Question about Samsung Digimax S630 Digital Camera
It won't power on
I had my Camera Plugged into my PC because I was uploading videos. About an hour later, I hear 3 beeps and my camera won't turn on anymore! The green light appears fine, and when I press the power button, I hear a little tiny *click*.
  • jbillz May 23, 2008
    I have the same problem. Did good batteries work Jamall?
Batteries are too low. Install new alkaline batteries or better yet metal hydride batteries that have been fully charged first.
Posted on Sep 07, 2007
SOURCE:
When I install the c613 usb cable into my usb port, it does not transfer pictures anymore, and makes a beep sound...why?
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Mar 16, 2012 | Kodak EasyShare C613 Digital Camera
Video has no sound
the camera itself does not have a speaker, but it records audio and you can hear it on the computer.
Jun 14, 2010 | Kodak EasyShare C180 Digital Camera
Playstation not registering with hdmi or video mode suddenly
Please try the following steps :-
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep once when you press it, then once more 5 seconds later. Let go of the power button when you hear this second beep.
Step 3. Wait for the PS3 to reset display settings back to standard.
Hope this helps
Nov 05, 2009 | Sony Playstation 3 (PS3) Console
When trying to power up hear 3 beeps and camera turns off.
Make sure the batteries are good and in right. If it keeps doing it you might be having a problem with your lens opening up and staying open, I had a camera that did that to me, and the lens had been knock and wouldnt open properly, check that out. The lens was out of range from normal and would automatically shut down
May 09, 2009 | Cameras
My computer is not showing when my camera is plugged in
Make sure the camera is turned on, plug the USB cable into your PC first, then into the camera, wait for a beep from your PC to show it has recognized the hookup, then go to "My Computer" and look for the Fuji icon. Don't unplug the camera anytime the lights are flashing on it.
Mar 21, 2009 | Fuji FinePix S1000FD Digital Camera
My philips pt44434 digital camera is dead
The reason why your camera is beeping 3 times and then shutting off is because it is dead. Charge it for a couple of hours or so and it will turn on and work again.
Mar 08, 2009 | Philips PT44434 Digital Camera
Camera wont upload videos
Hi there. I would like to help you.
Turn the camera off and connect the usb cable between the camera and the pc. Turn the camera on. Go to My Computer on your pc. Do you see the camera as one of the drives in the list? If not, do this:
Turn the camera off and disconnect it from the pc, and turn it back on.
While in live view, hit the menu/ok button.
Scroll to the right to the the icon with the wrench (set up menu).
Scroll down to usb configuration and press the menu/ok button.
Highlight Disk Drive, then press the menu/ok button.
Turn the camera back off, and reconnect it to the pc.
Turn the camera back on.
You should now see it as a drive. Open the folder and find a video you recorded and try to play it.
Let me know if this works for you. You can leave a comment and we'll get it worked out. If it does work, feel free to rate this solution a fixya.
Rob
Feb 23, 2009 | HP Photosmart M425 Digital Camera
Uploading video to Mac
You can't transfer videos through USB. You will need a Firewire 6-pin cord and use it to connect from your MAC to the Camcorder. Only then you can transfer videos.
Jun 16, 2008 | Video Cameras
Samsung Digimax S630 Digital Camera Logo
90 people viewed this question
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
