Question about Gateway MT6730 Notebook PC
Power light blinking on nv53a gateway - Gateway MT6730 Notebook PC
  • Gateway Master
  • 27,725 Answers
Your Gateway laptop comes with a series of LED lights that alert you to the state of your computer. You'll notice there are blue, purple and red lights that either blink or display solidly. Each light, blinking or solid, has a different meaning. The blue blinking light on your laptop indicates that it is in Standby mode. Your laptop goes into Standby when you close its lid without shutting down the computer. To turn this light off, you'll need to take the computer out of Standby mode, and if you want to ensure that the blinking blue light does not return, shut down the computer after each use.
Open the lid of your Gateway laptop and press the power button. Once Windows loads, enter your password if required. The blue light will no longer be blinking because the computer is no longer in Standby mode. Shut the laptop off when you finish using it rather than simply closing the lid to stop the blue light from blinking again. Click "Start" from your Windows desktop and click "Shut down." Change your computer's power settings to keep if from going into Standby mode when you close the lid if you'd rather not shut down your computer every time you use it. Click "Start" and click "Control Panel." Click "System and Security" and then click "Power Options." Click "Choose what closing the lid does" from the list of options on the left side of the window. Select "Hibernate" from the drop-down lists under "On Battery" and "Plugged In." Click "Save Changes." Your laptop will now bypass Standby mode when you close the lid and it will enter Hibernate mode instead. Hope it helps.
Posted on Jan 23, 2013
Gateway ethernet controller driver
Use a USB flash drive on the computer you can access the internet on and save the driver files onto it. Then transfer them to your Gateway NV53A laptop.
How to Save Files to USB Flash Drive
Jun 28, 2014 | Computers & Internet
  1. Plug a USB key into a computer you can access the internet with
  2. Get updated drivers from manufacturers site
  3. When prompted to save download choose the USB drive letter which you should see in My Computer/Computer on your 'desktop' screen.
  4. Save file(s) and them remove the USB key when safe to do so.
  5. Insert USB key into your Gateway NV53A and either run driver installer directly from USB key or copy files onto your Gateway.
How to Save Files Using Thumb Drive eHow
I have a gateway NV53a Batt went dead wont start correctly since
Try removing the battery and see if you have any issue just using the power cord. The laptop may be detecting issues with the battery causing it to malfunction. If that is the case just replace the battery with an OEM (original manufacturers) part.
Oct 27, 2013 | Gateway Computers & Internet
The VGA Port on my Gateway NV53A laptop has come loose. It can still be made to work if I position the vga plug upward at precisely the right angle, but that involves keeping the laptop held still, ot
There should be 2 small nuts holding the connector in place these are also used to secure the external monitor VGA connector to the computer. You can get them from a computer shop.
Apr 12, 2013 | Gateway Nv53a
Delete hardrive on a gateway nv53a
To delete a harddrive you would go into BIOS Setup, and remove.
(Main menu, or Standard BIOS options (setup)
Was there a previous harddrive, you installed a new one, and the old is still showing up, or what is going on?
http://support.gateway.com/s/notebook/2010/gateway/nv/nv53A/NV53Asp2.shtml
My intel indicates press F2 to enter BIOS Setup.
The best method I've found is;
AS SOON AS you press the Power On button, start tapping on the F2 key.
You may hear beeps as you do.
Those are Stuck key Error Code beeps, and it is you that is doing it.
Ignore them.
If you do not know how to navigate in BIOS Setup, or save changes; post back in a Comment.
Totally way off? Post back in a Comment.
Regards,
joecoolvette
Feb 22, 2013 | Acer Gateway NV53A36u
Clock resetting and power button malfunctioning on my Gateway NV53A laptop.
Replace the CMOS battery. In the Control Panel, Power Options, set to High Performance, open Advanced power settings, set Sleep and Hibernate to Never, Adjust other settings to your preference. Set Screen Saver Time. Always turn off the computer and unplug when not in use, it will prolong life and a reboot every day will reset the computer. I would say you have a issue with the outlet connections/plug. If you have a multimeter you can verify.
Jan 18, 2013 | Gateway Computers & Internet
Need service manual for gateway NV53A laptop
This manual may be found on the Gateway website.
See their support/downloads section.
Search using your notebook model number.
Take care!
damnor01
Sep 13, 2012 | Gateway NV53A24u Laptop
Problem finding bios battery on gateway nv53a laptop
Hi Maggie,
The battery looks like the image below and should be behind the RAM or the PCI covers.
Hope this helps.Thanks!
Dec 17, 2011 | Gateway Computers & Internet
Does not bootup and top light on power supply is blinking
Replaced the Gateway Power Supply, 450W.RDNT and the Gateway Power Distribution Board, 960/980 Servers. When the top light is blinking on the power supply, there is a power problem.
Mar 18, 2009 | Gateway 960 Series (gtwy960) Server
Gateway MT6730 Notebook PC Logo
660 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
