Question about Cooktops
Thermador Electric Cook Top Circa 1957-58 Model #
Does anyone know where the model number is located? There is a metal plate on the front underneath that has a Ser# ER 143407 and a Cat. # SU4-D and a listing for the Volts and K.W. However, nothing that says Model #. I've tried looking underneath the cooktop but I can't see anything so far.
SU4-D is your model number. This is a very old cook top. Older units have a catalog number and not a model number. SU4-D stands for surface unit 4 burners.
Posted on Mar 08, 2010
  • 979 Answers
Try looking on the inside of the door and also next to the frame. If not here, take of the back of the stove and you should find it there. Call the 800 number for that brand and give them the ser #.
Posted on Jan 28, 2009
Cooktop locked
May I get the make and model # of the cook top to help you more.
Jul 06, 2010 | Thermador CIT304ES (Electric) Stainless...
Want a narrow ceramic cook top / hob
Look at Baumatic 90cm Slimline 4 Hyperspeed Zone Ceramic Hob. Dimensions are 350mm x 880mm
Apr 26, 2010 | DeLonghi Cooktops
How do you remove the cook top on a GE profile model number JSP47SOH2SS
take off the knobs, unscrew the plastic underneath the knobs, take off the plastic cover. unscrew the four metal screws holding the the display panel on. remove the 5 silver screws across the top inside of the plastic cover front and the 2 black ones on the lower left and right sides. remove the to stainless steal stews on the sides of the stove towards the rear top. these should allow you to remove the cover once you unplug the two cables going into the burners.
Feb 26, 2010 | GE Cooktops
Thermador cooktop ignitors won't stop clicking
I have the same range top. I am looking for the switch assembly. Do you know where I can buy this part? Please email me if you do. prboardman@yahoo.com
Dec 30, 2009 | Cooktops
I have a cracked ceramic top on a thermadore induction cooktop. Can I get a replacement for it?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Model Number is always helpful when requesting information.
This part should still be available from a local parts outlet. You'll need model and serial and color. Model and serial are located underneath the unit on its bottom.
You won't like the price. Good Luck
Aug 31, 2009 | Thermador Cooktops
Red light on cook top remains on always.
Don't really need a wiring diagram, although there may be one inside switch area. (make sure to put it back again if it is there) Will need the full model number to get you the part number you need. (model number usually on a sticker near where the electrical wire enters the cook top)
Turn off power to cook top. Open cover to switches. Pull two "pilot" (usually smaller spade terminals) off the switch for the right front burner, and insulate each with a bit of electrical tape. Turn power back on to see if light now off. If yes, replace that switch. If no, replace those wires and repeat procedure with the next switch until you find the bad switch. Send a comment if you need additional help.
Feb 13, 2009 | GE 30 in. JP326 Electric Cooktop
Burner cap
The cook top should be bolted to the counter. Look under and look for brackets that attach the bottom of the cooktop to the sides of the counter. and also the model number should be somewere underneath. If you can get me the Model number I can get you the maintenance manual in PDF format.
Eddie Rentas
Tupper Lake NY
Jul 24, 2008 | GE 30 in. JGP336 Gas Cooktop
Obsolete Thermador
I am looking for Thermador part # 414-564 and Bosch part # AP2831995. Anyone ???
Sep 09, 2007 | Thermador 37 in. SGSX365 Gas Cooktop
Cooktops Logo
461 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
