Question about Honeywell Programmable Thermostat Heater
My honeywell pro th4000 thermostat heat goes to aux heat and is blowing out cold air.
hotuna
  • 288 Answers
SOURCE: Honeywell thermostat....Home cooling/heating system....Chromotherm III
On heat pumps, the normal setting is simply an air conditioner working in reverse. The EMT or AUX heat is a supplemental heating system using electric heating elements instead of the hermetic (compressor) system. As far as why the regular heat does not work it can be one of many things. low freon charge. reversing valve not functioning. The defrost cycle not working. Take your pick. you may want to call a service man to repair it as the electric (EMT) is not as efficient.
Posted on Nov 04, 2007
Therinnaiguy
  • 1420 Answers
SOURCE: Changing Thermostats
This is one where you will need a good control man or woman. The American Standard ASYST system is not intended for the homeowner to change out. It has a room sensor wire that others do not account for.
Posted on Jan 16, 2008
benmartinez
SOURCE: Heat pump that just blows cool air
I have a Honeywell heater i'll set my thermostat to 76 and ill turn on the heater and it would turn on... but when it get to 76 it turns off so when the temperature drops down and the heater clicks back on all i get is cold air .. it only works on the 1st time what to do ?
Posted on Dec 24, 2008
  • 3 Answers
SOURCE: wiring diagram to connect programmable Thermo to Heat Pump
I don't know if this will be helpful or not, but I just installed a new Honeywell and the Honeywell customer service guy helped me get the wires done correctly. The number is 800-468-1502.
Posted on Jan 05, 2009
koolbreezes
  • 540 Answers
SOURCE: furnace blows cold air
Sometimes the fans kicks in by time ---or by heat...even if the heat cycles dont starts . Is this gas or electric,, name brand,.... model # ect...ect..
Posted on Dec 19, 2009
My Honeywell thermostat isnt keeping my house cool even though the temp is set to 69. Currently 90 degrees in here
Its probably not the thermostat. The air conditioner may be stuck on heating mode. If its a reverse cycle, the reversing valve may be jammed so even when the thermostat is calling for cold air, it stays on heat. If the machine is on heating mode, it should be blowing cold air out of the outdoor unit of the air con. If its on cooling mode, the outdoor should be blowing hot air.
Apr 12, 2015 | Honeywell Heat/Cool Thermostat
Honeywell thermostat blows cold air on heat
Thermostats don't actually blow anything, the heating system might though. Check the breakers for your heat system, then call a heating specialist. They're really not that expensive.
Oct 06, 2014 | Honeywell Heat/Cool Thermostat
I have Honeywell Pro TH4000 series. The fan wiil not come on what do i do
Depends on what type of heat you have...gas, oil , electric, heat pump? Make sure it is the right thermostat for your heat source. Some thermostats have a switch on the back for fuel or electric.
Dec 08, 2013 | Honeywell Programmable Thermostat Heater
Aux keeps coming on on regular heat is there something wrong with heat
See if it happens only when your temperature of the room is more than 3 degrees of your setpoint temperature. Since you have a heat pump, the auxiliary (electric heat strips) is use for backup of the heat pump when it can't keep up. The heat pump will run by itself if it can maintain temperature within a couple degrees. If it is too cold outside to handle the load or you set the temperature more than 2 degrees past room temperature, the auxiliary will turn on. The thermostat has a memory of how long it takes to reach desired temperature. If it goes into auxiliary mode trying to satisfy setpoint during the last call for heat, it will start the next call for heat in both aux & heat pump mode until the thermostats algorithm (timed program) allows only the heat pump to run. Not sure if you have an air to air, or geothermal heat pump. The outside air temperature will affect only the air to air system ie. when the temps drop outside, the heat coming out of your vents will be cooler...the air to air systems drops efficiency when the outdoor air drops.
Nov 08, 2013 | Honeywell TH3210D1004 PRO 3000...
Replaced Bryant T-stat model TSTATBBNB001 with Honeywell t-stat
Hello,You forgot to wire the O terminal w1 witch is the reversing valve.It is important to check if old stat is using O or B in witch case B terminal=w1 leaving O unused.
Apr 21, 2010 | Honeywell Heating & Cooling
Your original wiring configuration seems to indicate that you have an air conditioner (not heat pump) and either a gas or electric furnace. If this is the case you may need a different thermostat for your application.
Apr 21, 2010 | Honeywell Heat/Cool Thermostat
Buzzing sound when aux heat comes on
Sounds like it could be a effiency function to warn you that the heat elements are on. Check your thermostat manual and see if you can turn this feature off. If this is not a feature then the thermostat may be wired wrong or something in the circuit may be trying to short out.
Jan 04, 2010 | Honeywell Electronic Programmable...
One honeywell to another
you need to program the thermostat for the reversing valve "O" it will tell you how to do this in the manual. you will need to chang from "O" to "B" or "B" to "O" depending on how its set.
Jun 24, 2009 | Honeywell Programmable Thermostat Heater
Wiring diagram to connect programmable Thermo to Heat Pump
Jan 05, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
119 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
