Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
BADGER GARBAGE DISPOSAL just humms. does not work.
I had problem with disposer, and then cleared every thing. Pressed the reset button, still no use. Any thoughts.
  • snowman_dumb Jan 30, 2009
    Thanks a lot pgh for caring to help. I looked with flash light and don't see any thing. I obviously miss something since I hear the humming sound. I don't know what else to do. Seems like time to replace with a new one.
    President:
  • 2,992 Answers
It sounds like the disposer has something jamming it. Try using the breaker wrench supplied with the disposer (or a suitable-size hex wrench) fitted into the socket on the bottom. Rock the wrench back and forth to see if you can loosen the jam. Another trick is to use a wooden rod (end of a broom handle, for example) to push on the blade to try dislodging the jam. Look inside with a flashlight to see if there is something that is easily missed. (I have found drink can tabs, coins and a shelf clip that way.)
It's also possible the motor starting capacitor inside the disposer or the motor itself is bad, in which case you would probably spend less on a new disposer than on repairing this one. But a jam is more likely.
Posted on Jan 28, 2009
Is there a reset button on badger 15ss?
Usually the reset button is located on bottom of disposal near where wire is connected..
Use your hair mirror to look at bottom of disposal.
More disposal resources for troubleshoot, maintenance, repair and installation:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Gene
Water Heater Timers Save Money
Feb 25, 2015 | In-Sink-Erator InSinkErator Badger 3/4-HP...
Is there an override button is not clearing garbage
If disposal is not running, then push red reset button located bottom of disposal.
If disposal is clogged, Clean out drain line under sink, and bottom of disposal under cutter blade.
Copy following link for clogged disposal.
Oct 19, 2012 | Badger 1 Insinkerator 76039h 1/3 Hp Feed...
Where is the reset button on the InSinkErator Badger 5, 1/2 HP Garbage Disposal Problems & Solutions?
Here is a tip that I wrote that will help you to figure out what is going on with your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed
heatman101
Jan 23, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
The badger 5 has just stoped working
There are three possible things.
1) Circuit breaker tripped
2) Wall switch gone bad
3) Reset button tripped on disposal
Reset is located near where wire connects to disposal
Nov 22, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
InSinkErator Badger 5, 1/2 HP Garbage Disposal: I have a Badger InSinkErator, it suddenly just sto...
Here is a tip the I wrote that may help you to figure out what is going on withyour garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed heatman101
May 18, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
InSinkErator Badger 5, 1/2 HP Garbage Disposal: my disposal just humms not sure where the reset bu...
It is the redbutton on the bottom of the motor...
heatman101
May 17, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I have a badger 5 plus garbage disposal (5-6 years) it humms
Yes, it sounds like you have a bad motor winding, not allowing the motor to actually work. It is time to replace. Hope this helps
Jul 16, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
829 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
