Question about Refrigerators
How do I remove the water filter in a Whirlpool Refrigerator model ET9FTTXL?
    President:
  • 1,214 Answers
Rotate 1/4 turn to the left and pull.
Posted on Jan 28, 2009
What type/model/ brand of water filter do I need for the Whirlpool Roper side-by-side refrigerator with the model number: RS25AGXNQ00
There is a generic type of water filter that fits all Whirlpool and KitchenAid refrigerators with a water filter located in the base grill below the door.
it looks a bit like this: http://www.partselect.ca/11722132-2-M-Whirlpool-EDR5RXD1-Water-Filter.jpg
Here is one on amazon: Amazon com Replacement Roper RS25AGXNQ00 Refrigerator Water Filter...
Sep 05, 2016 | Whirlpool Refrigerators
Replaced water filter on a Maytag refrigerator it uses whirlpool filter. when filter is replaced and you try to use the water dispenser you get a loud grinding noise from the filter, how do you fix this?
I need to know which model you have, because i would explain the issue you have better. I thin it would be a MSD model and it could mean a board collision in the touch panel to the dispenser.
Please let me know your model so I can help you further.
Good Luck
Sep 01, 2013 | Whirlpool Refrigerator Water Filter
Jenn-Air Refrigerator JS42SEDBDA Model 12606032GJ was in house when I brought house. No user manual. Does this model have a water filter? The refrigerator has the words water filter,and underneath that...
Remove the compressor cover to locate the filter.
www.appliancepartspros.com has the filter.
http://www.appliancepartspros.com/Appliance-Parts/whirlpool-refrigerator-water-filter--puri-clean--item-number-ap4343710.aspx
Aug 20, 2011 | Jenn-Air JS42SEDBDA Stainless Steel Side...
Refrigerator part not cold
Manually defrost the refrigerator/freezer. Be sure that it's THOROUGHLY defrosted and that the defrost water runs freely into the tray underneath the refrigerator.
ALWAYS clean the bottom coils, a FREE fix that is the source of COUNTLESS problems with the refrigerator inside and out.
Plug it back in. If that doesn't solve your problem, you've either got a physical blockage between the compartments or the flap/linkage that controls air flow between them is stuck (closed).
If you don't know how to access these components, it's time to call the repairman.
Hope this helps.
Sep 12, 2009 | Whirlpool ET9FTTXL Top Freezer...
Whirlpool refrigerator - condensation, ?clogged drain
The stopped up drain tube is inside the freezer probably behind the rear wall. There should be screws in it to remove it. Remove any ice at the bottome and you should be able to see it. I don't know about the wheel.
Aug 14, 2009 | Refrigerators
Location ofwater filter(s) whirlpool modeled22dq
Hi, The filter is located behind the kickplate. You can see the handle for the filter in the kick plate. I believe you turn the filter handle Counter clock wise to remove it. It will tke a little bit of force. Yes this filters the water in the door.
Let me know If I canassist you further. Thanks
Vic
May 17, 2009 | Whirlpool ED2FHEXN Side by Side...
Trying to remove the water filter and front grill
To change the filter rotate counter clockwise. To remove the grill at bottom grab bottom lift up and out. also here is the manual.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=ET1FHTXMQ04&siteCd=WHRCOM
Good Luck and please rate FixYa!
Apr 11, 2009 | Whirlpool 21.8 cu. ft. Side-By-Side...
ICE MAKER NOT MAKING ICE &WATER DISPENSER NOT DISPENSING WATER. WIRLPOOL ET9FTTXLQ11
Check the water filter cartridge - possibly needs replacement. It should be near the bottom of the unit in the front.
Mar 28, 2009 | Whirlpool ET9FTTXL Top Freezer...
Refrigerators Logo
98 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
