Question about Michael Kors Watches
MISSING SCREW ON BAND OF MK5411
IS THERE ANY WAY TO JUST GET A REPLACEMENT SCREW WITHOUT HAVING TO SEND WATCH IN FOR REPAIR?
  • 2039 Answers
SOURCE: Lost screw
go to any jewelery store cheers
Posted on Jan 19, 2008
escapement
  • 2334 Answers
SOURCE: Adjusting the Band...the damn screws!
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Mar 26, 2009
escapement
  • 2334 Answers
SOURCE: how to shorten the watch band without breaking it
Job done!
Posted on Apr 09, 2009
escapement
  • 2334 Answers
SOURCE: My Cartier Santos Stainless/gold Screws watch band
Only CARTIER itself will solve it. There is no way you can repair it outside CARTIER. Contact CARTIER and ask what the cost would be. Be prepaired to pay a lot.
Posted on May 19, 2010
gemineye61
  • 831 Answers
SOURCE: Where can I buy replacement
Try this link:
http://www.skagen.com/service/orderWatchBandParts.fx
Posted on Aug 09, 2010
My watch broke and the main link piece that connects the band to the watch is missing how do i replace that piece to my watch my arm feels bare without my watch.
Hello collay1,
I understand what you mean.. You can just go to any watch repair center and they should have a spare part of what you need. Many people have had that kind of problem.
Nov 08, 2011 | Wittnauer Crystal 10L02 Watch for Women
Missing screw to hold band together need replacement
Most jewelry stores--or even jewelry counters in department and discount stores like Walmart--keep a supply of replacement screws for when one is lost while changing a watch band. Ask around, show them your watch, and you may even get the right screw for free!
May 06, 2011 | Field and Stream F187GWBS e by Field &...
The clasp broke from my Fossil watch. Can the
mcdevito75 here, Without seeing the watch it"s hard to tell, but I would figure the clasp could be repaired, but the cost may equal a new band and clasp. Look for a small watch repair shop in your area and compare repair cost of the clasp with that of a new band.
Jul 06, 2010 | Fossil Watches
I just bought a diesel watch from ebay model no DZ7068 and for some reason the wrist band doesn't tighten.. i got confused is there any solution for this? thanks chris
mcdevito75 here, Without seeing the watch NO. Best Bet, visit a small watch repair shop in your area and see about band adjustment, Most likely your missing something on the band you have to use to adjust for your wrist size.
Jun 28, 2010 | Watches
We missing all 4 screws on my concord watch
Try taking your watch to your nearest repair shop and discuss it with them.
They may be able to have them replaced for you or they may recommend that you send it back to the maker.
Jun 10, 2010 | Watches
One of the screws that connects the band to the body of the watch fell out. Is there any way to replace screw without sending it in to Nike? What size screw would I need if I went to the hardware store?
It is unlikely that any hardware store will have the size of screw that you need, since watch screws tend to be much smaller than are generally available.
The best place to go is a watch shop. They should be able to get it replaced for you.
Feb 21, 2010 | Nike Mettle Sledge Watch WC0040 096
Nautica Compass watch
Any local watch repair shop will fix this.
Jan 10, 2010 | Nautica Compass Chrono Date Leather Set...
Pin that holds metal band clasp is missing
If it is only the pin that holds the metal band, this is an extremely inexpensive part that is available at most stores that sell watches.
May 24, 2009 | Casio G-Shock MTG900DA-8V Wrist Watch
Missing screw and band for Casio Alarm Chronograph mod 388
I am not sure that i have a solution but i am 100% intrested int hat watch mine has the same problem and it was my grandfathers, i sure would like to get a hold of you!!!! mandy laesser at g mail, thanks!
Nov 19, 2008 | Casio DW290 1V Classic Alarm Chronograph...
Replacement band for nike watch wa0018 oregon alt
I wear the smaller, womens' version of the Nike Oregon. Nice watch. I was attracted to it by the replaceable battery feature, but found out the strap goes long before the battery and the joy of ownership goes out the window with the price of Nike wrist-band replacement. I held onto my broken banded watch for awhile, and came up with a solution. First, don't try removing the screws that secure the watch-band pins. Not sure how they work, but I tried several times without luck. Even had a jeweler look at it without success.
I went to Kohl's and purchased a black velcro Timex replacement band for $8. Again this is the for the smaller version of the Oregon. The width of the timex band in 3/4". It includes a elastic band to secure the watch. This elastic band runs under the back of the watch and over the two pins. It is secured to a faux leather tab (with emblems), which is in turn attached to the velco band. Using a razor knife, I detached the faux leather pad from the velcro band and ran it under the watch pins, then reattached it with a touch of Gorilla glue. Be careful to wipe off any excess as Gorilla glue expands as it dries. Finally I blacked out the Timex advertising with a black felt permanent marker.
No reason to think this wouldn't work on the larger, mens' version of the same watch.
Apr 18, 2008 | Nike Oregon Series WA0019-001 Wrist Watch
Watches Logo
211 people viewed this question
Top Michael Kors Watches Experts
noel
noel
Andrew Taylor
Andrew Taylor
Are you a Michael Kors Watch Expert? Answer questions, earn points and help others
