Question about RIM BlackBerry 7100G Smartphone
Blackberry screen has the hour glass tilting motion and I tried taking out battery and putting it back but it will not reset
  • fpetrilli1 Jan 28, 2009
    please get me an answer quickly. i am travelling starting tomorrow morning and I need my blackberry to work
  • RIM Master
  • 1,800 Answers
Does it freeze??
Posted on Jan 28, 2009
  • Jalal Sordo
    Jalal Sordo Jan 28, 2009
    Performing a soft reset stops all applications on the BlackBerry device
    by pressing the ALT+RIGHT SHIFT(CAP)+DELETE keys.
    also
    Performing a double-soft reset stops all applications on the BlackBerry
    device and is nearly the equivalent of a hard reset. Timing however is
    critical. Perform a soft reset by pressing the ALT+RIGHT
    SHIFT(CAP)+DELETE keys. The screen will go blank. When the screen is no
    longer black, press the ALT+RIGHT SHIFT(CAP)+DELETE keys again. You
    should then see another blank screen followed by an hour glass.
    also
    TThe first step in troubleshooting a network, software or hardware error
    is often to perform a hard reset. With Java® based devices, this is
    accomplished by removing the battery, while the BlackBerry device is
    powered on. Hold the battery out for about 30 seconds, and replace. The
    BlackBerry device will reboot.
  • RIM Master
  • 13,433 Answers
Try a reset
hold down ALT + CAP + DEL and your Blackberry will reboot
White screen with the hour glass wont go away
try to remove your sim card and the memory card out of your unit and try to open it again
If that work then have it run for 5 minutes then turn off again put your sim card not your memory card, then turn it On again
inform us what happen
Nov 05, 2009 | RIM BlackBerry Curve 8310 Smartphone
Continous hour glass
This unfortunately happens from time to time when loading updated firmware or you dont have the updated firmware. Although the device won't properly boot you may be able to get Desktop Manager to recognise it - if so run the Application Loader and try reloading the software. Download the latest firmware from Blackberry website.
Jul 20, 2009 | AT&T Blackberry Curve 8300 Smartphone
An hour glass is on screen and will not go away,
try this method
2. You need to install a BlackBerry OS file that is specific to your device. The original version, as supplied by the carrier, is the safe choice, but you can use any model specific version. This is not supplied on your BlackBerry CD, Ref: 3 links to BlackBerry's download pages.
3. Once the OS has been installed, you have to prepare it for the device.
Select Start / Computer and select the Drive C: Icon.
Open Program Files / Common Files / Research in Motion / AppLoader.
Navigate to the bottom and delete the file Vendor.XML file.
4. You are now ready to restore your device. Verify that BlackBerry Desktop Manager is NOT running. Plug the device directly into the computer's USB port.
We are about to venture into the bowls of the beast. Windows is not suitable for this job, we are going to invoke the Command line interface with an option switch.
Windows XP: Start / Run... / Command
Windows Vista: Start / Command (type this into 'start search')
Jun 28, 2009 | AT&T Blackberry Curve 8300 Smartphone
Blackberry spontaneously switches off then hour glass
Mine was doing this for a while, However, i cleared up space on it by deleting apps, and fonts, and messages, etc. that i did not want on the phone and it discontinued this problem and also responded much faster. Its worth a try.
Jun 25, 2009 | RIM BlackBerry Pearl 8100
Screen says JVM Error 513 Reset
install Blackberry Desktop on your computer and download the latest Blackberry Phone software from your carriers webite and instal it on your computer. Then connect your phone WITHOUT the battery to your PC and Click on App Loader. Follow directions and install the Software. The Installation WILL FAIL THE 1ST TIME. Thats normal. This time connect the phone WITH the battery and try the same thing again and you will have a brand new phone. except your Data.
Apr 26, 2009 | RIM BlackBerry Pearl 8100
I put the battery in it shows no battery symbol on the screen
Hold in Alt, delete in backspace in immediately after putting the battery back in until you get the hour glass.
Apr 11, 2009 | RIM BlackBerry Pearl 8100
Hour glass constantly turns on
Try to reset - firstly by powering off, removing battery wait 30 seconds and then power back on.
Faling that do a soft reset hold down for a couple of second these ALT+RIGHT SHIFT(CAP)+DELETE keys
Mar 22, 2009 | RIM BlackBerry 7750
Blackberry Pearl, JVM Error 547
IF YOU HAVE A COMPANY PHONE - CALL TECH SUPPORT
IF ITS A PERSONAL PHONE CALL YOUR PHONE SERVICE PROVIDER ask if there is any special version of software you have to use.
try a hard reset (take the battery out wait 2 mins then put it back in) if that doesnt work...
BEFORE ANYTHING !!!! use the desktop software to backup your data (because you will be erasing ALL DATE on the device) on the BB (if you can) and save the file to the desktop. next go to https://www.blackberry.com/Downloads/entry.do?code=577BCC914F9E55D5E4E4F82F9F00E7D4you need to download (use pull down menu)blackberry desktop software 4.6 and the blackberry devicesoftware (FOR YOUR MODEL PHONE) install the desktop software first thenthe device software.. this can take maybe an hour (not including thedownload time) once your done use your desktop software to restore yourdata
GOOD LUCK - Please rate this solution :]
Jun 06, 2008 | RIM BlackBerry Pearl 8100
Blackberry Pearl
did it get wet? whats the sensor sticker look like?
Apr 02, 2008 | RIM BlackBerry Pearl 8100
RIM BlackBerry 7100G Smartphone Logo
19 people viewed this question
Top RIM Computers & Internet Experts
Trisha
Trisha
Nataly Roberts
Nataly Roberts
SANTHOSH
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
