Question about Fantech DB10 Pressure Switch Kit w/ Delay
Two switches with two hallway lights-one delays going on.
I have two hallway lights that are connected to two separate switches. The second light was added years after the original and a new switch was installed too. When I turn either switch on, the original light turns on immediately, but the second light takes about one to two additional seconds to turn on (it is very noticeable). If I immediately turn both off and then immediately switch them on again, both light up at the same time with no delay. It's almost as though the second light has to warm up. Could there be a loose connection in the wiring between the light switch and the fixture? I am thinking I could just cut the power, go into the attic and reconnect the two by tightening the wire nuts. Because it happens from both light switches, I don't think the problem is with either switch directly.
  • smajhood Jan 28, 2009
    I didn't even think of that. My house was rented for three years while I was overseas and I bet the bulb was replaced by the tenants. I'll check tomorrow and let you know. I sure hope it is this simple.
    It was that simple. I feel very dumb for not thinking about checking this first!
  • 37 Answers
What it sounds like to me is that the second light may have fluorescent bulbs - either the compact fluorescent type or maybe a circular bulb. The fact that when you turn off the switch and then immediately on and it works fine, also makes sense if that is the case.
Posted on Jan 28, 2009
Headlights delay 20-30 seconds before coming on with switch
It all depends on what kind of headlights. Most the relay is slowly going bad.
Feb 01, 2014 | 1989 Chevrolet K1500
1999 Dodge Intrepid with flickering Dash Lights and Wipers Delay Problems
the dash lights is a lose ground or power connection the wipers could be a couple things there is a wiper relay that may be going bad or the wiper motor is going bad could even be both
Jun 03, 2013 | 1999 Dodge Intrepid
I have two white wire bond together, then two red wires and two black wires how do I wire this switch?
You posted under 3-way switch.
Example of 3-way switch is a hallway with switch at each end of hallway.
If you have a different switch, then instructions below do not apply, so add a comment.
1) Your old switch has 3 screws: 1 dark screw and 2 brass screws.
New switch has same color screws.
If you can remember where wires went on old switch, then re-connect on new switch using color-coded screws.
This is why I learned to make notes or take a photo before disconnecting electrical device.
2) If you are uncertain where wires went on old switch, then we can test.
The testing takes more words than it does work, and it will resolve problem.
You are replacing one 3-way switch, but other 3-way switch is still in the wall and is wired correctly.
We will call the other switch: switch2
Move switch2 to down position.
Separate wires at new switch for testing.
Use ordinary two wire tester.
Tape tester leads to wood to keep hands away from power
Turn power ON.
Test each wire to bare ground wire.
Tester lights up on Hot wire. Mark this wire.
Now move switch2 to up position and repeat test.
Tester lights up on Hot wire so mark this wire.
>If same wire is Hot in each test, then this wire connects to dark screw. If this wire was also connected with another wire on old switch, then connect that other wire to brass screw also.
>If two different wires tested Hot, then these are the travelers, and each traveler connects to a brass screw. One traveler on one brass screw and other traveler on other brass screw, in any order.
Leave switch2 in up position. One wire is Hot and has power.
Test this wire to all other wires in box, except bare ground wire.
Tester lights up on Neutral wire(s). This wire(s) is not used in the 3-way circuit, so put a wire nut over Neutral.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on circuit.
Jan 11, 2011 | Leviton 5603-02W Decora Rocker 3-Way AC...
I have the unit wired and it does not wotk.I have black to black,red to red green to ground and white to white,any thoughts? Thank you
Electrician test wiring before connecting anything.
First of all, you don't mention what type of switch was replaced.
1) Leviton 6230 countdown timer is made to replace single-pole light switch only.
Single pole is where 1 switch controls the Load (light fan motor)
Your wiring sounds like 3-way switch.
3-way is where 2 switches control same Load.
For example a hallway usually has 3-way switches.
To confirm. If old switch has 1 dark screw, 2 brass screws, and 1 green screw, then that is 3-way switch. Use Leviton LTB15, LTB30, LTB60, LTB02, LTB12 countdown timer for 3-way.
Smarthome sells product and shows .pdf manual
http://www.smarthome.com/4255/Leviton-LTB60-1LZ-4-Button-10-20-30-60-Minute-Countdown-Timer-Switch/p.aspx
2) If old switch has 2 brass screws and 1 green screw then that is single-pole switch.
3) If you are replacing single-pole switch, here are testing & wiring instructions for Leviton timer.
Remove device and separate wires for testing.
Tape tester leads to wood sticks so hands are away from power.
Do not untwist wires that were twisted together before you started.
Turn on power.
Tester lights up on Hot wire. This wire will connect to timer black wire.
Now you know Hot wire.
Test Hot wire to each of the other wires, excluding bare ground wire.
Tester lights up on neutral. Timer white wire connects to Neutral wire.
If box does not contain Neutral wire, then timer white wire connects to bare ground.
Timer green wire connects to bare ground wire.
Timer red wire connects to wire going to Load.
Dec 26, 2010 | Leviton 6230M Decora Four Preset...
The bathroom light does not turn on, I changed the switch but now the light in the hallway does not turn on. The original switch was wired through the back but I have changed it to the side.
Is the bathroom light controlled by two switches?
Is the hallway light controlled by two switches?
What color wires are in the bathroom light switch that you changed?
Side wiring will not change the way the switch works.
Dec 12, 2010 | Leviton White 3-way Toggle Switch 15a...
I would like to use the 1301 switch but my house circuit has 2 black wires and 1 red wire which terminals do I connect the wires to on the switch?
I don't know the copper-brand 1301 switch
Internet photos of the 1301 show that it has two screw terminals, and a green ground screw
Switch with 2 screws is a single-pole switch. (plug green ground screw)
Sounds like you are replacing 3-way switch with 3 screws. (plus green ground screw)
3-way switches control hallway lights, with switch at each end of hallway.
I think you need to buy a 3-way switch.
How to wire 3-way switch:
Bare ground always goes to green screw
The key is the dark-colored screw.
Old switch has dark-colored screw >> mark this wire.
Attach this wire to dark-colored screw on new switch.
Other two wires go to either screw.
Nov 19, 2010 | Cooper Wiring Devices "COOPER WIRING"...
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
Replace two way light switch
It sounds like you have what is called a three way switch for the upstairs light. This means that the light is controlled in two locations. The extra wire you refer to as a loop is called the traveller it goes between the two locations. You need to use the proper type of switch for 3 way applications. Once you get that there will be three holes instead of 2. the traveller usually installs in the hole that is alone (usually 2 holes on the bottom and one on the top). Any 3 way switch will come with instructions, or you should be able to find diagram easily on line.
Dec 24, 2008 | Electrical Supplies
3 ways not wired correctly
Im not sure if you know what you got yourself into but i hope this helps. Sorry for all the words but this does take some reading if this is new to you.
http://www.homeimprovementweb.com/information/how-to/three-way-switch.htm
Dec 13, 2008 | Electrical Supplies
Fantech DB10 Pressure Switch Kit w/ Delay Logo
328 people viewed this question
Top Fantech Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Fantech Electrical Supply Expert? Answer questions, earn points and help others
