Question about Vehicle Parts & Accessories
Where is pcm located on a 2006 lincoln zephyr
    Filmmaker:
    Uploaded 5 video answers.
    Scholar:
  • 74 Answers
There are a few technical service bulletins about the PCM, TSB-13-4-17, TSB 06-21-11, or 06187. You may want to check your coil driver as well. Coil driver failure can inspire premature PCM failure. Diagram for the part is here.
http://www.fordparts.com/Commerce/PartDetail.aspx?n=%2bJjQu39tfmvkhh2FBVnLtA%3d%3d&id=265955558&m=2&search=true&year=2006&make=Lincoln&model=Zephyr
Posted on Feb 06, 2014
IS THERE A FUSE FOR A 2006 LINCOLN ZEPHYR DRIVERS POWER SEAT?
Fuse for the driver seat is No. 32.
Power distribution box fuses and description are attached for the reference.
lincoln zephyr fuse box bower distribution box-ulsfvzorca1mdsfkvpc0qdgs-5-0.jpg
http://www.autogenius.info/lincoln-zephyr-mkz-i-fuse-box/
Apr 24, 2017 | Lincoln Cars & Trucks
Im looking for the location for the passenger front seat fuse and lighter fuse in a 2006 lincoln zephyr
https://www.google.com/url?sa=t&source=web&rct=j&url=http://www.autogenius.info/lincoln-zephyr-mkz-i-fuse-box/&ved=0ahUKEwi-hvyVmbnTAhVI3IMKHVDFDcIQFggaMAA&usg=AFQjCNG91zFyi069xUH_l63W-q-_wjMNSQ&sig2=cw-4kEjMSR_1l-X1xubXEQ https://www.google.com/url?sa=t&source=web&rct=j&url=http://www.autogenius.info/lincoln-zephyr-mkz-i-fuse-box/&ved=0ahUKEwi-hvyVmbnTAhVI3IMKHVDFDcIQFggaMAA&usg=AFQjCNG91zFyi069xUH_l63W-q-_wjMNSQ&sig2=cw-4kEjMSR_1l-X1xubXEQ
Apr 22, 2017 | Lincoln Cars & Trucks
Location 2006 Lincoln zephyr's fuse boxes
Lincoln Zephyr MKZ fuse box Auto Genius
On this website (link below) you finde fuse box description and diagram for Lincoln Zephyr
Nov 20, 2012 | 2006 Lincoln Zephyr
Why won't my 2006 Lincoln Zephyr start?
Hello
The engine and automatic transmission in this vehicles drive train are fully electronically controlled by a computer called the PCM and TCM (Power Train Control Module, Transmission Control Module). When a problem like this or other drive-ability related problems occurs the computer stores a record of the problem (there are of course some exceptions to this, like the fuel pump, engine coolant temperature sensor and MAF sensor for instance) in the form of a fault code in its memory, to read these fault codes you must have the systems memory scanned with a special tool. Once the fault code(s) are read you then must perform the appropriate diagnostic testing to find and resolve the problem(s) DO NOT REPLACE ANY PARTS UNTIL A TRAINED TECHNICAIN HAS DIAGNOSED THE PROBLEM TO AVOID SPENDING YOUR HARD EARNED MONEY ON PARTS THAT MAY NOT CORRECT THE PROBLEM
Aug 30, 2012 | 2006 Lincoln Zephyr
Where is cabin air filter located on 2006 Lincoln Zepher
It is located under both front seats, raise your seats up, and back as far as they can go. You will see that they are round in shape, twist the plastic slightly, and remove them.
Aug 03, 2010 | 2006 Lincoln Zephyr
My 2006 lincoln zephyr's front turn signals quit working. I can't find a fuse location for turn signals. Is there one?
check the inside fusebox, at location f20, this is the fuse # location F 20, this fuse operates the dsp module which is the digital signal processing. check that fuse.also check F4. now look under the hood and check these two fuses in that box, fuse 23 (F23) and fuse 19 (F19). hope this helps.
Apr 16, 2010 | 2006 Lincoln Zephyr
2006 Lincoln Zephyr - Static on radio with rear window defroster
check for antenna ground if corroded relocalize the ground.
Jul 10, 2009 | 2006 Lincoln Zephyr
Vehicle Parts & Accessories Logo
180 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
