water to your pool thru the highest hole.
If your pool did not come with a skimmer, you need to be sure to screw the vent cover over the lowest hole. You will need to screw the vent cover to the highest hole as well, but this is MOST important with the lowest hole as the suction could cause serious injury or even death to anyone (especially a child) who unsuspectingly gets too near. The suction could 'grab' a child and harm him/her or even cause the child to become trapped underwater. Please don't forget to correctly secure this spot of your pool.
Jun 21, 2011 | Intex 1000 Gallon Per Hour FilterPump
When setting the pump to pull only from the skimmer on my in-ground pool, it doesn't **** enough water to keep the the suction pump full of water. I have to set it on main drain or ''skimmer & main...
There may be a partial blockage in the skimmer plumbing. If you lift out the basket, you may be able to see something there. If not, try a hose and flushing the lines.
Make sure the wear door is functioning properly also.
If this is not the issue, make sure that you have all the valves open so there is no restriction of flow.
Jul 10, 2009 | Pentair Bermuda Vinyl/Fiberglass Pool...
Hampton Bay Dehumidifier Model# HB50
MY dehumidifier leaks water from upper part of unit causing water to leak on floor while running.
Feb 23, 2009 | Dehumidifiers
Vertex IN-80 Protein Skimmer Logo
65 people viewed this question
Top Vertex Fish Experts
ThothMer
ThothMer
Level 1 Expert
Richard Lindsey ...
Are you a Vertex Fish Expert? Answer questions, earn points and help others
