Question about IBM Infoprint 1120 Laser Printer
Ibm infoprint 1654 955 error code - IBM Infoprint 1120 Laser Printer
  • 9 Answers
SOURCE: IBM Infoprint 21- 651 HW error
Look in Printer Manual (usually in the back) for error codes.
Try cycling power including unplugging AC cord from printer for 1/2 hour.
Posted on Apr 25, 2008
SOURCE: resetting IBM infoprint 1552 maintenance counter
Go Here: it's a PDF file which explains how to reset the printer's maintenance count.
http://www.marketpoint.com/files/pdfs/mk_ibm_1532.pdf
Posted on May 15, 2008
  • 32 Answers
SOURCE: IBM Infoprint 1532
There is probably a small piece of paper in the back of the printer in the fuser. Shutdown the printer and wait a few minutes as this part is hot. You may need to remove a few screws to take off the back cover and check inside the fuser.
Posted on Jul 24, 2009
  • 32 Answers
SOURCE: IBM infoprint 1312 toner and error light.
If both Lights are solid, it means that the top cover is still open and the toner is low. Please make sure the top cover is closed all the way. If the toner light is blinking and the errror light is solid, it means there is a toner cartridge error. Please try a new cartridge. If that solves the issue, then you should return the damaged one.
  • 32 Answers
SOURCE: how do i rest maintenance
You need to enter the config menu, by turning off the printer. Hold the middle button and right arrow and power the printer up. Continue to hold the two buttons until you see Performing self test. Then you should see config menu. Scroll to Reset Maintenance count and select it. When it returns to the previous menu, you can restart the printer and the error should be cleared.
IBM Infoprint 1532 giving error code 922.14 -service fuser error
There is a heater control problem in the fuser.
The fuser is the assembly of heated rollers in the rear of the device.
The most likely cause is either a blown heater element, or perhaps a faulty temperature sensor.
Usually we fit an exchange fuser assemblt to fix this.
Feb 04, 2010 | IBM Infoprint 1532 Laser Printer
Getting service code 914 on a IBM infoprint 1145
Service code 914 does not exist. If you meant 941, that is a tray 1 lift motor issue.
Jun 16, 2009 | IBM Infoprint 1145 Laser Printer
IBM infoprint 932 service printhead error
go on line and type in
ibm infoprint 1352 laser printer error 932
enter
or
ibm 1352 infoprine error message 932
rod
Feb 06, 2009 | IBM Infoprint 1352 Laser Printer
IBM INFOPRINT 1352
check for paper jam in duplexer - or it is not seated correctly. power cycle printer after reseating to re-init printer.
Nov 17, 2008 | IBM Infoprint 1352 Laser Printer
Infoprint 1120 929 service toner sensor error code
The problem is caused by one of the following (normally it's the cartridge that's faulty, very common on Lexmark's and IBM Infoprints)
The toner sensor is not operating properly, the developer
drive assembly is not operating properly or the print
cartridge is defective
Jun 09, 2008 | IBM Infoprint 1120 Laser Printer
Apr 25, 2008 | IBM Infoprint 21 Laser Printer
Mar 10, 2008 | IBM Infoprint 1312 Laser Printer
Install of IBM infoprint printer drivers
make sure you are logged on a the Administrator to the computer then try installing..
Dec 26, 2007 | Office Equipment & Supplies
IBM Infoprint 1120 Laser Printer Logo
29 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
CheckitRight
CheckitRight
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
