Question about Clarion DRB2475
No back light on display
When radio is on, there is no back light. Is this a wiring issue or is the LCD bad. The display is very dim.
    Scholar:
  • 116 Answers
I know that most Clarions have an "illumination" wire usually orange and or orange/white. If the unit only has one, then most likely it is for a "dimmer circuit" and not atraight illumination. Let me know. If by putting power on tat orange wire does not do it, then you have a bad "bulb" in the faceplate.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Posted on Jan 28, 2009
Which fuse is for the instrument panel back lighting?
Does the radio play ? Are any other back lighting components not lighting ? Does the HVAC control panel light up ? You probably need new radio !
The second interior lighting group includes lamps which may be dimmed. This group may use a combination of vacuum fluorescent (VF) illumination, LED illumination and incandescent lamps.
When the ignition switch is turned to the RUN position, the radio VF display turns ON at maximum brightness. When the park lamps are ON, all incandescent and LED back lighting turn ON at the dimming level indicated by the instrument panel (I/P) dimmer switch. At the same time all VF displays dim to match the indicated dimming level. The panel dimmer switch potentiometer is an input to the body control module (BCM). When the driver selects a dimming setting by moving the I/P dimming switch potentiometer, all incandescent back lighting lamps are provided with a specific voltage. When the I/P dimmer switch is moved from MIN to MAX, all VF displays, as well as all incandescent back lighting respond from minimum intensity to maximum brightness in response to the I/P dimmer switch.
Dose
Jul 14, 2015 | 2008 GMC Sierra 1500
My radio works on my 2004 jeep grand Cherokee but the time and station don't light up do I need to replace the radio
any thing can be fixed.! (my job that, before retired)
the question (only) is time and money?
if the labor is more than a new upgraded radio.
why fix old.?
is the dash dimmer working, and all other lights on dash bright
the the radio has issues. (stock) if not stock the wires are bad behind radio. the dial wire.
does the radio work? and dial right, can you see the stations, with a flash light, ? then the back light is burned out.
if VFD display or LCD dead , big time $$$ fix.
on mine , 04 i put a new , media only head end.
am/fm , USB , flashcard, aux in, radio
and have micro usb there, very tiny with 4000 songs.
no more discs and radio head is very tiny.
Sep 13, 2014 | 2004 Jeep Grand Cherokee
How do i replace burned out lightbulb in my in my cambridge soundworks cd - 740 clock radio ?
I believe the problem is either a faulty light sensor the unit has to dim the display when the lights dim since it was designed for bedroom use with alrms and snooze button. or it is simply a failure in the circuit that drives the LCDs. Mine has been dim for a long time but I can still see just enough to adjust the sound settings. I tune and set stations by sound. so the display has not been an issue since we do not use it for a clock or alarm. I doubt there is a fix for the dim display.
Mar 10, 2014 | Cambridge Soundworks CD-740 Clock Radio
Radio lights are out
what lights, the dial back lights, is it stock>?
the radios have 3 power sources
1 for radio and amp.
2: dial lamps (dim,) if the other cars dim-able park lamps work then
the radio lamps are bad, or not connected (1 wire)
3: memory. power.
my guess is the rad back lamps are dead.
so turn on the parking lights (Head ligths 1st click)
does dashlight up.? no, turn the dimmmer up.
do they light now? yes, and radio no?
if no radio lamp now, the lamp is bad or wired wrong or the fuse blew
that the dial feed wires to.
if not stock, any thing is possible, (infinity)
Dec 01, 2013 | 2007 Honda Accord Sedan
Pioneer deq-7600 lcd very dim, lcd problem?
The LCD display is failing, or the driver ic is the issue, or the B+ is to low causing the dimming effect, a resistor gone high in value would explain this.
Mar 19, 2012 | Pioneer Audio Players & Recorders
How do I replace backlight on my bc895xlt
Greetings,
The bulbs can be replaced,
Remove covers taking care of the speaker wire. Remove screw for the green wire on disp. board and then the two screws holding the display board in place. Carefully remove the metal shield can with the four locking tabs. there are four grain of wheat lamps, two on each side of the display 12v/60mA DC. lamp # 7219 and radio shack sell them They are located in the white rubber holders on each side of the dissplay. unsolder the wires, pull up rubber white holder, remove bulbs, remove rubber light covers and put these on new lamps, slide lamp wires into rubber holders and then holders back to display pcb. Solder wires into place and repeat on other side of display. Usual common sence applies, be carefull, ect...,.
Apr 10, 2010 | Uniden BC895XLT Base Scanner
Possible electric short. Lights dim on occasion(all lights, including headlights), clock/radio display went out for a couple of weeks then came back on and now the rear passenger brake light is out. Also...
squeal sounds like lose alternator belt and that would make sense if belt sliping lights will dim rear brake light probley a bulb radios dispaly may have short or just going bad
Feb 17, 2010 | 2004 Pontiac Sunfire
Oem Radio installation
*** 91 park ave with delco bose =
black = ground
dark green = lights on input
grey = panel lights
pink = on input
yellow = power input
orange = battery power input
nca = shield ground
tan = left fr spkr +
orange/black = left & right spkr -neg
lite green = right fr spkr +
nca = shield ground
dark blue = right rear spkr +
dark green/yellow = right & left spkr - neg
brown = left rear spkr +
purple/white = display dim output
pink = vehicle speed input
**** 91 park ave without delco bose =
grey = left front - neg
tan = left front + pos
dark green = right front - neg
light green = right front + pos
black = ground
dark green = display dim signal
grey = panel lights
pink = power antanna
yellow = ign input
light blue = right rear - neg
dark blue = right rear + pos
yellow = left rear - neg
brown = left rear + pos .
there YA go
Dec 27, 2008 | 1991 Buick Park Avenue
Dell inspiron 4150 video dim
The empty slot is for a mini-PC card, usually a wireless network card. The 2 wires are actually the antenna wires that connect to the wireless card. The dim LCD may be a problem with the LCD panel display, video controller or motherboard. Try connecting the laptop to an external monitor by connecting to the Video Connector located on the back of the laptop. If the display on the external monitor appears to be normal, then your LCD display panel on the laptop has a problem. If the display on the external monitor is dim then you probably have a bad video controller card or motherboard.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 25, 2008 | Dell Inspiron 4150 Notebook
Wont stay on
IF there is no display even with a flashlight, the P/S board is malfunctioning. Bad capacitors or LCD driver board circuit. Mine did this and it was bad caps, 4 of 8 were bad and a burned out chip on the P/S board.
Oct 20, 2007 | Proview PL913S 19" Flat Panel LCD Monitor
Car Audio & Video Logo
397 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
