Question about 13 HP Electric Start GX390
How to install electric starter kit on honda 13hp engine
3 Suggested Answers
  • 76 Answers
SOURCE: 13hp honda on hyd. wood spliter running normal at
try basic, drain the carburetor...
Posted on Dec 31, 2009
LandaNW
  • 45 Answers
SOURCE: 13hp honda motor what is the right psi for it
It will depend on the pump that you have but the most common versions will be the 13HP PC4-35324 which is a direct drive unit or a PG4-35324 which is a belt drive unit. In both cases the machine would be 4GPM at 3500PSI.
Sincerely,
Aron Kerr
Landa Northwest
www.landanw.com
800.247.8103
503.255.6508
Posted on Feb 14, 2011
Spring on recoil starter broke after using generator third time. now mcculloch says recoil starter is not available.have to purchase entire starter housing assembly for $105.00
Generic version of your starter is most likely available from small engine shop. Look for model and type of engine itself. Briggs stratton, honda, etc. model number if engine is usually on starter cover or stamped on block or tag attached. If the recoil part is riveted to housing you may need to either re-rivet or use screws to attach new rewind. Used parts are also available at small engine shops. Just take in the starter housing only for match-up. Good luck
Sep 13, 2010 | McCulloch 13HP 338 Cc Portable Generator #...
Sincerely,
Aron Kerr
Landa Northwest
www.landanw.com
800.247.8103
503.255.6508
Jun 03, 2010 | Honda Landa PG 3500 PSI Pressure Washer
Run fuel line from truck tank to 13hp honda engine
This will work if the 13hp engine has its own fuel pump to draw fuel from the tank. Sounds like a good idea, use as mush steel line as possible to prevent line damage and associated leaks.
Apr 17, 2010 | Air Tools & Compressors
How to replace starter ring on husqvarna yt130 with B & S 13hp engine. I have removed the flywheel. Nylon starter ring appears to be riveted on. Can I buy the ring only or do I buy the flywheel...
Briggs offers a kit to replace the plastic ring gear with an aluminum ring gear. Remove the gear by drilling the rivets and punching them out. The kit comes with bolts, ring gear, and starter gear, plus instructions. Go to your local briggs dealer with the model, type, code numbers of the engine. Aprox $40 cost. If you cannot find a dealer, I can offer the part to you. thanks, mowerguy
Nov 08, 2009 | Husqvarna Garden
Broken genarator
This engine is easy to tear apart. It's like taking apart an electrical motor. With a good set of tools you should be able to take it apart no problem.
Apr 09, 2009 | Electrical Supplies
13HP honda engine
Try running without filter if ok clean filter and put back. This is and air/fuel mix problem,did you adjust idle screw??
Please rate. Thanks
Mar 31, 2009 | Northstar Garden
13 HP Electric Start GX390 Logo
1,010 people viewed this question
Top Honda Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
Spud Howell
Mike Carew
Are you a Honda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
