Sylvania electric fireplace with 28" mantel mayhill
2 Suggested Answers
sales50056
  • 72 Answers
SOURCE: My electric fireplace won't come on. We changed the light bulbs. Nothing will work. What do I check now
https://www.heatsurge.com/help/service-store-locator
Customer Service
1-800-924-7964
Mon - Fri: 8:00am - 9:00pm EST
Sat - Sun: 9:00am - 6:00pm EST
custserv@heatsurge.com
Posted on Dec 10, 2012
How to put the mantel and flue parts back on in the fireplace
Fireplace and Chimney Parts: Diagram and Anatomy
https://www.highschimney.com/.../parts-chimney-anatomy-fireplace-chi...
Nov 30, 2011 - A chimney is made up of up to 22 parts. ... Mantle - Also known asmantel piece or mantel shelf, this piece of hardware is more than a .... I have an old Blaze King Fireplace Insert that was purchased back in the mid 1980's.
How to install a wood burning fireplace insert - Hearth.com
www.hearth.com/econtent/index.php/articles/install_insert
A Heatform is a metal firebox which is built into a full masonry chimney. ... The distance to the adjacent wood trim and the mantle. ... All the way back in the fireplace, or out on the hearth? ... Rockford Chimney Supply - We are the best source forChimney liners and Stainless steel chimney liner kits to install your insert or ...
Dec 20, 2015 | Heating & Cooling
Flames wont move
There should be a small electric motor that turns the wheel that looks like flames. That little motor may not be working making it look like the flames don't work. May have to replace the motor.
Dec 03, 2014 | Classic Flame Nantucket Corner or Flat...
The flame effect quit working in my Brittany Electric Stove Heater, Model #BESBY-1500. How can I get a replacement flame effect?
Typically the flame effect is accomplished when a motor turns a rod with polished metal strips on it. The strips then reflect the light onto the back of the glass. The the rod rotates, the reflection moves giving the effect of the flames moving. If the lights work on your unit then the motor has most likely stopped. It would need to be replaced. A quick internet search turned up nothing for that company so you may need to go back to the store where you purchased the unit to get the part. Once you have the part, you will need to disassemble the unit. Some units are simple (like removing the fake logs) and some units are more involved (like removing access panels from the back or bottom).
Mar 10, 2014 | Vendor Development Group Inc Borgen...
My problem is I have a electric fireplace the insert is a colemen and the heater stoped I bought it a Costco about 4 years ago
It may need repairing, do not take risks trying to fix it without an expert. But its 4 years old so its better to replace it with new.
Dec 15, 2013 | Leisure HOMEPRIDE Electric Fireplace...
Customer Service
1-800-924-7964
Dec 09, 2012 | Leisure HOMEPRIDE Electric Fireplace...
Thinking of mounting my sony bravia lcd 45" on the mentel above the gas fireplace. Is it the right thing to do
It should be fine to mount your t.v. above your mantel. As flat screen t.v.s become more popular more and more people have started mounting their t.v.s over the fireplace.
Aug 06, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Having trouble mounting a LC420SS8 VESA mount
There are 6 mounting screws located on the back panel that can be used as mounts points if you wish to construct a DIY mount (or if you don't want to purchase the official mounting bracket). See the manual for their exact locations.
I used 2 of these screws (the top two) to anchor a twisted steel cable that I designed to work in the same manner as a picture frame cable mount. I then drove a masonry nail into the brick chimney above my fireplace, and connected this steel cable to that mount point. The TV is mounted there, much like the way you would hang a painting (a very large & heavy painting). The bulk of the weight is supported by the front edge of the TV, which rests on a brick mantel that is part of my chimney. The steel cable, while strong enough to fully support the TV, only acts as a balancing wire, or to catch the TV should it topple forward off of the mantel.
Be sure you know how to work with steel cable and have a strong anchor point if you try to use this method. DO NOT USE THIS METHOD FOR DRYWALL ONLY APPLICATIONS. USE FOR EITHER WOOD STUDS or MASONRY APPLICATIONS ONLY.
Apr 05, 2009 | Sylvania LC420SS8 LCD TV
Distance over gas fireplace
Both LCD TVs and plasma TVs get hot, though plasma TVs tend to be a bit hotter in my experience. Also, plasma TVs are going out of fashion.
A lot will depend on the construction of your fireplace. If it's brick it should insulate fairly well.
Either way, I would recommend a mounting solution that does not put the back of the TV flush with the wall. Get one that tilts. I would avoid the "arm" style ones as that will put additional strain on the mounting.
Remember to think about how you want to run your power and video cabling as well!
Apr 06, 2008 | Televison & Video
Heating & Cooling Logo
19 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
