Question about Crock Pots & Slow Cookers
Hoffman induction cooker won't turn on - Crock Pots & Slow Cookers
Looking for an instruction manual for my pressure cooker: Tfal Clipso Easy
T-Fal has a number of their pressure cooker manuals on the support page: http://www.t-falusa.com/instructions-for-use/Products/Non-electric-pressure-cooker/csc/NonElectricPressureCooker . None are labeled the Clipso Easy. There are the Clipso, Clipso America and the Clipso Induction Compatible Pressure Cookers. On web sites advertising these models, they are all "Easy" pressure cookers with one-handed operation.
Please check the pressure cooker for a product number to find the correct manual. The different Clipso pressure cookers are very similar. The direct link to the Clipso manual is http://www.t-falusa.com/medias/?context=bWFzdGVyfHJvb3R8MTUyMTE3M3xhcHBsaWNhdGlvbi9wZGZ8aGZjL2hlZC85NDY0ODMyMzkzMjQ2LnBkZnxhMWU4NWQwODhiZWUwZGI4YmY1ZDE2MzA4YWNmN2E2YTUyMGM0YmFkOGRjZTQzNzIyODBjZTBkMGY2NTZhZTVi .
I hope this helps.
Apr 20, 2017 | Crock Pots & Slow Cookers
Repair induction cooker
>> call a service agent with induction cooker experience
Sep 27, 2013 | GE Electric Induction Cooker
Why the induction cooker not getting power supply
might not be good any more you might need a new one.
Jan 05, 2013 | GE Electric Induction Cooker
I have an all-clad slow cooker that won't get any power
Oh thats a pitty these things happens all the time. These devices working under high temperatures, working once and then turn off until the end of time. Advice you to send it to service if you have guarantee. Else somebody with technical knowledge must check where the problem is by using a test light first then treatment begins.
Nov 05, 2012 | All-Clad 99009 Stainless-steel 6-1/2 Quart...
All clad slow cooker won't heat up.
I tried to locate the manual with google, and had luck to find this page, they have the manual!
Enjoy my help.
Sep 20, 2012 | All-Clad (HCOF8H2MZQ) 65Quart Slow Cooker
My cooks essentials technique pressure cooker will not turn on. It's like no power is reaching it. I've plugged it into outlets, but it won't turn on.
I had no power on my cepc800. Since parts are not available I had my husband tear it apart. If you are not electrically inclined don't try it....the problem in mine was a high temp resistor, which was bad. The problem was solved with a $2.50 resistor from our local electronics store.
May 21, 2012 | Select Brands Crock Pots & Slow Cookers
I can't get my 17quart pressure cooker to seal. I was looking for an online manuel so i could find out why.
Take the rubber ring out of the lid.
Wash it with warm soapy water.
Dry it.
Oil it with vegetable oil.
Now do you see how the rubber ring has a groove around it on the inside? Push your thumb into the groove and work it around the ring, you're trying to spread the rubber V out.
Put it back in the lid and take it for a test run.
In the future store your cooker with the lid upside down on top, keeping it closed will ruin the seal.
If it still won't seal replace the rubber parts, you can get a kit for your cooker from presto.
Regards
TickMagnet.
Aug 08, 2011 | Presto 01282 Aluminum Pressure Cooker Slow...
Crock Pots & Slow Cookers Logo
Top Crock Pots & Slow Cookers Experts
tsalagi152
charles
Irene Tulloch
Are you a Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
