Question about Gateway MT6730 Notebook PC
Hi i have a gateway nv53a and the screen is loose on the left side the charger also plugs in on the left side, whenever i plug my charger in, the power light begins to blink when my screen is at a certain angle, is there a way to fix ths
  • Gateway Master
  • 7,627 Answers
Sounds like the AC jack has been damaged, due to pulling on the cord. Why is the monitor loose? Dropped? Has it had a hard life?
Posted on Jan 23, 2013
  • rougethebat6
    rougethebat6 Feb 03, 2013
    the screen is loose most likely from being used so much.
  • max carson
    max carson Feb 03, 2013
    Have you tried to tighten the hinge screws?
farhangM
  • 64 Answers
SOURCE: Gateway Laptop not charging
It sounds like defective power jack. Bring it to a reapir shop.
Posted on Dec 01, 2008
  • 50 Answers
SOURCE: Gateway laptop powers up but screen does not come up.
See if you can attach an external monitor to your laptop.If you can and you can see your display on the monitor the it is a faulty laptop screen .If you see nothing on the x monitor then the graphic card/chip is fried.
Posted on Dec 08, 2008
  • 27 Answers
SOURCE: Gateway not turning on with or without battery/AC adaptor
these people are right and there is definitely some hardware issues with your computer...which can be repaired but not really worth the money or effort.
Posted on Feb 17, 2009
cowboytech
  • 69 Answers
SOURCE: screen on my laptop will not work. Black screen.
Test if it works on external monitor. If it does, then turn the computer on, remove the battery, then reinsert the battery. That little trick has worked several times for me and my customers. If the external monitor does NOT work, then you probably have a bad video chip in the computer's motherboard.... by the time you fix it, you could almost by a new machine.
Posted on May 25, 2009
SOURCE: Gateway NV52 Laptop charger sound.
I don't know if this will work with Vista but in Windows 7 you can go to the speaker icon in the taskbar and click on the icon above the volume control. This will take you to the sound properties. Click the levels tab and mute the PC speaker. This worked for me.
Posted on Jan 30, 2010
Gateway ethernet controller driver
  1. Plug a USB key into a computer you can access the internet with
  2. Get updated drivers from manufacturers site
  3. When prompted to save download choose the USB drive letter which you should see in My Computer/Computer on your 'desktop' screen.
  4. Save file(s) and them remove the USB key when safe to do so.
  5. Insert USB key into your Gateway NV53A and either run driver installer directly from USB key or copy files onto your Gateway.
How to Save Files Using Thumb Drive eHow
Jun 28, 2014 | Computers & Internet
Black screen flash bios
You don't need to access the BIOS to format your laptop. Put the Windows disk in the optical drive and then select format when you reach the correct prompt.
May 06, 2013 | Gateway Computers & Internet
My phone will not charge
You probably tried taking the battery out and using an eraser, clean the terminals of the battery, replace do not power phone on, plug in charger and see what happens.
Aug 03, 2017 | Alcatel Lands Phones
The VGA Port on my Gateway NV53A laptop has come loose. It can still be made to work if I position the vga plug upward at precisely the right angle, but that involves keeping the laptop held still, ot
There should be 2 small nuts holding the connector in place these are also used to secure the external monitor VGA connector to the computer. You can get them from a computer shop.
Apr 12, 2013 | Gateway Nv53a
Clock resetting and power button malfunctioning on my Gateway NV53A laptop.
Replace the CMOS battery. In the Control Panel, Power Options, set to High Performance, open Advanced power settings, set Sleep and Hibernate to Never, Adjust other settings to your preference. Set Screen Saver Time. Always turn off the computer and unplug when not in use, it will prolong life and a reboot every day will reset the computer. I would say you have a issue with the outlet connections/plug. If you have a multimeter you can verify.
Jan 18, 2013 | Gateway Computers & Internet
It isn't charging
For this kind of issue, please follow up the following steps to check:
confirm the battery and ac adapter connect the laptop normally.Maybe the bad connect lead to this problem. If there are no lights when you turn on laptop, one of possible reason is that your adapter is malfunction.
the second possible cause is laptop dc jack failure. If the dc jack is broken or loose, you are required to replace it or repair it.
Another possible reason is that there is something wrong with laptop motherboard. For this situation, it includs two kinds of possibility,a failure in an electronic circuit and BGA malfunction.
For more detailed reasons and solutions, please have a look at the following article:http://www.ifitjams.com/lappower.htm
Oct 28, 2012 | Gateway NV53A NV55C NV59C NV73A Acer...
Problem finding bios battery on gateway nv53a laptop
Hi Maggie,
The battery looks like the image below and should be behind the RAM or the PCI covers.
Hope this helps.Thanks!
Dec 17, 2011 | Gateway Computers & Internet
I dropped my laptop and now the battery will not charge.
Most likely its the DC Power Jack. Happened to me. You can find the part online by searching for "450ROG DC Jack" and then just resolder yourself or take it to a repair shop.
Jan 19, 2009 | Gateway 450ROG Notebook
The socket where you plug the charger into the laptop is loose and now will not charge. where can i send it to be fixed and how much will it cost? I am in Niagara falls, ONtario
Hi
This is typically caused by tension on the plug. For instance, you allow the charger to dangle and hang on the plug. This causes poor contact and the socket gets hot and melts.
If you go to the manufacturers they will charge you for a new mainboard. Your best bet is to take it into a local TV/Hi-Fi repair shop and get a quote.
Aug 15, 2008 | Gateway Computers & Internet
Gateway MT6730 Notebook PC Logo
62 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
