Question about Dell Inkjet 720 Printer
720 and 540 Dell printer communication problems
I had this solved a few years ago, but my computer crashed, and I can't remember how to fix it. For some reason, the pc will not recognize both drivers and I need to check the box (or uncheck the box) next to
statmon.exe
but I can't seem to find the place where this is.
Help!
  • klockie Jan 28, 2009
    When I first got the computer and printers, I had the same problem. I reinstalled/installed a million times. Seemed like the last driver installed would be the one that would work. They sent me a new printer--the 720, sent in a repairman who tried uninstalling/reinstalling both printers, and even replaced the hard drive in my computer, ugh! Finally, the serviceman contracted by Dell called someone in Texas, and she said it was the statmon.exe, had him pull it up somewhere in configurations, click off (I believe) the box, and the problem was fixed, all in about 2 minutes. That's what I am trying to find. Thanks for your reply.
Sounds like you are looking for System configuration utility.
Click Start and then click Run and type MSCONFIG (in Vista, I believe you just type it in the box next to the bottom of the start menu).
Select the Startup tab and untick the StatMon box. Restart the computer. A "warning" will open on reboot saying a bunch of verbage about the fact that you just changed the "startup settings" (or something like that). Just tick the "don't show me this again" box and click OK.
HTH,
Futile
Posted on Mar 14, 2009
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came withthe printer. When the software program asks you to connect theprinter to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 28, 2009
Screen crashed to flickering gray screen
Try a roll back of the Graphics driver. Have you done any Graphic Updates? Install the driver from the DELL or Windows Update website. Does it work with a external monitor? When you boot in safe mode your machine uses the Basis graphics driver. Is the monitor OK when you boot in safe mode?
Jan 07, 2013 | Dell Inspiron 1764 Laptop
Two days ago, my Dell 2135cn decided to start printing with an approximate 2 inch margin at the top of each page, but only when I am sending something to print from the computer itself. It does not do...
That happened to me, too. One of my employees fixed it. She found that someone (prboably me - but I don't remember) set the paper size to A4. She set it back to letter size and it solved the problem. I hope this helps!
Nov 03, 2011 | Dell 2135cn All-In-One Laser Printer
I have an HP Laserjet CM1015 Priner/scanner and an HP pavillion running Windows Vista. When I try to scan anything it says an error occured communicating with scanning device and check it is connected...
I had this too on my Vista. I re-installed the original software that came with the printer and the scanner then worked OK. My problem was always triggered when HP automatically downloaded 'updated' software, so I would disable the update feature as it only causes problems!!
Hope this works for you.
CK39
Dec 17, 2010 | HP Color LaserJet CM1015 Printer
Dell Inspirion 530 won't communicate with Dell V305 printer
The problem could be because of ONE out of FIVE problems listed below. Try the steps recommended and it should fix the problem.
Thanks,
Abhishek
Jun 26, 2009 | Dell V305w All-In-One R840635AU InkJet...
Dell V305 Printer No communication
wolfhaus: Did you try creating another user account 'Administrator' or 'Standard' and see if it will print from that ?. Let me know if this helps or not.
Mar 10, 2009 | Dell V305w All-In-One R840635AU InkJet...
Richo 1515 MF Error message: 12320 couldn't find the scanner.
This is a message on your PC...not the machine itself obviously? Was this scanner ever configured to work on your PC? If not, then follow this link to my comments to someone else about this machine:
http://www.fixya.com/support/t1718617-ricoh_1515mf_scanning
Feb 27, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Dell AIO Photo 926 will not operated at all
Try changing your firewall, it worked for me. I got my 926 a year ago with my Dell and had no problems until I replaced my expired Norton w/a freebe I downloaded then the problems started. Would not comunicate sometiimes and when it did it printed once than froze. Would not delete printed doc or print the next. I remembered that McAfee made my old Emachine freeze or crash. Put Norton back on and no more problems. Hope this helps you.
Feb 05, 2009 | Dell 926 All-In-One InkJet Printer
Dell photo 926 printer communication problem
1)right click the my computer icon
2)click properties and then click hardware n go to device manager.
3)uninstall all usb ports and then scan for hardware changes
4)ur pc will detect your printer and ask for printer drivers
5)re load drivers and your pc will communicate with your printer
6)for reloding install the cd follow the instructions on the screen and click next
7)restart when the printer is loded.connect the wires and cords properly.
Oct 05, 2008 | Dell 926 All-In-One InkJet Printer
Computer will not communicate with printer
Go out to Lexmark web site and look for a vista update in their software download section. So this should solve your problem.Most of the cds which come with equipment do not contain vista software and drivers.
Aug 06, 2008 | Dell 962 Photo All-In-One InkJet Printer
Dell Dimension 2350 - Computer Crashing
try boot in safe mode and restore to an earlier date when your pc was working nicely
May 08, 2008 | Dell Dimension 2350 PC Desktop
Dell Inkjet 720 Printer Logo
542 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
