Question about Sony Handycam DCR-TRV230 Digital Camcorder
Price value sony digital handycam 700x - Sony Handycam DCR-TRV230 Digital Camcorder
atlasuk2007
  • 85 Answers
SOURCE: sony 700X digital handycam
solution 1: Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times. solution 2: Turn off the camcorder. Remove the battery or disconnect the AC power adapter for 60 seconds. Insert the battery or reconnect the AC adapter. Turn on the camcorder. If the error message appears, service may be required. If your camcorder still shows the same error code, then you'll have to send in your camcorder for service additional info that might help: According to the manual, the error code C:31:xx:xx means an error that >the owner can fix by himself has occured and that by taking out the >cassette and replacing it or by disconnecting the battery pack and >fixing it back should solve the problem. Error "23" means: "S reel emergency during normal rotation", i.e. the problem is with the tape deck mechanism and specifically the supply reel.
Posted on Aug 21, 2007
  • 31 Answers
SOURCE: sony 700x digital handycam
error 31 is some kind of a problem with the cassette compartment, it's either won't eject it right now, or it's stuck otherwise. try to eject, if doesn't work, try "reset" button, if still no luck, replace the cassette compartment
SOURCE: I have a sony 700x digital handycam....
have all time C 23 31 flashing
Posted on Sep 04, 2008
welcomejee
  • 10594 Answers
SOURCE: error code C:31:42 on a Sony Digital Handycam DCR-TRV530
C:31:42 shows following error..
FG fault during normal drum operations.
Its related to drum assembly (video head) in camcorder and possible reason can be drum stuck with some thing, no power to drum motor etc.
Posted on Jan 19, 2009
mahhek
  • 662 Answers
SOURCE: hi where is the record button on sony handycam
It would be just below the view lens (From where you see the object)
It would be a button with red mark on it.
Posted on Oct 02, 2010
Hello, I have a Sony Digital8 Handycam 700x SteadyShot DCR-TRV 230. Can I bypass the tape cassette and record directly into a PC? If so, would I still need to insert a tape? Thank you for your help.
No, that's not possible unfortunately. The live stream would have much more data than the USB or firewire connection could handle, and your PC would have to be top notch spec wise to keep up.
Long answer short, no.
Mar 05, 2011 | Sony Handycam DCR-TRV230 Digital Camcorder
Hi where is the record button on sony handycam 700x. just bought it. thanks Ian
Oct 02, 2010 | Sony Handycam DCR-TR7000 Digital Camcorder
Transfering video ... but no audio is coming
normally, cameras send audio separately on a different cord. if it does have a separate audio cord, this will likely be plugged in to the blue input on the audio card of the computer.
Nov 01, 2009 | Sony Handycam DCR-TRV250 Digital Camcorder
I have a quick question about my Sony DCR-TRV350
dear sir
i have sony 700x digital200m optical 20x dcr-trv350 ntsc handycam , kindly let me know if device av cordless ir receiver ift-r20 can be used with my above mentioned camera
Feb 22, 2009 | Sony Handycam DCR-TRV350 Digital Camcorder
Need to install driver for sony digital 8 700x
Please mention exact model number of your Sony camera and Windows version in your PC to help you out.
Nov 27, 2008 | Sony Handycam DCR-TR7000 Digital Camcorder
HOW DO I SET DATE & TIME-ALSO GO FROM SP TO SLP
There is a built-in rechargeable battery in the camera and after approx 3 months it will be completely discharged if the camcorder is not used. To recharge: Connect camcorder to wall outlet using the supplied AC Adapter with the power switch turned OFF for more than 24 hours. (To keep the internal batter charged, try to plug the camera in every couple of months or attach a fully charged external battery for at least 24hrs). To set the clock: Set the power switch to CAMERA and then press MENU. Turn the dial to select CLOCK SET, scroll to the toolbox looking icon -it may say DEMO MODE next to it. Then press the dial. Turn the dial to select the desired year, month, day and then pressing the dial to set each as you go. For the tape speed go to Menu settings scroll to find Tape settings (TAPE SET), select REC MODE and from there you can change the tape speed from SP to LP. Hope this helps. I have the Sony Digital 8 Handycam DCR-TRV250 I purchased about 3 or 4 years ago (700x digital zoom etc).
May 21, 2008 | Sony Handycam DCR-TR7000 Digital Camcorder
Problem with sony 700x
Handycam should have came with software to install on your pc to capture and edit home movies.
May 19, 2008 | Sony Handycam DCR-TR7000 Digital Camcorder
Sony DCR-TRV240E Digital 8 Camcorder
Try this...
http://support.sony-europe.com/dime/camcorders/d8/d8.aspx?site=&m=DCR-TRV240E&site=odw_en_GB&odw_model=DCR-TRV240E
Apr 13, 2008 | E.Digital Sony DCR-TRV265E camcorder Pal
Sony 700x digital handycam
Aug 21, 2007 | Sony Handycam DCR-TR7000 Digital Camcorder
Sony Handycam DCR-TRV230 Digital Camcorder Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
